Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924
  1. OT: My new tow rig (2 replies)
  2. Help! Speedo Seal Removal (6 replies)
  3. Team NARP (17 replies)
  4. Members in Eugene, Oregon - (19 replies)
  5. Sort of OT: Looking for era correct Recaro seats for a 911 (2 replies)
  6. Left longitudinal member (1 replies)
  7. Rear swaybar drop link bushing (7 replies)
  8. Bra<ke line lenghts (3 replies)
  9. Oil Pressure Sending Unit (11 replies)
  10. Headlight switch removal (8 replies)
  11. Valve Adjustment Screw Questions (4 replies)
  12. Wrong rear bkake pads (2 replies)
  13. How do you make fog lights independent of low beam? (30 replies)
  14. Just to be sure... Front transmission seal replacement (6 replies)
  15. 2,000 HP Flat Four (23 replies)
  16. Mounting new coil (6 replies)
  17. OT: Hercules (11 replies)
  18. OT: Birthday Fairy News for 3 Jan 2014 (7 replies)
  19. Installing Bearings and Hubs (36 replies)
  20. Fresh Air Grille? (7 replies)
  21. Subaru Engine, Trans, ECU, Wiring Harness (13 replies)
  22. new master cylinder not bleeding...what now? (8 replies)
  23. Stock -6 Fuel Pump (4 replies)
  24. www.914ap.com contact info? (10 replies)
  25. Painting the rocker panels (6 replies)
  26. NOT Driving my Car Today. (22 replies)
  27. Heat and AC for my darkside (2 replies)
  28. Need heater / flapper gaskets (7 replies)
  29. Recommendations for a floor jack? (35 replies)
  30. Info on 914 manufacture (19 replies)
  31. 914-6 (6 replies)
  32. Fill my opening (16 replies)
  33. Targa seal (1 replies)
  34. 3rd Brake light with pulse strobe (33 replies)
  35. GPS: any have a full screen speedo selection? (15 replies)
  36. 5-bolt hub caps on 4-bolt wheels? (3 replies)
  37. getting tanked (4 replies)
  38. Intermittent connection Engman fuse panel (6 replies)
  39. OT: Birthday Fairy News for 2 Jan 2014 (8 replies)
  40. GB- The original window scrapers (54 replies)
  41. OK, so now what (30 replies)
  42. identify this steering wheel? (4 replies)
  43. Tip-Renegade motor mounts (11 replies)
  44. Check this out (3 replies)
  45. Christmas is Over (5 replies)
  46. OT: Birthday Fairy News for 1 Jan 2014 (9 replies)
  47. Apparently I need a new computer for my 1974 2.0 with D-jet fuel injection (35 replies)
  48. Happy 2.014! (2 replies)
  49. Cut a new Master Key from a Valet Key (15 replies)
  50. HAPPY NEW YEAR! (13 replies)
  51. Has anyone seen any thread about a Bay Area New Year's Day drive? (13 replies)
  52. found another one (25 replies)
  53. OT: Birthday Fairy News for 31 Dec 2013 (9 replies)
  54. testing orig radio for functionality (7 replies)
  55. 914-4 rear caliper rebuild kits ---eware (6 replies)
  56. New Years Eve North Georgia Mtn Drive (8 replies)
  57. Caliper Question - Calling Eric (3 replies)
  58. which type of sway bar (10 replies)
  59. Watercooled VW / Audi motor swaps? (42 replies)
  60. Sitting at the Airport (0 replies)
  61. Running down the road (3 replies)
  62. Removing Heat Exchangers (2 replies)
  63. Tie Rods (11 replies)
  64. New to me 2.2 (12 replies)
  65. SAN FRAN (0 replies)
  66. PCA National Press Release- Werks Reunion (15 replies)
  67. Windshield replacement needed (8 replies)
  68. tightening front wheel bearings (1 replies)
  69. CV Joint HELP! (3 replies)
  70. Paint question (25 replies)
  71. Light Smoke (19 replies)
  72. Wheel center cap locks (2 replies)
  73. Michael Schumacher injured (35 replies)
  74. Mount for Tomtom V2 GPS (13 replies)
  75. Exhaust flange spacing (8 replies)
  76. Bushing Grease (7 replies)
  77. Another round of 73 1.7 questions (3 replies)
  78. i almost got scammed - craigslist/paypal - related (23 replies)
