Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924
  1. One Birthday for 10/17/20 (6 replies)
  2. 6 swap Oil Pressure / Temp Combo Gauge Options? (15 replies)
  3. Removing (8 replies)
  4. Start not disengagin (1 replies)
  5. Headlight Wiring Assistance? (3 replies)
  6. What size sockets for belly pan removal? (3 replies)
  7. Light bulb replacement (14 replies)
  8. Windshield washer system (13 replies)
  9. Where are all of the locations this part can be found. (13 replies)
  10. Sumebore Cylinder Development Underway (15 replies)
  11. /6 oil tank mounting bolt holes? (9 replies)
  12. Birthday News for 10/16/20 (8 replies)
  13. 901/16 old rebuild? (0 replies)
  14. Have you heard of or used PTH racing oil? (15 replies)
  15. Muffler paint: Special or not (4 replies)
  16. Hershey Swap 2021 (9 replies)
  17. Worst nightmare or just fine? (4 replies)
  18. Rubber on rear shock tower is that right? (23 replies)
  19. GB -Thresholds and carpet strips (black in aluminum NOT plastic) (89 replies)
  20. Replacing rear floor pan (4 replies)
  21. Birthday News for 10/15/20 (10 replies)
  22. Ignition switch/turn signal switch questions (6 replies)
  23. Need a new driver's seat (2 replies)
  24. NLA gasket and return fuel line question. (11 replies)
  25. Center console (13 replies)
  26. Delete (0 replies)
  27. What do you want to do with your life? I wanna Blog! (17 replies)
  28. COTM Nominations (42 replies)
  29. Backdating Rear (8 replies)
  30. Flasher/turn signal relay clicks all the time (1 replies)
  31. turbo tie rod wrench (12 replies)
  32. Cool Targa cover (21 replies)
  33. 1973 Fort Worth Auoto Show Pictures (0 replies)
  34. So long BUB's, good riddance (21 replies)
  35. INTEREST IN 914's GROWING? (23 replies)
  36. brake warning chime on all the time - misdiagnosed, starting new thread (5 replies)
  37. Coilovers (14 replies)
  38. pictures heat exchangers glavanized or SS? (11 replies)
  39. Interchange/replacement 2.0 injectors? (7 replies)
  40. Repro bike racks? (5 replies)
  41. How do I get access to the handbrake adjustment rod? (5 replies)
  42. Super strange pop up headlight problem (11 replies)
  43. Winking, Blinking, and Nothing (4 replies)
  44. Help Needed Kansas City,Mo. Xsmn install (0 replies)
  45. WCR (0 replies)
  46. Air Flaps spring (6 replies)
  47. Longer throttle cable for 914 with carbs (16 replies)
  48. 914 Illusion (2 replies)
  49. Need Help (7 replies)
  50. Headlight surround color (2 replies)
  51. Brake hardware (5 replies)
  52. 19K mile car, clutch noise (11 replies)
  53. At the Risk of Becoming "That Guy"...I have another question (8 replies)
  54. Can anyone recommend a 914 mechanic near North Hollywood/Studio City, CA ? (11 replies)
  55. Weidmans loss in Bear fire (2 replies)
  56. heat exchanger pipes (14 replies)
  57. New TPS circuit boards $35 (28 replies)
  58. POC Autocross @ El Toro - 10/11/2020 (3 replies)
  59. Frustrating - No spark from coil to dizzy? (19 replies)
  60. Rekeying the 914 (8 replies)
  61. Paint protection film? (8 replies)
  62. What Brand Oil Cooler Seals? (4 replies)
  63. Gullwing gets some new eyes (22 replies)
  64. TDC - once more with feeling..... (17 replies)
  65. Rear Emblem Questions and Advice (17 replies)
  66. Another GB you can combine stuff together as it's small (1 replies)
  67. Rear Trunk Lid adjustment ? (4 replies)
  68. Porsche air cooled Lego Engine (1 replies)
  69. Thoughts about GT build approach? (22 replies)
  70. Cars in the canyon show (8 replies)
  71. New owner in UK (17 replies)
  72. Electrical issue (0 replies)
  73. A Pile Of Switches (4 replies)
  74. How likely my rear brake line is leaking? (5 replies)
  75. How to clean up a pan o' brake fluid (8 replies)
  76. Birthday News for 10/12/20 5 birthdays including BKLA! (4 replies)
  77. 914-6 Sighting in Rapid City SD (0 replies)
