Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924, 925
  1. South Florida 914 mechanics (0 replies)
  2. Help me figure a roof coating/color (12 replies)
  3. Installing fuel pressure gauge (4 replies)
  4. Fender flares (22 replies)
  5. need advice on putting in proper shims behind flywheel (36 replies)
  6. my search for a 914... (57 replies)
  7. Oil leak at input area (7 replies)
  8. WTF are these for ? (18 replies)
  9. How to you bench test electrical things? (24 replies)
  10. 914 Springs? (2 replies)
  11. OT: Birthday Fairy News for 6 Feb 2014 (8 replies)
  12. She's got a new attitude. (39 replies)
  13. D-Jet working again (9 replies)
  14. GB: Porsche 914 Sill (Rocker) Panel Rubber Spacer 914-559-127-10 (0 replies)
  15. GB: 914 CV Cover Plates (5 replies)
  16. Various 914 maintenance and repair questions (4 replies)
  17. Body Work Repair Advice Needed (8 replies)
  18. Removing the rocker panel (23 replies)
  19. How much needs to be cut off the lover valve covers (10 replies)
  20. whats with the plastic porsche logo under rear trunk lid (46 replies)
  21. Question about Early Fuchs (14") (1969's) (42 replies)
  22. 914 baja? corvair or 2.0 (9 replies)
  23. I'M SO MAD I HAVE TO USE CAPS! (43 replies)
  24. Tranny issue (10 replies)
  25. vapor lines (13 replies)
  26. shifter bar bushing help needed (7 replies)
  27. Fuel pump location (14 replies)
  28. Distributor rebuild question (2 replies)
  29. Rear Spring Indentification (6 replies)
  30. 1.8 FI distributor (8 replies)
  31. OT: Birthday Fairy News for 4 Feb 2014 (7 replies)
  32. 914 Flywheel Pricing and Quality. (9 replies)
  33. Steering wheel value? (22 replies)
  34. Solar electric 914 at DC Auto Show (17 replies)
  35. Required parts for an oil change (5 replies)
  36. Alternator Cooling duct/backplate (6 replies)
  37. Got my plates today ! (1 replies)
  38. ITB project (53 replies)
  39. people write such poor ads to sell their cars (6 replies)
  40. Are my torsion bars toast? (11 replies)
  41. new engine bay rubber seal i,now have gap (15 replies)
  42. Alternator upgrade (3 replies)
  43. did I shrink my long? (17 replies)
  44. Info or history on my car (6 replies)
  45. OT: Birthday Fairy News for 3 Feb 2014 (9 replies)
  46. 914 sbc turbo, 9" ford, powerglide...how? (5 replies)
  47. Tranny Output Flange Oil Seal (9 replies)
  48. Idle Problems (12 replies)
  49. How hard is it for a semi-novice to put in push rod tubes and seals? "not too bad!" (32 replies)
  50. 2.0l air is sealing ring $9 for rubber only (12 replies)
  51. Front suspension top measuring..... (15 replies)
  52. Moved: Go Hawks! (-- replies)
  53. Moved: You'd think it Christmas Eve (-- replies)
  54. Rough/Missing at Idle/Low RPM (12 replies)
  55. Hub-Centric Spacers? (12 replies)
  56. SOT - best photo sharing website? (4 replies)
  57. WAAAAYYYY OT (0 replies)
  58. CV Joint Will 113 501 331 Work on a 914-4? (3 replies)
  59. 914-6 exhaust hanger (4 replies)
  60. Rods n Wheels (2 replies)
  61. Starter Question follow up (2 replies)
  62. Imron paint on intake runners (2 replies)
  63. fuel delivery differences (HP) (10 replies)
  64. OT: Birthday Fairy News for 2 Feb 2014 (8 replies)
  65. anyone fitted power steering to a 914 (18 replies)
  66. "Port Hole" rear valance, what did they come on? (3 replies)
  67. Paging (2 replies)
  68. NPC - cool old corvette pic i took recently (0 replies)
  69. Sound Deadening? (8 replies)
  70. 70 914 convertible (22 replies)
  71. Troutman 914 pickup trucks (63 replies)
  72. Will the shifter bar be in the way? (5 replies)
  73. Adjustable Temp Electric Fans (24 replies)
