Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923
  1. Why does my engine rev full blast with clutch in (6 replies)
  2. Is anyone using a cable-shifter for gears? (6 replies)
  3. Speedometer/odometer dump (3 replies)
  4. 1.7 djet compression specs/ wear limits (18 replies)
  5. Rear brake caliper help/info needed... (28 replies)
  6. compression question (34 replies)
  7. Back UP! (12 replies)
  8. Goldilocks and the 914 (9 replies)
  9. Replacing heads on a 1.8L 1974 (19 replies)
  10. 951 guru's (3 replies)
  11. Opinions needed what value would you place on this? (20 replies)
  12. OT: Birthday Fairy Report for 26 April 08 (10 replies)
  13. First post, Fuel Injection Question (27 replies)
  14. Targa top dye? ....not paint? (9 replies)
  15. Heading down for G & R 914 swap meet! (13 replies)
  16. OT but very cool - electric "unicycle" (8 replies)
  17. This week's progress (9 replies)
  18. SSI Heat Exchangers? (10 replies)
  19. How to remove A arm from strut (15 replies)
  20. 16 x 6 Fuchs as spare- what size tire? (1 replies)
  21. Heres 1 (8 replies)
  22. Different Location for Cylinder Head Temp Sensor (6 replies)
  23. Screw on throttle body (4 replies)
  24. Set Timing and Car Runs Like Crap (10 replies)
  25. Plug gap recommendation? Carbed 73 1.7 (1 replies)
  26. Coleman Racing Adjustable Spring Perch (6 replies)
  27. norcal bay area breakfast (38 replies)
  28. setting initial timing on new motor start up (9 replies)
  29. Rear Brakes - 914/6 (14 replies)
  30. 944 CV joint conversion? (4 replies)
  31. Push rod tube retainer springy-thinies (10 replies)
  32. Interior Mirror height? (9 replies)
  33. Question about 4 to 5 lug adapters? (1 replies)
  34. Bad weld on Eurorace header collector (5 replies)
  35. I had a run in with a bad alternator (5 replies)
  36. Windshield Width (2 replies)
  37. 374 currently on line lets party! (1 replies)
  38. front caliper identification (18 replies)
  39. So, can you just pull a head off of a /4 (30 replies)
  40. Door handle problems... (5 replies)
  41. Moved: 914 2.0 heads! (-- replies)
  42. My 914 on YouTube (7 replies)
  43. Ignition (distributor) timing gear (16 replies)
  44. Determining compression based on compression test numbers (6 replies)
  45. Firewall repair instead of replace? (1 replies)
  46. Help find sourse of oil leak (18 replies)
  47. Sexy! (4 replies)
  48. ONLY 1 MORE DAY...To Vote for Mrs. K! (6 replies)
  49. Steering rack question (5 replies)
  50. Step by step photobucket (7 replies)
  51. Fixing my thermostat (14 replies)
  52. Rear brake adjustments (7 replies)
  53. To be clean or not be clean? (4 replies)
  54. Piston Question (3 replies)
  55. Hey McMark, found pics! (13 replies)
  56. OT: Birthday Fairy News for 25 April 08 (11 replies)
  57. OT sort of...AUTO X Sunday Wash DC (0 replies)
  58. Busy Day today, Fuel Pump Leak (8 replies)
  59. which is the better anti-theft device? (31 replies)
  60. 7x15 4-lug wheels? (14 replies)
  61. npc/ scangauge, (1 replies)
  62. Machining a sealing groove (7 replies)
  63. Anybody here who can redo a lower dash pad? (7 replies)
  64. I Have Gas (13 replies)
  65. I opened Pandora's Box. (2 replies)
  66. Need help with parts (0 replies)
  67. anyone have blue printing specs for a 2.0L -4? (2 replies)
  68. worst road rage experience (50 replies)
  69. 73 914 2.0 revs to high rpm by itself! (25 replies)
  70. POPPY RED (12 replies)
  71. OT: Fun lunch break (4 replies)
  72. High Pressure Washer – Friend or Foe (14 replies)
  73. Whats the worth? (4 replies)
  74. How to tell the difference between 1.7 and 1.8 heads? (1 replies)
