Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922
  1. 914 central LLC (50 replies)
  2. How does jack get placed in trunk (7 replies)
  3. Warts (8 replies)
  4. Restoration time (13 replies)
  5. 5 terminal Relay (13 replies)
  6. Crankshaft end play (5 replies)
  7. idle on a 2056 with 9590 cam (30 replies)
  8. Is this a SR17X starter? (2 replies)
  9. OT: Birthday Fairy News for 10 Jun 2014 (7 replies)
  10. turn signal bulb stays on (5 replies)
  11. Fuel pump plug (0 replies)
  12. Bad tank or bad fuel lines? (21 replies)
  13. Question: what oil temps do you see on your non-stock 6? (14 replies)
  14. Can a passenger seat be used on the drivers side? (10 replies)
  15. Blue 914 spotting in Hadley MA. (0 replies)
  16. Slowly back to life (6 replies)
  17. Evil..........bought a TIG (27 replies)
  18. What am I doing wrong? (9 replies)
  19. Polizei 914/6 (30 replies)
  20. OT: Birthday Fairy News for 10 Jun 2014 (9 replies)
  21. jack (4 replies)
  22. Palos Verdes Estates or Rolling Hills Member(s) (6 replies)
  23. Green 914-6 at Cars and Coffee Dallas (6 replies)
  24. CV axle cup washers (5 replies)
  25. Drive ALERT! (18 replies)
  26. GB - late jack strap rubber Finally perfected ! (29 replies)
  27. GB - Valve cover gaskets High temp silicone (18 replies)
  28. GB- Wiper grommets all 4 -$16 will be $26 after the 15th (14 replies)
  29. GB- Doorlight switch gaskets set of 2 Yes the 944 part (17 replies)
  30. New GB OEM style - set of 2 - 9.99+ shipping $16.50 after GB (13 replies)
  31. what grade of gas to use (20 replies)
  32. ugh! (7 replies)
  33. Any local members in Eastern WA (7 replies)
  34. Need referral for buying an outside car cover for my 914. (13 replies)
  35. Adjustment to front hood latch? (4 replies)
  36. thread size for cht (13 replies)
  37. gas in crankcase (6 replies)
  38. Speedometer Drive Block-Off Plug? (9 replies)
  39. CFR fuel line install (16 replies)
  40. targa moulding removal (13 replies)
  41. how tight (8 replies)
  42. OT: Birthday Fairy News for 9 Jun 2014 (9 replies)
  43. Bumpers (14 replies)
  44. OT: Birthday Fairy News for 8 Jun 2014 (12 replies)
  45. 914 Wheel stud question (6 replies)
  46. AAR and High Idle (14 replies)
  47. seating upgrade? (3 replies)
  48. vapor lock or something else? (6 replies)
  49. Red 914 spotted in Carnegie,Pa. (0 replies)
  50. Conflicted. Not sure about this one. (31 replies)
  51. Turn signals not working (1 replies)
  52. Drain hole (3 replies)
  53. Jake's forum now on facebook? (4 replies)
  54. Weird issue with shifting (11 replies)
  55. Headlights opening (9 replies)
  56. Air Filter Box Latch (0 replies)
  57. removing front bumper 1973 (4 replies)
  58. Do I really need it - long stiffening kit (20 replies)
  59. Overheating brakes...very exciting (2 replies)
  60. Anyone in Indiana, Lake Station, Merrillville, Portage area? (4 replies)
  61. Does this front rotor to caliper clearance look right? (11 replies)
  62. OT: Birthday Fairy News for 7 Jun 2014 (7 replies)
  63. Do unicorns exist? (22 replies)
  64. Speedo Cable (5 replies)
  65. So whats this number (2 replies)
  66. 914-6 vs early 911 struts, and difference ? (7 replies)
  67. Transaxle stack replacement? (9 replies)
  68. Aligning the rear trunk lid (3 replies)
  69. AF meter how do i go about reading this. (17 replies)
  70. Good cars for good prices (19 replies)
  71. Brake fittings / size / DIN ? (6 replies)
  72. Subie cooling leak (0 replies)
  73. 914 Starter upgrade (22 replies)
  74. Wipers and horn quit working together (6 replies)
  75. Newbie resurrecting a 914: I have questions. (23 replies)