  74. Headlight Relay (3 replies)
  75. Wheels and tires, tires and wheels? (18 replies)
  76. Tangerine or signal orange? (37 replies)
  77. Best source for valve springs (9 replies)
  78. Headlight Relays 111 941 583 (1 replies)
  79. How to replace windshield. (4 replies)
  80. sheet metal parts; where to buy? (6 replies)
  81. OT: Birthday Fairy News for 1 Feb 2014 (11 replies)
  82. SOT-Quadcopter Go-Pro at Pipe (6 replies)
  83. Is this the right profile for rear engine tin seal? (4 replies)
  84. Roll bar for a street car? (24 replies)
  85. Pictures of Body Dimension X Measurement Points (36 replies)
  86. Underneath Video (41 replies)
  87. Front End Squeaking After Exhaust and HE Install (14 replies)
  88. 3.6 fuel lines (9 replies)
  89. ISO CV Safety wiring primer (6 replies)
  90. Anyone know this car? (9 replies)
  91. relay (2 replies)
  92. 76 rear "sticker" 914 and 2.0 emblem (1 replies)
  93. Spotted one in Hermosa Beach (5 replies)
  94. 1974 914 (7 replies)
  95. porsche article (0 replies)
  96. 914-6 on The Samba (17 replies)
  97. OT: Birthday Fairy News for 31 Jan 2014 (9 replies)
  98. Rods and wheels 914 spotting (5 replies)
  99. Oil, Oil, Oil (3 replies)
  100. Engine Cleaning (10 replies)
  101. 1.7 SS Heat exchangers (4 replies)
  102. Temporary Engine support (4 replies)
  103. what is that smell ? (4 replies)
  104. Correction... Huey is in Excellence (23 replies)
  105. Buttercup's recent show (23 replies)
  106. 2 Post Lift Positioning (34 replies)
  107. What size trailers are guys using for 914s? (41 replies)
  108. Check those weep holes! (0 replies)
  109. OT: Birthday Fairy News for 30 Jan 2014 (7 replies)
  110. D-Jet vs. Megasquirt? (25 replies)
  111. 1.7 rebuild - recommended upgrades (17 replies)
  112. 3 bolt exhaust flanges (3 replies)
  113. Electronic Ignition - which is best? (8 replies)
  114. Another 914 post in Hooniverse (0 replies)
  115. Removing that dreaded bolt inner end of tie rod (2 replies)
  116. Brake light issue (11 replies)
  117. VDO Head Temp Gage (7 replies)
  118. Road trip (20 replies)
  119. Brakes and a larger motor (10 replies)
  120. Barn find of the century (8 replies)
  121. OT, Is this wheel worth anything? (18 replies)
  122. Looking for a referral (3 replies)
  123. OT: Birthday Fairy News for 29 Jan 2014 (7 replies)
  124. What do you think? (14 replies)
  125. Fuel lines in engine (5 replies)
  126. What's wrong here (20 replies)
  127. More new stuff GB Injector plug rubber covers (12 replies)
  128. Brake and Light Inspection Shop for Porsche in So Cal? (1 replies)
  129. 1:18 scale die-casts of 914 (12 replies)
  130. Hooniverse (9 replies)
  131. Wiring requirements when switching from fuel injection to carbs (12 replies)
  132. Part identification (2 replies)
  133. No Power Captain! (23 replies)
  134. Should I Save Another One ? (19 replies)
  135. Nissan's DIG-T R Engine: 88lbs, 1.5ltr, 3cyl turbo, 400hp (3 replies)
  136. Engine Lids ? (0 replies)
  137. new rear bearing & hubs (13 replies)
  138. Yet another wiper question (6 replies)
  139. need engine bay pic showing rubber seals (3 replies)
  140. Re-done foglight grills that I purchased ? (4 replies)
  141. Wiring issues, can you say smoke. (3 replies)
  142. Points or electronic ignition poll (19 replies)
  143. momo wheel (3 replies)
  144. Fuel tank recondition. (3 replies)
  145. Door problems (3 replies)
  146. Pair of cars 4702905170 & 4722909504 (29 replies)
  147. Megasquirt fuel rails (2 replies)
  148. 295/35-17 tires (1 replies)
  149. Hollywood cruz-in (17 replies)
  150. 914 Scarfs and caps are back (0 replies)