  75. Gas Additive (33 replies)
  76. Points and condensor for an 050 Dizzy? (0 replies)
  77. FOUND ONE - NEVERMIND (0 replies)
  78. Who all here does vinyl lettering (6 replies)
  79. OT: Birthday Fairy Report for 24 April 08 (8 replies)
  80. Let's Find This 914 (6 replies)
  81. Gas to use (3 replies)
  82. Anyone out in Reno, NV willing to do a PPI? (18 replies)
  83. Hershey attendees! (14 replies)
  84. I DID IT - IT RUNS! (11 replies)
  85. Parts cleaning with oven cleaner (15 replies)
  86. Somebody had a diagram for adapting the 911 ignition switch (3 replies)
  87. Fuse panel covers (8 replies)
  88. 914-6 Rear Axle shaft (1 replies)
  89. fart pipe on 914 with header? (33 replies)
  90. Turn signal/wiper switch (6 replies)
  91. Splitting Case - Help (19 replies)
  92. OT: Boxter motors installed in a what? (1 replies)
  93. Front Valance Paint Protection (15 replies)
  94. Subtle sport seats that fit (30 replies)
  95. which wires go where when hookin up the starter (8 replies)
  96. What's it worth? (18 replies)
  97. Ballast resistor (2 replies)
  98. Chances of selling a 1.8 at Hershay? (1 replies)
  99. OT: Carfax ... grumble, grumble ... (6 replies)
  100. OT: Birthday Fairy News for 23 April 08 (5 replies)
  101. OT: Redwood City, CA 914 Owners (7 replies)
  102. 914 reunion charlotte (0 replies)
  103. Funny video ( 914 at the end ) (9 replies)
  104. Dropping the engine for the first time (25 replies)
  105. Double your autocrossing pleasure! (4 replies)
  106. Rockin' out (12 replies)
  107. NON Porsche projects ? (55 replies)
  108. For those of you organizing a 914 Event ... (2 replies)
  109. Kumho V700 Victoracers? (0 replies)
  110. SF Bay Area breakfast (1 replies)
  111. 2.2L Six (10 replies)
  112. 914 update (2 replies)
  113. Check Out The Magic (0 replies)
  114. Handling feels "wiggly" (7 replies)
  115. Engine replacement question (3 replies)
  116. i'm laughing my ass ofF! (23 replies)
  117. OT: State Farm Insurance! (34 replies)
  118. 1911 + ready to go (28 replies)
  119. Issues painting sheet metal (14 replies)
  120. CV joint bolts (2 replies)
  121. teener daily driver (45 replies)
  122. saw the European GT championships at Silverstone! (5 replies)
  123. Chassis (re)construction (9 replies)
  124. Fog Lamp circuit breaker pops. Why? (6 replies)
  125. 1.7 intake runner boot (6 replies)
  126. Under Cylinder Tin (3 replies)
  127. WANTED Pics of rear valences (22 replies)
  128. Long Beach Gran Prix Pics - Saturday (17 replies)
  129. Need a recomendation for DFW body work (9 replies)
  130. 1998 VW golf Parts interchange. (2 replies)
  131. updates this weekend - nice weather in CO finally (17 replies)
  132. Plastic Fuel Lines (29 replies)
  133. anyone know the weight of a bare shell? (24 replies)
  134. My feeble attempt at Bling (3 replies)
  135. NEWS LETTER (4 replies)
  136. Nominations for May/June: Car of the Month Contest! (33 replies)
  137. How Do I remove the Window and Frame (3 replies)
  138. The car of the month (4 replies)
  139. very special (?) teener on eBay (9 replies)
  140. gettinerdone! (7 replies)
  141. Wierd turn signal buzzing (6 replies)
  142. runs like a pig today - help (5 replies)
  143. New Member Common Tire Question (10 replies)
  144. Heading to Hershey from Pittsburgh (1 replies)
  145. Insulation Melted Off Coil Wire - HELP (9 replies)
  146. Clutch question (1 replies)
  147. WOT: How I'm spending my weekend... (34 replies)
  148. Need out of CA help, free vinyl script for the help (5 replies)
  149. OT: Birthday Fairy Report for 21 April 08 (4 replies)
  150. What you need? What you need? (14 replies)
