Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922
  1. Centre / gauge console unit fit and wiring (9 replies)
  2. Brake calliper ID (12 replies)
  3. Trunk rear floor (10 replies)
  4. Cylinder to head sealing ring (2 replies)
  5. Off topic , ,,,, generators , hitch racks and tounge weight (0 replies)
  6. Some rust and welder experiment (0 replies)
  7. DPD - AC Unit Relay (4 replies)
  8. Adjustable pushrod for measuring (9 replies)
  9. Head temps VS oil temps and cooling (2 replies)
  10. 914 Car Buying Advice (32 replies)
  11. New to me 914. 74. 1.8 (10 replies)
  12. Cabin Electrical connections (17 replies)
  13. Sway Bar Bushings (13 replies)
  14. 914/6 on german ebay (9 replies)
  15. How to check that a crank and cam shaft are good to use? (7 replies)
  16. Car Cover Source? (6 replies)
  17. ISO experience with cableshift.com (23 replies)
  18. Front Sway Bar fitting (3 replies)
  19. Alternator issue- maybe... (8 replies)
  20. Missing trim piece, could you show me what I need please (11 replies)
  21. Birthday News for 6/17/20 (7 replies)
  22. compression ratio question (0 replies)
  23. Top Secret 914 Project! (32 replies)
  24. Possible bad fuel pump (15 replies)
  25. Steering wheel spline sizes (5 replies)
  26. How to wire fuel pump? Carb conversion (9 replies)
  27. Does something fit under the targa roof panel? (4 replies)
  28. Targa Top to Window Top Seal (2 replies)
  29. Things heating up (5 replies)
  30. TPS variations - has anyone else noticed this ? (20 replies)
  31. Need some door window trim details (2 replies)
  32. Help on 76 (8 replies)
  33. Birthday News for 6/16/20 (9 replies)
  34. Tie rod removal. (5 replies)
  35. After Market Blinker switch experience? (5 replies)
  36. New to the 914 world (21 replies)
  37. Relay board (4 replies)
  38. Rear spring rate of 52# per inch = what exactly? (4 replies)
  39. A "stockish" 914-6 languishing on Ebay (15 replies)
  40. Fifty years ago today, in France... (17 replies)
  41. Stripped threads on shift coupling (7 replies)
  42. Piston Rings (1 replies)
  43. 914 -6 : Brain Trust ? (11 replies)
  44. Maybe A Quick Fix For Worn Out Turn Signal (0 replies)
  45. YourFavorite Porsche Commercial-You Tube (10 replies)
  46. Door threshold (2 replies)
  47. Traveling (12 replies)
  48. new 50th anniversary 914 restorers guide to authenticity (4 replies)
  49. 914 6 trans numbers (4 replies)
  50. R&R Window Regulators ? (8 replies)
  51. More new stuff on the way.Seat uhplostery tabs (6 replies)
  52. Birthday News for 6/15/20 (3 replies)
  53. WANTED: Floor Mat Template (1 replies)
  54. Bondo Bill Built - 914 Station Wagon (22 replies)
  55. -6 Rear Caliper Option ? (4 replies)
  56. bumblebee in a box (2 replies)
  57. Rear stub axle question (10 replies)
  58. Need an underside picture of 1.7 heat components (4 replies)
  59. Bumper Repair (5 replies)
  60. 914-6 build date (4 replies)
  61. Stock 914/6 aircleaner ? (8 replies)
  62. Bumper Issue (15 replies)
  63. 914s in Denver (1 replies)
  64. Clutch cable bushing (9 replies)
  65. Northern 914 Introduction (13 replies)
  66. Harbor Freight jackstands recalled! (33 replies)
  67. 1971 Porsche 914 1.7 liter (7 replies)
  68. nine one "faux" six GT gauges (19 replies)
  69. Birthday News for 6/14/20 (3 replies)
  70. /6 Rear Caliper Bleeder Location (2 replies)
  71. PDX teeners - Event ! SAT JUNE 13th $30 road rally (14 replies)
  72. My First 914WORLD So Cal Rally (25 replies)
  73. Never mind (0 replies)
  74. 914-6 conversion for sale on the Bird (0 replies)
