Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924, 925, 926, 927, 928
  1. Drip, drip, drip (7 replies)
  2. Car cove forr long term storage (4 replies)
  3. Sway Bar Question (22 replies)
  4. SOT-Gulf blue color code (3 replies)
  5. Vapor Blasting Engine and/or Transmission Case (22 replies)
  6. Door handle issue (12 replies)
  7. Early six oil pressure sender question (5 replies)
  8. Recommendation on fuel pressure regulator for return line on dual carb (17 replies)
  9. Cooling flaps and thermostat (11 replies)
  10. Speedo cable disaster (0 replies)
  11. Gauging value of NOS ? 914-6 heater flapper valves (23 replies)
  12. Birthday News for 2/27/25 (6 replies)
  13. Fuel pressure gauge installed / cutting a notch out of the lid hinges (7 replies)
  14. Gas tank fittings (4 replies)
  15. Ash tray (19 replies)
  16. A separate hole in the tin for the CHT sensor wire ? (9 replies)
  17. What Now !? .. the Ignition Switch? (9 replies)
  18. 914/4 914/6 brake master cylinder (10 replies)
  19. Recommended dual Webers Carburetors (13 replies)
  20. Heated Windshield? Or "Windscreen" (10 replies)
  21. Birthday News for 2/26/25 (5 replies)
  22. Attention @SirAndy (1 replies)
  23. Birthday News for 2/25/25 (8 replies)
  24. 911 Bilstein Struts on a Narrow 914 (8 replies)
  25. Birthday News for 9/27/24 (9 replies)
  26. Crazy accident footage (11 replies)
  27. Door hinge pins (3 replies)
  28. SoCal Lit Show 2025 (25 replies)
  29. Clutch Arm Qs (4 replies)
  30. Birthday News for 2/24/25 (5 replies)
  31. Suspension Decisions (19 replies)
  32. 96mm P&Cs (11 replies)
  33. Reviving a Salvage/Junk Title in California (55 replies)
  34. Twitchy steering (6 replies)
  35. Safari 914 project (385 replies)
  36. Weird holes in 2.0 heads, anyone seen this before (5 replies)
  37. Birthday News for 2/24/25 (0 replies)
  38. GT line group buy (4 replies)
  39. Server maintenance today (5 replies)
  40. Door jam jig (0 replies)
  41. Distributor Concerns on my 1.7 (12 replies)
  42. New fuel pump for D-jetronic FI - advice needed, please...... (10 replies)
  43. Brake line differences - support through strut (7 replies)
  44. 914 at LKQ (1 replies)
  45. 2L Case refurb (7 replies)
  46. Do I need both sway bars, or is front enough? (24 replies)
  47. Need help with sizing Gruppe 4 Campy reps and Vred Sprint Classics with GT Flares (7 replies)
  48. Anyone have more info on this 914? (2 replies)
  49. Baby Moon hubcaps on Fuchs? (13 replies)
  50. Thunderchief's 3.6 build (12 replies)
  51. 914world is showing its age (151 replies)
  52. '73 tach wiring question (3 replies)
  53. Crack in Drivers Side Long? (34 replies)
  54. tachometer (4 replies)
  55. Six engine detail question (4 replies)
  56. Transmission Mount Bolts (10 replies)
  57. Birthday News for 2/21/25 (8 replies)
  58. BUILD-OFF CHALLENGE: 1972 barnfind (21 replies)
  59. Another new guy (19 replies)
  60. Rear Wheel Flares (5 replies)
  61. Dashboard switches (11 replies)
  62. Birthday News for 2/20/25 (7 replies)
  63. Rims (8 replies)
  64. 9142430240 (4 replies)
  65. Resurface Dash Face (16 replies)
  66. Birthday News for 2/19/25 (8 replies)
  67. 022906091A Fuel Pump O-Ring (12 replies)
  68. Fuel Tank Strainer Pipe Leak (10 replies)
  69. Headlight Switch (1 replies)
  70. Any Solutions for smoothing carpet over the Tunnel ? (7 replies)
  71. windshield top seal (1 replies)
  72. Muffler Question (7 replies)
  73. Rear sway bar identification (3 replies)
  74. Engine freshen up tasks? (6 replies)
  75. Wiper parking mystery (4 replies)