  79. Tips for Speedo Angle Drive Seal Replacement (12 replies)
  80. Werks Reunion A Porsche Reunion Carmel Vally, August (4 replies)
  81. My latest project (48 replies)
  82. Can you restore a fog light lense? (5 replies)
  83. Seat cover kits: World Upholstery vs ebay aoenterpreses (12 replies)
  84. 71 914 with less than 70k (14 replies)
  85. Introduction (18 replies)
  86. OT: Birthday Fairy News for 30 Dec 2013 (8 replies)
  87. OT: Headed to the PNW (7 replies)
  88. Deciding about wiring harness ? (20 replies)
  89. Seatcovers from " aoenterpreses" on evilbay? (2 replies)
  90. Karmann ghia with 914 engine (86 replies)
  91. Trailing arm bushings (30 replies)
  92. A European friend is looking for an "037" MPS (7 replies)
  93. Which VDO gauge (1 replies)
  94. GEARS! (5 replies)
  95. Replacing sail panels (3 replies)
  96. LOWER TARGA SEAL (1 replies)
  97. Fog Light Protection (6 replies)
  98. OT: Birthday Fairy News for 29 Dec 2013 (6 replies)
  99. Firewall shift bushing linkage install question (12 replies)
  100. Searching for the original engine for my -6 (12 replies)
  101. What is this hole for? (7 replies)
  102. Has anyone painted their engine block and fan housings ? (12 replies)
  103. Runs only with air flow meter disconnected (17 replies)
  104. Rear engine seal (5 replies)
  105. Searching for my original engine - Chris Rider from All Wheels in MA? (2 replies)
  106. OT: Birthday Fairy News for 28 Dec 2013 (7 replies)
  107. Should I? (28 replies)
  108. Hurley Haywood Porsche 914 GT video (32 replies)
  109. So you want to rebuild your Webers? (35 replies)
  110. Air Filter Assemby Recommendations for Weber IDF (25 replies)
  111. What Originally Came with a 914? (11 replies)
  112. 1978 vintage center console with beverage holder (4 replies)
  113. Alternatives to Hagerty (32 replies)
  114. Running fuel and brake lines under the car... (19 replies)
  115. mystery wire (18 replies)
  116. Pull loops on RS-style door panels (2 replies)
  117. Getting gas tank boiled/cleaned/painted (6 replies)
  118. OT: 911 by Singer (1 replies)
  119. Please help me name our Classic Car Restoration shop (64 replies)
  120. Cars and Coffee (12 replies)
  121. OT: Birthday Fairy News for 27 Dec 2013 (8 replies)
  122. Rocker set question? (16 replies)
  123. lower air guides (26 replies)
  124. New 96mm 1911cc kit (17 replies)
  125. Weirdest thing ever done to a SIX? (26 replies)
  126. cable shifter (19 replies)
  127. delete (63 replies)
  128. HAPPY BOXING DAY ! (2 replies)
  129. OEM Foglight wiring (5 replies)
  130. Running on 3 1/2 Cylinders (15 replies)
  131. 914 Near-Mint American Lenses: What are they worth? (7 replies)
  132. OT: Birthday Fairy News for 26 Dec 2013 (7 replies)
  133. Carbs backfire (8 replies)
  134. Exhaust Options (36 replies)
  135. Anyone need something transported (1 replies)
  136. Eye spyed Ice blue 914 Southlake TX (3 replies)
  137. Merry Christmas and Happy Holidays (52 replies)
  138. Congratulations Paul Bizzigotti! (12 replies)
  139. Just some vintage 914 pictures (60 replies)
  140. OT: 2003 Boxster S engine replacement (203 replies)
  141. Project Received (31 replies)
  142. MAP sensor/OT (6 replies)
  143. Side Mirror Inside Cushion (12 replies)
  144. Cant tell what i have (24 replies)
  145. OT: Birthday Fairy News for 25 Dec 2013 (7 replies)
  146. Replacing 930 selector shaft seal? (19 replies)
  147. 1970 914/4 turn signal switch/high beams (6 replies)
  148. Canadian 914s (17 replies)
  149. Porsche Parade 2014 Monterrey, June 14-21 (23 replies)
  150. right rear possibel wheel ,brake noise question (0 replies)
