Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922
  1. Rear Springs (1 replies)
  2. Wheel size selection (9 replies)
  3. Want to Borrow: KONI gland nut spanner wrench (2 replies)
  4. High idle when cold then just about right (3 replies)
  5. 12 Volt Heater (9 replies)
  6. Exactly which vacuum lines do I need? (7 replies)
  7. wheel restoration... (5 replies)
  8. Fuse keeps blowing~ (7 replies)
  9. Garbage? or Not? (5 replies)
  10. 205-65-15 on stock wheels (10 replies)
  11. Wiring Help (3 replies)
  12. Out with the old, in with the older (17 replies)
  13. Mystery Part (8 replies)
  14. thought that some of you 914 folk might like this pic that i took (7 replies)
  15. Anybody recognize this 914? (12 replies)
  16. White 914 on trailer spotted in MN heading east on 94 (0 replies)
  17. more fun @ bremerton motor sports park (10 replies)
  18. Questions about fluids. (4 replies)
  19. Red Fuse on Relay Board (10 replies)
  20. corner balancing (4 replies)
  21. What have you done to your fan housing? (29 replies)
  22. Weltmiester Rear Sway Bar Pictures or (7 replies)
  23. Idle knob on ECU (5 replies)
  24. R/C car bodies (1/24 scale?) (0 replies)
  25. driver side rear wheel is hard to rotate (2 replies)
  26. Riviera Wheel offset ?'s (3 replies)
  27. refinshing the spokes on the stock steering wheel (9 replies)
  28. Are there any smaller/lighter batteries? (15 replies)
  29. OT Going to see that lil ol band from Texas (15 replies)
  30. OT: Waiting for things to turn UP in '07! (11 replies)
  31. Black 914 spotted on car haluler (0 replies)
  32. OT: Birthday Fairy Report for 29 OCT 07 (0 replies)
  33. James Kelly PM please (0 replies)
  34. patrick motorsports header (2 replies)
  35. SOT: So who is going to do this for our little cars? (1 replies)
  36. Moved: OT: Your Best One-liner! (-- replies)
  37. Relay Board (10 replies)
  38. cooling (3 replies)
  39. looking for pics of the Bob Zulkowski IMSA GT (3 replies)
  40. OT: Hung out with Chuck Beck and son Randy... (25 replies)
  41. Horsepower and Torque. (9 replies)
  42. Reinforcements (3 replies)
  43. ot npc another ferrari story (1 replies)
  44. the good or bad skinny on DEVES rings (7 replies)
  45. Carbs and Emissions. I failed, high HC (18 replies)
  46. a weber problem. one carb only (8 replies)
  47. fuel regulator for single line carb setup question (1 replies)
  48. should I use undercoating? (6 replies)
  49. OT: Birthday Fairy Report for 28 Oct 07 (1 replies)
  50. Damn, hit a deer this morning (28 replies)
  51. Breakfast moves to lunch! (23 replies)
  52. Studs & lug nuts for steel wheels? (6 replies)
  53. Got rear-ended... (17 replies)
  54. Anybody Want A Ferrari 914? (19 replies)
  55. 914-6 George Vellios oil tank capacity ? (8 replies)
  56. XL fuel lines between tank and body...? (3 replies)
  57. Dual carb accelerator cable and spring (3 replies)
  58. Roll Bar Pad Removal (8 replies)
  59. How far can I tear down my Dellortos... (2 replies)
  60. UPDATE, MRD SoCal gathering and barbeque (how do you spell that?) (19 replies)
  61. Planning for the winter (1 replies)
  62. Dog tooth puller...got one? (8 replies)
  63. OT: question for the computer network gurus ... (29 replies)
  64. Thermostat Cable Adjustment (4 replies)
  65. New project, door gap, rear camber (15 replies)
  66. Ground Breaking (3 replies)
  67. OT: Birthday Fairy Report for 27 Oct 07 (2 replies)
  68. Tire size for stock steelies? Staggered? (16 replies)
  69. carbs (1 replies)
  70. Top restoration products/tools... (2 replies)
  71. OT - 61 356B Super 90, your thoughts (17 replies)
  72. I wonder if we could persuade these guys to do a 914? (7 replies)
  73. Okay, now i'm confused (18 replies)
