Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924, 925
  1. Fuch electical! (25 replies)
  2. Late to Early Headlight Switch (2 replies)
  3. HELP ! (5 replies)
  4. What Compression Ratio to use. (2 replies)
  5. converting to carbs what to do with the fi return line. (13 replies)
  6. Installing the (1 replies)
  7. ISO link for zerk install trailing arms (28 replies)
  8. I need a radiator for my SBC conversion (44 replies)
  9. OT: Birthday Fairy News for 12 Sept 2014 (7 replies)
  10. How difficult and expensive to convert from Carbs to FI (5 replies)
  11. does anyone on forum own a 911? (70 replies)
  12. Update 09/12/14 - In Production: (25 replies)
  13. Southern California drive on 9-14! (12 replies)
  14. Swaybar Bushings…. (7 replies)
  15. Intro and WTB (2 replies)
  16. Happy Birthday 914! (20 replies)
  17. How Do You Re-Attach the Rear Trunk Torsion Bars (16 replies)
  18. 914 vs 911 (1 replies)
  19. Fresh air blower (1 replies)
  20. Did i get some bad gas? (10 replies)
  21. Never Forget (1 replies)
  22. fuel-starting issues- carbs... (2 replies)
  23. Front air blower (8 replies)
  24. how much force needed to install roll pin into CV Joint? (4 replies)
  25. PCA 914 Register Advocate (47 replies)
  26. Headers or Heat Exchangers (7 replies)
  27. Clutch Cable (0 replies)
  28. 914-6 engine compartment (3 replies)
  29. Toe setting on rear wheels (2 replies)
  30. value of a side shift trans with Quaife LSD (13 replies)
  31. Targa top painting (2 replies)
  32. Poly-Graphite Control Arm & Rear Trailing Arm Bushings (9 replies)
  33. OT: Birthday Fairy News for 11 Sept 2014 (8 replies)
  34. clutch cable (5 replies)
  35. AZ caravan to RRC (16 replies)
  36. odd wear marks on flywheel (14 replies)
  37. to the british members - what happend to DDK ...? (9 replies)
  38. looking for a car ramp (6 replies)
  39. Need Buying advice - 1971 914 (27 replies)
  40. Running too rich! (14 replies)
  41. Lizard skin (14 replies)
  42. Crankshaft endplay (5 replies)
  43. Keith Black Piston to Cylinder Clearance. (3 replies)
  44. Off to a great start (19 replies)
  45. So check out my ride almost complete! (29 replies)
  46. Targa Latch handles (7 replies)
  47. 3200 miles, 1975 914 (28 replies)
  48. rear trunk torsion springs suck (30 replies)
  49. Long time 914 owner and fan, here are some 914s East Coast (11 replies)
  50. Horn wire help (5 replies)
  51. Re-doing the interior (4 replies)
  52. Bonehead Move Of The Month Award (6 replies)
  53. OT: Is The Site Font Getting Smaller? (14 replies)
  54. purchasing a 2.7 for the 1.7 (12 replies)
  55. Looking for Engine Nunber 6414127? (0 replies)
  56. OT: Birthday Fairy News for 10 Sept 2014 (7 replies)
  57. Windshield Replacement (19 replies)
  58. New car oil spec (6 replies)
  59. WOT: burned out 1940 dodge truck, what front suspension? (3 replies)
  60. Front Center Engine Mount Bolts (1 replies)
  61. 914/6 Wins at SCCA Solo National (8 replies)
  62. sited in Medford Oregon (16 replies)
  63. Defrost fan won't turn off (9 replies)
  64. Sun visor rebuild group buy need to do 20 sets (217 replies)
  65. Brake fluid flush (13 replies)
  66. relay plate covers (1 replies)
  67. OT: Birthday Fairy News for 9 Sept 2014 (13 replies)
  68. Threading on Bosch 69133 Fuel pump (1 replies)
  69. Never heard of this - Tail of the Dragon Boxer Takeover (0 replies)
  70. Anybody looking for their door? (7 replies)
  71. Porsche 914 french club event (24 replies)
  72. Cam Gear (-2) (9 replies)
  73. OT: Birthday Fairy News for 8 Sept 2014 (9 replies)
  74. She likes it.... (11 replies)
  75. blinker gremlin (4 replies)
  76. Cover your glass! (2 replies)
