Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924, 925, 926, 927
  1. 914-6 speedo inop (13 replies)
  2. Argh! Another one headed to the junkyard. (9 replies)
  3. front oil cooler oil lines from the hard lines (0 replies)
  4. got my vertical spare tire mount (10 replies)
  5. Is it a fools errand to try to put engine tin on once the engine is installed in the car? (7 replies)
  6. Vertical Mount Collapsible Spare Tire (9 replies)
  7. Wiper system install (1 replies)
  8. Rear license plate bracket screw size (0 replies)
  9. OT: Birthday Fairy News for 22 May 2019 (7 replies)
  10. Fuel Pump Issue (4 replies)
  11. Would you believe...? (4 replies)
  12. A-arm bushing install video (37 replies)
  13. CV joint axles pulled (3 replies)
  14. 914-4 AGM Battery (22 replies)
  15. A question about the factory backpad (23 replies)
  16. Another Front Oil Cooler (15 replies)
  17. Original CA Blue/Gold License Plate list (107 replies)
  18. Passing On Information (3 replies)
  19. 914 air conditioning (37 replies)
  20. Moved: FS: Rayco Kit (-- replies)
  21. The righteous sound of a SIX. (20 replies)
  22. SOT: Flat tow break away device (0 replies)
  23. ECU loom plug remove tools (8 replies)
  24. Wheel options? (32 replies)
  25. OT: Birthday Fairy News for 21 May 2019 (5 replies)
  26. Shifter in 4th position for engine removal? (4 replies)
  27. SOT: The Meyers Manx reborn! (4 replies)
  28. Proper Alignment Makes All the Difference (7 replies)
  29. 914 1.7 to a 2.0 (VW) (13 replies)
  30. VTEC Swap: (29 replies)
  31. Correct ECU for 1.7 registered October 1971 (12 replies)
  32. Rear Wheel Bearing questions (10 replies)
  33. Charcoal canister hoses (1 replies)
  34. OT: Birthday Fairy News for 20 May 2019 (5 replies)
  35. Installing new differential - reading mesh pattern (2 replies)
  36. FIXED: Idle was HIGH, now too low, popping and missing VIDEO (12 replies)
  37. 1975 1.8 FI fuel pump not working (3 replies)
  38. 914-4 2L - 1 in 2 out exhaust with headers (0 replies)
  39. Web Cam Lifters with EDM hole (5 replies)
  40. Where does this white wire go? (12 replies)
  41. Best Ignition Switch (3 replies)
  42. Brian Redman (4 replies)
  43. Alternator recommendations (0 replies)
  44. OT: Birthday Fairy News for 19 May 2019 (7 replies)
  45. Calling FI Experts (4 replies)
  46. OT: Birthday Fairy News for 18 May 2019 (7 replies)
  47. Fuel pump for carbs on a '75 (10 replies)
  48. additional oil heater solutions for 2.0/4 (6 replies)
  49. Fuel Pump Wiring Experts (22 replies)
  50. South Florida Body Metal Repair (2 replies)
  51. Front Targa Seal installation (8 replies)
  52. Sail Panel Vinyl on New Paint (9 replies)
  53. OT: Birthday Fairy News for 17 May 2019 (8 replies)
  54. Wacky Wipers (15 replies)
  55. Odometer stopped working (5 replies)
  56. Pads (2 replies)
  57. questions about a 205AA Dizzy with dual IDF weber 40's (8 replies)
  58. Going to dual Carbs from single Carb (23 replies)
  59. Windshield Moulding Retaining Clips (8 replies)
  60. Steering column interchangability? (9 replies)
  61. Dash Gauge Pod (29 replies)
  62. Hell Hole Time (6 replies)
  63. FIXED: Idle weirdness (22 replies)
  64. Seats are done (13 replies)
  65. 911S strut assemblies (24 replies)
  66. More Novice Help Please, Suspension (20 replies)
  67. What fuel pump you running? (10 replies)
  68. OT: Birthday Fairy News for 16 May 2019 (4 replies)
  69. My very own barn find (15 replies)
  70. 75 914 Bumper (2 replies)
  71. Odyssey Battery Question (12 replies)
  72. Gauging interest...pun intended (26 replies)
  73. Trailing arm bushings (10 replies)
  74. OT: Birthday Fairy News for 15 May 2019 (9 replies)
