Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924, 925, 926, 927
  1. Printing out Forums (4 replies)
  2. Dinner with John Kelly and his protege's? (6 replies)
  3. Replacing rear panel (3 replies)
  4. OT: Energy Saving R40-type Flood Lights (1 replies)
  5. 1976 Front panel (13 replies)
  6. v8 914 with whale tail (18 replies)
  7. Center Tunnel Delete? (3 replies)
  8. Holy moly (0 replies)
  9. need help with ideas for install (4 replies)
  10. 944 turbo calipers (3 replies)
  11. So my alternator dash light lights up… (14 replies)
  12. haven't tried this before (31 replies)
  13. How much can front Koni spots be compressed? (9 replies)
  14. Does 'Z' have a brother?? (5 replies)
  15. AX under the lights (6 replies)
  16. Red Neck Racer Takes TTOD (9 replies)
  17. Igition Help - 6 conversion (6 replies)
  18. To do a TER or not to do a TER (16 replies)
  19. looking for a 1218 tester (6 replies)
  20. 1.7L Throttle Return Spring Placement (8 replies)
  21. Oil Lines.. (12 replies)
  22. OT When do you let a car go? (17 replies)
  23. This is what a $250 914 in Florida (48 replies)
  24. Steering wheel measurment (4 replies)
  25. Difference between these hubs? (9 replies)
  26. I need a back up light switch (3 replies)
  27. Car show at oxford july 30th (0 replies)
  28. 2005 ACC Concours d' Elegance (22 replies)
  29. Reverse Light Switch Connector (4 replies)
  30. Time to yank the D-Jet? (46 replies)
  31. I found the 914-6 PICKUP!!!! (36 replies)
  32. Maiden Voyage...... (8 replies)
  33. OT: Web Guru’s….dreamweaver (2 replies)
  34. Note to admin(s) (8 replies)
  35. somebody help me...i'm so close! (20 replies)
  36. How to stop corrosion in Magnesium?? (2 replies)
  37. OK.. Here's your chance to get a pair of 8"X 10" (10 replies)
  38. more help needed (6 replies)
  39. OK (10 replies)
  40. WOT: Going to See Kraftwerk tonight (20 replies)
  41. 7:27 R&P gear (42 replies)
  42. 944 Flag mirrors on a 914 (5 replies)
  43. Front suspension rides rough (18 replies)
  44. pats 914 project (29 replies)
  45. funny heard at the a/x (2 replies)
  46. The Alfred story (23 replies)
  47. LOST MY ONLY KEY (12 replies)
  48. OT (30 replies)
  49. Another Weber Question (10 replies)
  50. UPS Morons (14 replies)
  51. calling all computer geeks (3 replies)
  52. getting the door gap right (4 replies)
  53. 914 sighting in VA (4 replies)
  54. OT: but pretty damn cool (24 replies)
  55. thinking of having my wheels reconditioned. (7 replies)
  56. Trans-am invitational vintage race (62 replies)
  57. EASY 's phone number? (6 replies)
  58. 914 is back on the road (3 replies)
  59. Bay Area media blasting (4 replies)
  60. "Rust"oration (2 replies)
  61. Well for those who didn't believe in me (58 replies)
  62. Scam??? (7 replies)
  63. odometer/trip meter cable connection. (4 replies)
  64. teener down w/ emerg surg (2 replies)
  65. Part and car opportunity (2 replies)
  66. Spindle clamping nuts (4 replies)
  67. the best and least damaging way to strip bodypaint (6 replies)
  68. Source for oil thermostat for 2.7/6? (2 replies)
  69. OT: The Beaver Needs A New Carburator! (0 replies)
  70. V8 engine question (17 replies)
  71. Right Hand Drive? (11 replies)
  72. VIN number information (3 replies)
  73. brake fluid (j 1703)? (3 replies)
  74. brake fluid (1 replies)
