Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923
  1. Water spots (29 replies)
  2. Cylinder head studs (3 replies)
  3. RPM Idle for 1973 1.7? (5 replies)
  4. help with 1.7 rocker identification (1 replies)
  5. BOV (7 replies)
  6. Before I install my working engine what should I fix / replace? (14 replies)
  7. Cruze In (0 replies)
  8. How to correctly remove 914 rear glass (4 replies)
  9. SOLD Thanks (7 replies)
  10. Driver Side Rear End (29 replies)
  11. OT: Birthday Fairy News for 29 Sept 2013 (8 replies)
  12. 2 lines (tube) on outside of my early rollers drivers side long.. (5 replies)
  13. what does this mean? (1 replies)
  14. Porsche graphic (11 replies)
  15. starter wont crank (13 replies)
  16. Bosch fuel pump cross reference needed (4 replies)
  17. 914 spotted in Austin (18 replies)
  18. how many are using lightened flywheel and or stage 2 clutch kit (14 replies)
  19. Rear Shock Tower Tear (8 replies)
  20. I've only got 11 balls ... (4 replies)
  21. 2056 Valvetrain question (26 replies)
  22. bleeding brakes, etc (23 replies)
  23. Machining adapters for Subaru to 914 axels? (9 replies)
  24. Flywheel bearing greese (4 replies)
  25. Fuel Filler Vent and Charcoal Can (3 replies)
  26. OT: Birthday Fairy News for 28 Sept 2013 (7 replies)
  27. 914 Quirks (61 replies)
  28. Guage and Getty dash questions (7 replies)
  29. Need brake job (11 replies)
  30. 914 owners art decor (1 replies)
  31. AAR revisited (4 replies)
  32. Help Need for 3.6L conversion - O2 sensor (12 replies)
  33. Fog Light Flasher Relay Update... (8 replies)
  34. Need Help repair portion of rear firewall: Clutch cable tube & fuel tunnel holes (10 replies)
  35. Monterey Historic races + Pebble Beach, 1978 (11 replies)
  36. Rant: buyer beware of Rimco (19 replies)
  37. Looking for a new CDI box (2 replies)
  38. Is there a vendor who can upholster a Getty dash? (11 replies)
  39. Help removing stuck jets (6 replies)
  40. Transmission Fluid (3 replies)
  41. help identify part (13 replies)
  42. Spark plugs, how do you determine which to use (4 replies)
  43. Oops y'all (8 replies)
  44. OT: Birthday Fairy News for 27 Sept 2013 (10 replies)
  45. Non Ethanol Fuel (22 replies)
  46. Replacement Fuel Gauge (16 replies)
  47. SOT: Adios Kombi (3 replies)
  48. Engine damage with too much oil (7 replies)
  49. Teryn It Up's 71 1.7 (10 replies)
  50. Coming to LA tomorrow, Driving back to Michigan (2 replies)
  51. OT: Birthday Fairy News for 26 Sept 2013 (8 replies)
  52. Bay Area 914 events (7 replies)
  53. Who made this p&c? (9 replies)
  54. Help with fuel system diagnosis (4 replies)
  55. Coronado Speed Festival -914 content (23 replies)
  56. Avatar (8 replies)
  57. Standard 1.7 Exchanger Tube Size (13 replies)
  58. VTO Wheels? (21 replies)
  59. targa top finish (4 replies)
  60. OT: Birthday Fairy News for 25 Sept 2013 (7 replies)
  61. How stupid is it (29 replies)
  62. 110mm Trans output flanges (5 replies)
  63. Side Mirror Re Chrome (8 replies)
  64. Ariel Atom clone with a Type IV has been built (86 replies)
  65. OT (3 replies)
  66. Restoration Rebuild Vendors in Southwest USA (5 replies)
  67. How to test a speedometer angle drive? (4 replies)
  68. OT 964 crash (21 replies)
  69. East Coast racing? (21 replies)
  70. How Do I Check Front Shocks (17 replies)
  71. Wire (6 replies)
  72. OT: Birthday Fairy News for 24 Sept 2013 (7 replies)
  73. Sale on water cooled engines...SunCoast Porsche (2 replies)
  74. Review for aftermarket sports console (2 replies)
  75. 8" wide fuchs front and back? (10 replies)