  76. Birthday News for 2/18/25 (5 replies)
  77. Porsche Experience Center Los Angeles (11 replies)
  78. Inner Longs Kit origin and testing? (48 replies)
  79. Reservoir Brake Lines (4 replies)
  80. 914 Rear sway bar info (13 replies)
  81. Lit show shop tours this week (0 replies)
  82. Which Heater Cable for '74 Exhaust Backdate? (5 replies)
  83. Bottoming out adjuster screw before leveling the ride height ? (11 replies)
  84. Brake adjuster cap removal (5 replies)
  85. Wait...Walmart sells 914 parts now? (20 replies)
  86. Birthday News for 2/16/25 (5 replies)
  87. 914/6 stub axle (15 replies)
  88. AA Performance Products & GEX (11 replies)
  89. Birthday News for 2/15/25 (4 replies)
  90. Birthday News for 2/14/25 (8 replies)
  91. Carb Manifold Gasket (12 replies)
  92. Option of Alfa Dellorto's DRLA 36's on a bit of a budget ? (5 replies)
  93. 2 bolts with holes at the end of the threads (12 replies)
  94. New Windshield Install (12 replies)
  95. Push rol tube removal (20 replies)
  96. How To Build 914-6 GT STYLE Fuel Gauge (2 replies)
  97. Bench Testing Alternator (5 replies)
  98. Filter console product question (20 replies)
  99. 914.043.0012 (189 replies)
  100. 2.0 Oil Temp Sensors or Senders (5 replies)
  101. Too long on the stands (3 replies)
  102. Miles/Years on a set of Rotors ? (11 replies)
  103. Help identifying 914-6 hot air parts (3 replies)
  104. Birthday News for 2/13/25 (3 replies)
  105. Name that sound! (5 replies)
  106. Transport available: Petaluma <-> Portland (20 replies)
  107. Thinking of our LA family (65 replies)
  108. RATE THIS CORE (19 replies)
  109. Birthday News for 2/12/25 (5 replies)
  110. oil galley plugs - oil pressure relief valve Tangerine ? (6 replies)
  111. Shift Lever at Rest (7 replies)
  112. Aluminum Dry Sump Tank Questions (16 replies)
  113. Front strut axle repairs (16 replies)
  114. Anybody from Cleveland coming to race at Sebring 48 Hours (1 replies)
  115. Koni Rear Shocks (9 replies)
  116. Total lift numbers (11 replies)
  117. Idle fluctuation (24 replies)
  118. Case Marking (4 replies)
  119. Is this cable supposed to be here? (5 replies)
  120. VWP * 9014 (3 replies)
  121. 1970 porsche 914-6 Value (15 replies)
  122. Birthday News for 2/10/25 (4 replies)
  123. Seinfeld’s/McQueen 917 at Mecum (49 replies)
  124. Gear oil (1 replies)
  125. owned since 1978 (13 replies)
  126. Ready to Drop the 914-6 engine and then this! (16 replies)
  127. Which Exhaust Studs (3 replies)
  128. Can't find 20 amp or 7.5 amp GBC fuses (4 replies)
  129. Carb Fire Risk? (10 replies)
  130. Strange Spark Plugs (10 replies)
  131. Spare tire and radiator in the trunk (14 replies)
  132. Private message scammer (6 replies)
  133. Carlo the scammer (3 replies)
  134. Gauge cluster tin- Paint or Powder? (7 replies)
  135. Birthday News for 2/9/25 (4 replies)
  136. SOT -Negative spark advance (4 replies)
  137. Turn signal wiring to dash (2 replies)
  138. Check my new fuel line routing beneath the shelf please (8 replies)
  139. Why, oh Why Wipers! (10 replies)
  140. Video series on Painting a 914 (7 replies)
  141. What defines 914 GT Tribute project (20 replies)
  142. Birthday News for 2/8/25 (6 replies)
  143. I have Stan White's car (5 replies)
  144. OT: For those of us old enough to remember ... (41 replies)
  145. What is missing in this photo? (10 replies)
  146. Birthday News for 2/7/25 (10 replies)
  147. Empi heads and Cima/Mahle cylinders (13 replies)
  148. Deleting a Vehicle from my Signature (11 replies)
  149. Bumper change (18 replies)
  150. Birthday News for 2/6/25 (5 replies)