  75. Installed my 914rubber Dash today (4 replies)
  76. Rear trunk lid foam (28 replies)
  77. Another Miss On Reproduction Horn Contact Ring (4 replies)
  78. turn signal switch (1 replies)
  79. heater control unit wiring and cables (0 replies)
  80. What goes on this connection (7 replies)
  81. Led Bulbs for Fog Lights (42 replies)
  82. Birthday News for 6/13/20 (5 replies)
  83. International 914 Meet (94 replies)
  84. CV boot hard to change out? (2 replies)
  85. 1.8 Fuel Injection (8 replies)
  86. Using Lucas Oil 10278 Engine Oil Stop Leak (3 replies)
  87. P2O in Ohio - Anybody planning to go? (2 replies)
  88. Transmission Knock (10 replies)
  89. LED Headlight weirdness (17 replies)
  90. Gas pedal mount rusted (18 replies)
  91. Abandoned 914 (20 replies)
  92. Dealer AC wiring (2 replies)
  93. 1973 2.0 fs - PPI ? (29 replies)
  94. Under the body swaybar w/911 front suspension (21 replies)
  95. Pipe from the bottom of the air box (2 replies)
  96. All Bearings NOT Created Equal (15 replies)
  97. Recommendations (37 replies)
  98. Birthday News for 6/12/20 (8 replies)
  99. New master cylinder (6 replies)
  100. Bosch 050 Distributor parts (6 replies)
  101. What's this hose for? (9 replies)
  102. new product (7 replies)
  103. relay board help (9 replies)
  104. Removing pedal board driver's side '73 2.0 (7 replies)
  105. 924 'Tarantula' wheels on a 914 .. (4 replies)
  106. Turbo Tie Rod (15 replies)
  107. More Porsche? WTF, haven't seen this one before (9 replies)
  108. Hans Mezger (19 replies)
  109. What year is the wiring harness? (25 replies)
  110. What’s the deal with the @ symbol followed by member’s title (12 replies)
  111. Fuel Pump/ Vacuum hose questions (2 replies)
  112. 914s get some love (5 replies)
  113. Birthday News for 6/11/20 (5 replies)
  114. Some OT: have plasma table and will cut (1 replies)
  115. Front wheel bearings... (16 replies)
  116. Birthday News for 6/10/20 (7 replies)
  117. Another what is this question (5 replies)
  118. Better panel clamps for butt welding (19 replies)
  119. resurrection (9 replies)
  120. Has anyone heard from aircooledtechguy (Nate Morse) (26 replies)
  121. Visit to Porsche Mecca (20 replies)
  122. Did Lemforder Get Bought Out ? (2 replies)
  123. High speed vibration (6 replies)
  124. Cold Compression test 2.0 (8 replies)
  125. 914/6 Maintenance Record - 1970 - 1323 (4 replies)
  126. Rear trunk floor (10 replies)
  127. Save or toss - spare oil coolers (1 replies)
  128. How To Make a Lighted Combo / Fuel Gauge (0 replies)
  129. clutch cable check (0 replies)
  130. High Pitch sound. Speed related, not RPM (24 replies)
  131. Tires and tires (18 replies)
  132. 914/6 Column Wiring (11 replies)
  133. PartyStarter (13 replies)
  134. Wiper Crank Assembly Refurb (8 replies)
  135. Birthday News for 6/9/20 (5 replies)
  136. Fuel Tank, Hole size & Bolt Pattern? (6 replies)
  137. Speedo angle drive, do they go bad? (12 replies)
  138. Best grease for seat tracks (9 replies)
  139. Differential Cover on Early Transmission (9 replies)
  140. Bolt (13 replies)
  141. Gas pedal mount rusted (0 replies)
  142. 914 with 95 Camaro Body? (19 replies)
  143. Rare Shades 5: Toronto (12 replies)
  144. Factory 914-6 engine mount clearance issue? (24 replies)
  145. not another warning thread of buyer beware on 914 world (0 replies)
  146. Why are 1975/1976 heat exchangers considered undesirable? (9 replies)
  147. What are these rubber parts please (5 replies)
  148. oil change (6 replies)
  149. RPM at 70 MPH (15 replies)
  150. Parking brake (2 replies)