  76. OT: Birthday Fairy News for 6 Jun 2014 (8 replies)
  77. New part Rear targa seal like OEM WITH FUZZIE ! NO SQUEEKS (115 replies)
  78. Subie 6MT trans (2 replies)
  79. steering wheel wobble (13 replies)
  80. dash front refurb (2 replies)
  81. Does anyone know this 914 ? (22 replies)
  82. Starting Issues (8 replies)
  83. Silicone heater hose VS Gates green Stripe - Renegade 914 (5 replies)
  84. 3 port fuel pump (7 replies)
  85. Help a new PCA member (7 replies)
  86. Fire extinguishers (19 replies)
  87. Hey Chicago wanna help out? (3 replies)
  88. Steering (13 replies)
  89. trunk repair panel (4 replies)
  90. Cool Car Came in the Shop Today... (27 replies)
  91. Porsche Parade in Monterey (17 replies)
  92. OT: Birthday Fairy News for 5 Jun 2014 (8 replies)
  93. Ideas for non-stock parts that work really well. (2 replies)
  94. need help oil cooler (4 replies)
  95. Approx. cost to convert from tail to side shift? (18 replies)
  96. Tail shift Cable-shifter (40 replies)
  97. mystery engine tin piece (2 replies)
  98. 914 side shifter rear cup replacement (8 replies)
  99. Automotion door handles (9 replies)
  100. Bruce and Wes (4 replies)
  101. Turbo Tie Rods (1 replies)
  102. IROC BUMPER (5 replies)
  103. Tail lights to car body gasket (5 replies)
  104. Porsche Car Show in Dana Point, CA (28 replies)
  105. T-Shirts (0 replies)
  106. I friggen love this car (ie.. new member intro) (24 replies)
  107. Ducktail (24 replies)
  108. Problems with 914 2.0 ignition (15 replies)
  109. OT: Birthday Fairy News for 4 Jun 2014 (8 replies)
  110. Fog Light Fuse Question (9 replies)
  111. OT_Subaru conversion guys look at this. (19 replies)
  112. What muffler is this? (11 replies)
  113. First Engine Start Questions (26 replies)
  114. Transmission output shaft will not come out (4 replies)
  115. GB- Rear Sway bar bushings set of 2 - $12.99 $19.99 after (9 replies)
  116. Going to Drop the Engine (8 replies)
  117. Parts Heaven swap meet and show (27 replies)
  118. anyone know this one? (16 replies)
  119. 5 lug conversion (11 replies)
  120. Is the yellow wire on my starter in the correct spot? (5 replies)
  121. No power to coil (14 replies)
  122. high Idle (6 replies)
  123. Restoration or Porscharu (15 replies)
  124. OT: Birthday Fairy News for 3 Jun 2014 (9 replies)
  125. Fresh Air Control - elec connections? (4 replies)
  126. Fittings on Vellios oil tank oil filter (1 replies)
  127. Brad Penn 10-30 vs 20-50 (14 replies)
  128. 914 Sighting Center Conway NH (7 replies)
  129. How to heat seats not Porsche.... (16 replies)
  130. Back in the saddle again (13 replies)
  131. Handy product for your glovebox or tool kit (2 replies)
  132. so sick of that GD fluxcore! (8 replies)
  133. N. Cascade Hwy 20 WA state (2 replies)
  134. Gone to the dark side (16 replies)
  135. EvilWerks T shirts! (37 replies)
  136. 914 2.0 on Wheeler Dealers Wednesday at 3pm central on the Velocity channel (2 replies)
  137. Weltmeister short shift question (26 replies)
  138. Ignition switch (3 replies)
  139. Pomona Swap Meet on Sunday June 1st! (8 replies)
  140. Hey George (15 replies)
  141. Spring run of my 917 shifter knobs (57 replies)
  142. OT: Birthday Fairy News for 2 Jun 2014 (10 replies)
  143. EBrake Project Help (7 replies)
  144. Guinness World Record (8 replies)
  145. Where can i find a female connector for this temperature sender? (1 replies)
  146. Nice 914 HP/Torque Graph (7 replies)
  147. Re: Beugler pin striping tool. (0 replies)
  148. Hard top (1 replies)
  149. Adding A/C & Cruise control to my Suby conversion. (5 replies)
  150. I need a carb fuel pump, with threaded ends (5 replies)