  74. Source for injector(s) locally? (8 replies)
  75. Pedrini vs Fuchs (10 replies)
  76. Engine Removal Check List - Tech Article (4 replies)
  77. Two broken windshields...third time a charm? (17 replies)
  78. Engine Assy; Copper Gasket Between Head & Cylinder? (15 replies)
  79. What should be replaced this winter? (2 replies)
  80. Rebuilt Fuel Pump (9 replies)
  81. SoCal fires and 914 folks (8 replies)
  82. Window seals (1 replies)
  83. Starting issues. (15 replies)
  84. performance engine parts vendors (12 replies)
  85. CANT ALIGN PASSENGER DOOR. (38 replies)
  86. looking for photos of willow green wide body 914-6 (11 replies)
  87. 914 Won't Start (14 replies)
  88. OT: Birthday Fairy News for 26 Oct 07 (1 replies)
  89. my first drive! and... (8 replies)
  90. 96mm MAHLE piston markings (6 replies)
  91. San Antonio/Nearby Get-together? (5 replies)
  92. Brad Penn Retailers in Portland, OR and Vancouver, WA (1 replies)
  93. guage question (1 replies)
  94. Best Spark Plugs for Carburated 914? (5 replies)
  95. The Sterling Meet thread (138 replies)
  96. Wheel Spacers (7 replies)
  97. what would make my bursch fail (12 replies)
  98. OT: Birthday Fairy Big news for 25 Oct 07 (8 replies)
  99. MN/WIS (3 replies)
  100. Anyone in Everett WA able to do a PPI? (0 replies)
  101. Possible rust inhibitor product? (0 replies)
  102. Need your beater 5 lug loaner wheels (3 replies)
  103. New 914 owner =] (16 replies)
  104. Engine cooling flaps and thermostat (21 replies)
  105. headlights question (6 replies)
  106. Antenna Hole (9 replies)
  107. Fastners for rear logo (3 replies)
  108. OT: How hard to change head gaskets on a Subaru? (15 replies)
  109. Any shop in Orange County that can do a GOOD 4 wheel alignment on a 91 (4 replies)
  110. This weeks projects (15 replies)
  111. San Diego is Burning (52 replies)
  112. Halflife 2 Episode 2 Help? (3 replies)
  113. valve adjustment photo (0 replies)
  114. SSI heat Exchangers (19 replies)
  115. window adjustment (2 replies)
  116. turn signal issue (2 replies)
  117. Best way to weld side marker lights closed? (7 replies)
  118. GT Question (5 replies)
  119. Engine Assy Questions - P&C's Alignment (8 replies)
  120. WOT: mold making (14 replies)
  121. Best book on 914 fuel injection? (13 replies)
  122. Sudden Cruz Control? (4 replies)
  123. Rocker Spacer Install Question (1 replies)
  124. Bremerton Motorsports Park (7 replies)
  125. OT: Birthday Fairy Report for 24 Oct 07 (2 replies)
  126. SDS on a stock engine? (8 replies)
  127. Water in oil (9 replies)
  128. Our cars on CNN (4 replies)
  129. Calling Dr Evil.... have a tail shifter floating around? (0 replies)
  130. Are we being hijacked? (27 replies)
  131. New V8 guy with questions of course (16 replies)
  132. I want to start upgrading the suspension on my stock 2.0 (12 replies)
  133. Fire Fundraiser for the San Berdoo Crew (0 replies)
  134. Alternator question (6 replies)
  135. Oil strainer (10 replies)
  136. Welders: If you had to choose one...? (26 replies)
  137. OT: Rob Turned 50 Today! (7 replies)
  138. Engman kit Picture / installed (4 replies)
  139. alms (20 replies)
  140. bumper tops (8 replies)
  141. Heater hoses (15 replies)
  142. ram air (21 replies)
  143. new life for old piping (14 replies)
  144. Clutch vibration/noise... (2 replies)
  145. 914/6 conversion muffler what to use? (11 replies)
  146. Where are all the project threads? (37 replies)
  147. OT: Emissions test, non Porsche content (5 replies)
  148. OT: Birthday Fairy News for 23 Oct 07 (1 replies)
  149. Hey Bill Berthgo, gotta question for ya! (10 replies)
  150. OT: Penalized for "Power To Pass"? (5 replies)