  75. Pulled my first gear stack!!! (5 replies)
  76. Backpad Restoration (1 replies)
  77. SCCA uto-X at Mather (Sacramento) on June 11 (19 replies)
  78. Hayward PartsHeaven Swap Meet and Concourse (43 replies)
  79. Thanks James! (1 replies)
  80. Headlight problem (16 replies)
  81. Liquid cooled heads--Now on sale! (7 replies)
  82. Picture this... for v8 guys... (4 replies)
  83. Puppy pics.... (41 replies)
  84. TYPE4PARTS PROGRAMABLE FUEL INJECTION (130 replies)
  85. Original radio and speakers ? (23 replies)
  86. Weber IDF question (14 replies)
  87. Rotisserie plans? (5 replies)
  88. Reverse light switch (5 replies)
  89. OT..shorty VW bus on the samba (4 replies)
  90. Custom Exhaust Gasket (2 replies)
  91. This weekend's hard lesson learned (6 replies)
  92. Parts Heaven seller with the 993 used rims (1 replies)
  93. cigarette lighter (1 replies)
  94. SPT: (Some Porsche Content) (11 replies)
  95. 7 birthdays! (3 replies)
  96. OT: Is this a good deal on a used GT40? (17 replies)
  97. type one engine question (5 replies)
  98. OT making a life changing desicion (10 replies)
  99. distributor question (9 replies)
  100. Getting there. (15 replies)
  101. Went by Auto Atlanta today. Awesome. (24 replies)
  102. A smiley for Miles (20 replies)
  103. Clutch cable replacement... (2 replies)
  104. Classic Symptoms (12 replies)
  105. GET WELL SOON BOB (16 replies)
  106. 928 guys,help (26 replies)
  107. Side window rattle rattle (3 replies)
  108. i have no thermostat (1 replies)
  109. how to remove paint overspray (29 replies)
  110. another 914 drove by (10 replies)
  111. OT: Looking for a new cell phone (10 replies)
  112. What are these? (10 replies)
  113. OT: Watkins Glen Club Race (17 replies)
  114. Alternative A/C (3 replies)
  115. finally got a 914 (15 replies)
  116. Minor rust repair. (2 replies)
  117. Original radio worth anything? (16 replies)
  118. questions about upgrades.... (5 replies)
  119. Seattle Road Race.. (6 replies)
  120. Other mechanics in Atlanta (2 replies)
  121. other side of the coin (27 replies)
  122. Transaxle (transmission) Mount Suggestions (2 replies)
  123. 1st Drive in my SIX (36 replies)
  124. More new RennShift pics (44 replies)
  125. HELP Wiring/turn signal issue! (14 replies)
  126. Carburetor Suggestions (18 replies)
  127. OT- Happy Birthday (12 replies)
  128. AUDI (6 replies)
  129. found! (5 replies)
  130. another layer off the onion (130 replies)
  131. i am so damn pissed (34 replies)
  132. random pan questions (4 replies)
  133. Access to the 75 ignition switch, (7 replies)
  134. Server is dying ... (16 replies)
  135. SoCal Dinner in Buena Park, CA (24 replies)
  136. Low idle and stalling (2 replies)
  137. YIPEE (10 replies)
  138. v8 radiator hose routing (4 replies)
  139. OT: Swamp Buggy (2 replies)
  140. On TV: preparing a mini for the track (6 replies)
  141. So I bought a 914 and I went by Gunnar today (21 replies)
  142. "The Driver" (1 replies)
  143. How do I take out the seats in my 914? (5 replies)
  144. 73 911 oil tank (13 replies)
  145. Body Shutz Gun to lend?? (8 replies)
  146. DUMB question (12 replies)
  147. Odometer slightly out of synch. (7 replies)
  148. Rear springs ID (8 replies)
  149. Sunday! Sunday! Parts Heaven! (19 replies)
  150. My first 'Big' trip in the 914... (34 replies)