  76. OT My new toy (47 replies)
  77. Cooling fan (13 replies)
  78. OT: Birthday Fairy News for 23 Sept 2013 (12 replies)
  79. Interesting Items (14 replies)
  80. getting some gear crunching (13 replies)
  81. trans removal (10 replies)
  82. 1st driving video (11 replies)
  83. brush plate for starter (3 replies)
  84. 914-4 rear brake caliper options? (3 replies)
  85. Fuel pump is noisy (8 replies)
  86. Sighting - anybody having this car towed near Allentown, PA today? (0 replies)
  87. Is there any advantage to 916 front bumper? (23 replies)
  88. rear shock question -- resolved (0 replies)
  89. WOT: Dad's kevlar canoe major repair/rebuild (20 replies)
  90. pre-75 swap meet @ Ski Roundtop, Lewisberry, PA 9/21 (12 replies)
  91. October (0 replies)
  92. Brumos 914.043.2563 (8 replies)
  93. Bung for EGO Sensor (2 replies)
  94. OT. Look what I found 5 miles from the house yesterday (6 replies)
  95. Abbey's AirCooled 73 2.0 project (26 replies)
  96. Shifty eyed (0 replies)
  97. Dash Layout Question (6 replies)
  98. Shifting (26 replies)
  99. Shifting (4 replies)
  100. Opinion on cutting out & steering wheel vibration (9 replies)
  101. OT: Birthday Fairy News for 22 Sept 2013 (8 replies)
  102. 17 MM master cylinder (28 replies)
  103. Hot wiring a 914-6 / 911 engine (9 replies)
  104. Front Guide Rail (5 replies)
  105. looking for a very special scale model (7 replies)
  106. Northeast Rally & BBQ Pictures Thread (55 replies)
  107. Twin Turbo type 4 (21 replies)
  108. Trying to decide what wheels to run. (1 replies)
  109. Complete trans loss? (20 replies)
  110. New Webers, crazy high idle - SOLVED (17 replies)
  111. Are the stub axles supposed to have any play? (13 replies)
  112. Worthless 914 parts (45 replies)
  113. Air Duct Floor (13 replies)
  114. 15" or 16" Fuchs (26 replies)
  115. COTM Sept-Oct 2013 POLL CLOSED (59 replies)
  116. 2.0 heads with valve guide bosses machined off (4 replies)
  117. Axle Bolt Torque (1 replies)
  118. Electrical Question's (6 replies)
  119. SOT: Suby Factory Manual (12 replies)
  120. Engine Seems To Run Hot (20 replies)
  121. COLLISION - All fixed! (42 replies)
  122. Combo gauge (6 replies)
  123. $4200 for 15" Mahle Gas Burners? (32 replies)
  124. Lets chat about oil pressure/ oil temp (40 replies)
  125. Power Loss Under Load (7 replies)
  126. Door Restoration (0 replies)
  127. restoration design rear trunk reinforcement (9 replies)
  128. I got a new Bug... (9 replies)
  129. OT: Birthday Fairy News for 20 Sept 2013 (8 replies)
  130. Need a Seattle mechanic (21 replies)
  131. Trouble at low speed and a hot start problem (5 replies)
  132. Early and late wiper motors are wired differently! (11 replies)
  133. First drive with my new 2.0L engine.... (30 replies)
  134. Strut housing info please! (4 replies)
  135. Happy Ferry day (3 replies)
  136. Transmission leak at gasket (12 replies)
  137. 914-6 vs. 930 (25 replies)
  138. Where can I get a 914-6 2.2 sticker made? (8 replies)
  139. Oil temp- how low is too low (10 replies)
  140. Washer behind fog lights (1 replies)
  141. OT: Birthday Fairy News for 19 Sept 2013 (12 replies)
  142. Forgotten Leak Source (10 replies)
  143. Need Help.. Throttle sticking (16 replies)
  144. Upgrading Engine Specs and Overall Performance (2 replies)
  145. Shameless 916 Plug (26 replies)
  146. Transmission Leak (13 replies)
  147. Broken valve? (1 replies)
  148. Where do you buy SS Wire for the CV Bolts (12 replies)
  149. Ski Roundtop Aircooled Swap Meet - Lewisberry, PA (2 replies)
  150. Remove paint from trim (5 replies)