  77. Mom of Mom's service covers is 86 today (29 replies)
  78. 1st PCA concours event Saturday (10 replies)
  79. Help for Maroons (6 replies)
  80. running rough (6 replies)
  81. Argh.... transmission (19 replies)
  82. Alternator replacement recommendations for overloaded /4 (5 replies)
  83. Shudder when moving off in 1st (4 replies)
  84. For JRust (4 replies)
  85. Tranny experts. Help! (6 replies)
  86. Dash (3 replies)
  87. Starting Issue: only starts when clutch pedal is mashed to the floor (16 replies)
  88. Classic air cooled Porsche Classics today (1 replies)
  89. Wild AZ 914 (15 replies)
  90. OT: Birthday Fairy News for 7 Sept 2014 (7 replies)
  91. Anyone free in the Sacramento area today (0 replies)
  92. Mystery Hardware (3 replies)
  93. My 914 was accepted for display at Porsche Timeline Exhibition and Show (16 replies)
  94. 2.6 fat twin plug motor? (11 replies)
  95. Dawn Patrol Run/BBQ - Finally - Sat Sept 6 (29 replies)
  96. Rear Control arm outside console (driver's side) (3 replies)
  97. Caliper Suggestions for 5 Lug System (10 replies)
  98. Long Time 914 Suppporter Mechanic needs Moral Support (52 replies)
  99. OT: Birthday Fairy News for 6 Sept 2014 (8 replies)
  100. Correct Hell Hole Repair Panel (7 replies)
  101. Raby powered 914 (19 replies)
  102. I love old ads ! (5 replies)
  103. Are all Orgnial Starters the Same? (2 replies)
  104. what 914 parts are you thinking of putting in trash? (31 replies)
  105. drd racing heads (18 replies)
  106. Does it get modern music? (13 replies)
  107. Endplay (11 replies)
  108. Nice ready to race 914 showed up on Craigslist today (10 replies)
  109. Electrical Gremlins - Fuse 8 fried (6 replies)
  110. OT: Birthday Fairy News for 5 Sept 2014 (8 replies)
  111. Oil leak woes (21 replies)
  112. Someone in my neighborhood just got a 914 (11 replies)
  113. 914next (16 replies)
  114. lifter question (4 replies)
  115. How many 914s remain? (6 replies)
  116. row52.com alert (1 replies)
  117. Turning a modified 914-6 back close to original (29 replies)
  118. GB: 914 Poster Art - 2 Posters Available (17 replies)
  119. MPS Adjustment (11 replies)
  120. 914 Engine Balancing. Where to go. (4 replies)
  121. Now that is an awesome 914 race car (10 replies)
  122. Vertical Stabilizer (6 replies)
  123. Louvered long porsche 914? (13 replies)
  124. Body In White (16 replies)
  125. My 914 sketch (artwork) (10 replies)
  126. Are all fresh air intake boxes the same? (6 replies)
  127. 'Nuther sighting... (1 replies)
  128. "Winking Headlight" (9 replies)
  129. Inherited a couple 914's looking for insight-Pictures posted (36 replies)
  130. OT: Birthday Fairy News for 4 Sept 2014 (10 replies)
  131. PNW and Western Canada Transmission Clinic, how about Aug? (278 replies)
  132. Remote electric water pump (13 replies)
  133. next (6 replies)
  134. Time for a New Starter? (2 replies)
  135. One side of the engine cooler than the other (8 replies)
  136. Another Non starting issue. (1 replies)
  137. Pertronix doesn't work after engine rebuild... (6 replies)
  138. Questions? 3.6 Subaru in 914 (14 replies)
  139. Transmission Linkage Issues? (21 replies)
  140. Muffler shield (10 replies)
  141. OT: Birthday Fairy News for 3 Sept 2014 (9 replies)
  142. a covered 914 in Cincinnati.... (7 replies)
  143. Lime Rock Historics (13 replies)
  144. Where does this wire go? (10 replies)
  145. 1.8 fuel injected engine weight? (1 replies)
  146. Putting it back together (5 replies)
  147. Question for the MegaSquirt crowd (2 replies)
  148. What amount shall I sell my 914 ? (21 replies)
  149. Selling my 914, it's a good thing (3 replies)
  150. 914 t-shirts! (94 replies)