  75. Rear View Mirror placement? (10 replies)
  76. rotors, coils, and pertronix (8 replies)
  77. Front Hood Bolts (10 replies)
  78. 2 ltr from 1.7 ltr motor (11 replies)
  79. Hood Catch Problems (21 replies)
  80. OT: Birthday Fairy News for 14 May 2019 (5 replies)
  81. 1973 Horn Don’t work (22 replies)
  82. interesting 76 fact (19 replies)
  83. S.o.t...Front trunk springs (8 replies)
  84. Forum Questions (8 replies)
  85. Which would you choose? (15 replies)
  86. 914 styled steel wheel fitment to 72' T1 (5 replies)
  87. Throw out bearing failure (20 replies)
  88. Part(s) Source (11 replies)
  89. OT: Birthday Fairy News for 13 May 2019 (9 replies)
  90. Engine Number Decode help (3 replies)
  91. Seat Beat Bolt (10 replies)
  92. Downgrade a 914/4 side shift trans to a tail shift? (20 replies)
  93. Is this the right Bellcrank Carb Linkage (10 replies)
  94. Car smells like 5th Avenue right before Christmas (9 replies)
  95. Engine Builders - Recommendations? (5 replies)
  96. Is my fuel pump failing? (2 replies)
  97. PC 680 battery adapter. How I did it. (7 replies)
  98. OT: Birthday Fairy News for 12 May 2019 (6 replies)
  99. Exhaust to head gasket removal (6 replies)
  100. Stuck front caliper pistons (7 replies)
  101. Guy Berryman's Car Collection Inc. a 914/6 (1 replies)
  102. GB for headlight surrounds Black and White (20 replies)
  103. 1.7 Timing Help (5 replies)
  104. Defrost light wiring (10 replies)
  105. Fun 914 film from Germany (6 replies)
  106. What to do about a worn transmission? (11 replies)
  107. Stock dizzy for carbs (0 replies)
  108. Replacing first gear - question on sealing it back up (0 replies)
  109. North Carolina inspection (19 replies)
  110. OT: Birthday Fairy News for 11 May 2019 (6 replies)
  111. Shifter ID (5 replies)
  112. Suspension (17 replies)
  113. Rear Light Box (4 replies)
  114. Any after Market F I systems for the Type 4 (32 replies)
  115. Retirement (7 replies)
  116. OT but similar family roots (5 replies)
  117. Newbie from France (16 replies)
  118. Teach me something about spacers (9 replies)
  119. OT: My ports are bigger than yours (7 replies)
  120. patrick motor sport front oil cooler question (14 replies)
  121. Trouble with 1st gear (16 replies)
  122. Looking for someone in Seattle for a possible favor:) (26 replies)
  123. Engine Bay Relay Board (12 replies)
  124. Parking break cables (6 replies)
  125. Master Brake Cylinder (5 replies)
  126. New GB LED replacment Bulbs $99 a set (51 replies)
  127. Sketchy reply to a wtb (1 replies)
  128. OT: Birthday Fairy News for 9 May 2019 (8 replies)
  129. What are the trickiest parts about rebuilding one of these engines? Thanks (38 replies)
  130. General Novice Questions (3 replies)
  131. Installing an L Jet in a 72 (2 replies)
  132. WTB 6-Hole Flywheel Plate for 914-6/911 (5 replies)
  133. OT: Birthday Fairy News for 8 May 2019 (5 replies)
  134. Fog light trim retainer (12 replies)
  135. Emergency Brake Light - where is it? (9 replies)
  136. Renegade Hybrids Axle Kit (17 replies)
  137. PMB Performance did it again (6 replies)
  138. Suspension Ear Jig (21 replies)
  139. Giving Up On Vacuum Advance (41 replies)
  140. Easy access (14 replies)
  141. Oil pressure gauge (7 replies)
  142. Help with decel valve - 1973 2.0 (3 replies)
  143. Butyl primer for windshield installation, NLA in CA (5 replies)
  144. Spring G & R Swap Meet Sunday May 5 , 6AM - 12PM (110 replies)
  145. Resistor Spark Plugs (7 replies)
  146. Need a place to work on your 914 (5 replies)
  147. Getting carpet to stay in place (11 replies)
  148. SLITS ...Ron (28 replies)
  149. 914 performance possible? (32 replies)
  150. CIS Conversion on 2056 (41 replies)