  78. Starting my engine on a stand (54 replies)
  79. Cowl Vent Question (7 replies)
  80. Welder Rx (11 replies)
  81. 1.8 L alternator question (4 replies)
  82. Brake bleeding (34 replies)
  83. What kind of gas are you using? (25 replies)
  84. NY Metro Cruise thru Harriman State Park (11 replies)
  85. idf carbs (4 replies)
  86. Oil cooler size (2 replies)
  87. Flynn's EZ30 & 6 speed Subie conversion (26 replies)
  88. IDF Weber with hex bar - linkage towards front or rear of car? (21 replies)
  89. Eddie Van Halen (23 replies)
  90. Porsche ‘66 911 Boxter motor model available (1 replies)
  91. Auxiliary Air valve wiring tricks? (3 replies)
  92. Windshield sealant (5 replies)
  93. Birthday News for 10/11/20 (5 replies)
  94. 1975 1.8 on twin carbs running poorly (39 replies)
  95. Triad West Exhaust (10 replies)
  96. remote starter switch (8 replies)
  97. Correct finish for a steelie lug bolt (3 replies)
  98. More new stuff correct ski rack straps. Since we are making the whole thing (4 replies)
  99. Where to Source Throttle Cable Bracket (21 replies)
  100. Leak from front of car (17 replies)
  101. State of rust and unknown plastic bit (10 replies)
  102. Sight for sore eyes. (4 replies)
  103. Birthday Party Invites for 10/10/20 (5 replies)
  104. Mittlemotors right inner long (32 replies)
  105. 75 2.0 sittin along time! (9 replies)
  106. Seat ReUpholstery - Step by step (25 replies)
  107. How much can you add to the gizmo on a tail shifter? (2 replies)
  108. Porsche content....$25k, not bad for a "go kart!" (2 replies)
  109. Windshield sealant (3 replies)
  110. TEENERPALÜZA Driving Event - Sept 24-27, 2020 (153 replies)
  111. 914-6 conversion shift rod guidance (8 replies)
  112. Saw a few crown rally guys today (0 replies)
  113. Passenger foot rest board (1 replies)
  114. tires to fit my new empi-fuchs replica wheels (10 replies)
  115. Auxiliary Air Regulator 022 906 045 (6 replies)
  116. What the ventelation control levers in the dash do. (7 replies)
  117. Front lower valance & taillight assemblies (2 replies)
  118. GB tow bar for flat towing $99 Universal Tow bar mounts $25 (86 replies)
  119. Clutch kit (1 replies)
  120. Looking for a Video Star Car in Philly for Friday night (0 replies)
  121. License plate and dash lights on with key on (76 replies)
  122. Horrible scraping noise from rear left. (6 replies)
  123. 911 crankcase (14 replies)
  124. Which engine mounts to best manage NVH on /6? (5 replies)
  125. Replacing clutch and accelerator cable at the same time? (15 replies)
  126. Just One Birthday for 10/8/20 (6 replies)
  127. Ignition issue (8 replies)
  128. Our members and the California fires (11 replies)
  129. rare fully automatic 914 (23 replies)
  130. Specific stock exhaust system recommendations (4 replies)
  131. wiper blade control arm detachment-can anyone provide pictures of how the mechanism connects (19 replies)
  132. Newbie checking in - 73 914 cache (5 replies)
  133. Boxster 6 Speed - Which Clutch Master Cyl bore size? (6 replies)
  134. Front Strut Top Mounting (4 replies)
  135. Clutch cable...is Terry Cable the best? (4 replies)
  136. Birthday News for 10/7/20 (5 replies)
  137. New Relay Board Open Source Design (21 replies)
  138. Fog Light Trim Rings (2 replies)
  139. 1973 Optional Equipment (7 replies)
  140. Sloppy Steering? (3 replies)
  141. Birthday News for 10/6/20 (5 replies)
  142. Fresh Air Blower Motor Gasket? (7 replies)
  143. LS1 Guys: Best, Recent Transaxle Options? (38 replies)
  144. Headlight adjustment screw (5 replies)
  145. O...M...G! 914Rubber hits it out of the park! (12 replies)
  146. Nice looking '76 on BAT (9 replies)
  147. Fuel Pump Relay Electrical (3 replies)
  148. tachs - 914 vs 911 (12 replies)
  149. NPC: rare VW-based coach built Rometsch (9 replies)
  150. Birthday News for 10/5/20 (9 replies)
