Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924, 925
  1. push rod tube seals (6 replies)
  2. Foggy Fotos (20 replies)
  3. WOT - Technical, but NPC (7 replies)
  4. OT: odd car can you identify? (6 replies)
  5. mid rise scissor lift? (15 replies)
  6. 914 2.0S? mo' info. please (17 replies)
  7. TIMING? (29 replies)
  8. stainless steel heat exchangers (10 replies)
  9. Engman floor board finish options (3 replies)
  10. Air cleaner connection (15 replies)
  11. rear bumper pad rust (6 replies)
  12. Clutch Question (13 replies)
  13. Snorkel help! (2 replies)
  14. Spotted (2 replies)
  15. Weber Carb Conversion (12 replies)
  16. CSOB tool (3 replies)
  17. engine shipping (4 replies)
  18. future headlight mod help? (9 replies)
  19. powder coat oven fix (5 replies)
  20. What is this wire for and where/how does it go? (8 replies)
  21. Headlight dimmer Switch Connections (1 replies)
  22. Lifting the engine (9 replies)
  23. T-shirt for the little ones (13 replies)
  24. Temp Guage Sender (19 replies)
  25. Starter solenoid information (8 replies)
  26. NLA Dellorto parts (3 replies)
  27. OT: Birthday Fairy Report for 29 Jan 2011 (4 replies)
  28. Porsche Negative side stripes dimentions (3 replies)
  29. What are the cheapest wheels fit 914 (12 replies)
  30. Riviera Wheel Question (10 replies)
  31. If You Have to Ask the Price, You Can't Afford it (19 replies)
  32. what rpm is ideal for freeway cruising.73 ,1.7w/d-jet (20 replies)
  33. A/C Compressor Upgrade (20 replies)
  34. German Antenna Solution 4 the oversized fender hole. (4 replies)
  35. Need info On Pistons (20 replies)
  36. Engine Shelf Repair! (15 replies)
  37. Rim backspacing question (9 replies)
  38. Spanish 914-6 GT Yellow (84 replies)
  39. Fuel Pump for 3.0L Conversion! (8 replies)
  40. Who to contact at 914Rubber.com? (16 replies)
  41. Targa Headliner? (1 replies)
  42. Strange Shifter (21 replies)
  43. Victory Motors (1 replies)
  44. 914 towed away friday (15 replies)
  45. Porsche 914 2.0S on a bottle cap (Sprite) (9 replies)
  46. Anybody use kill switch's for security and ? (20 replies)
  47. OT: Birthday Fairy Report for 28 Jan 2011 (4 replies)
  48. 914 for sale (2 replies)
  49. Looking for Ideas (12 replies)
  50. 1.7 -2.0 (10 replies)
  51. Mile High 914 moving... (1 replies)
  52. OT: Did you grow up watching the show "The Prisoner"? (37 replies)
  53. 914 Factory Manual (7 replies)
  54. Possible tire / rim combo ? (12 replies)
  55. OT: Sealed bearings (3 replies)
  56. OT: Birthday Fairy Report for 27 Jan 2011 (6 replies)
  57. More Press that a Flat-4 Baby Porsche is coming SOT (39 replies)
  58. t4 engine builders in new jersey (6 replies)
  59. What's The Best Way to Bend Brake Tubes? (21 replies)
  60. Wiper blades? (5 replies)
  61. Bumpers/paint (3 replies)
  62. New digital distributor? (12 replies)
  63. Odd Ebay Result (6 replies)
  64. RESTO on some trailing arms and brakes....Anyone in CO interested? (10 replies)
  65. NPC: trying to source a ford transmission (1 replies)
  66. Fistful of Fug (4 replies)
  67. PPI? (4 replies)
  68. Camp914 Drivers Turn off on low & on with high beam (1 replies)
  69. Anybody have a PCA Credit Card? (7 replies)
  70. Plexiglass Fuse Covers (10 replies)
  71. OT: Birthday Fairy Report for 26 Jan 2011 (7 replies)
  72. OT:235MPG VW (10 replies)
  73. stainless heat exchanger shell set brand new (63 replies)
  74. Flights are booked for Jan 22. Destination Palm Springs/Santa Monica (21 replies)
  75. 914-6 engine (MY'72) on eBay (3 replies)
  76. PC: Tech Session at Porsche of Livermore ... (4 replies)
  77. What is the ideal hp for a 914 (52 replies)
  78. What now? (12 replies)
  79. 914 electric heater (16 replies)
  80. Tracking the sale price of cars (12 replies)
  81. ARP 8740 vs ARP 2000 5/16" connecting rod bolts for H beam Rods (7 replies)
  82. Push rods - Stock vs Chromoly - Aluminum vs Steel (11 replies)
  83. What does it weigh? (1 replies)
  84. auto subie conversion on CL (7 replies)
  85. 21mm Torsion Bars 4 914/4? (23 replies)
  86. Pushrods? Hydralic Lifters? (8 replies)
  87. Picked up my 1973 Porsche 914 2.0 Yesterday (30 replies)
  88. 'Trimming' turbo valve covers (7 replies)
  89. valve train geometry (13 replies)
  90. OT: Birthday Fairy Report for 25 Jan 2011 (4 replies)
  91. OT decalling up a 911...need an designer (6 replies)
  92. Anyone know what's going on with 914 Appearance and Performance? (11 replies)
  93. Front targa top latches (11 replies)
  94. Where are you getting your Koni reds rebuilt? (9 replies)
  95. HF coupons again (0 replies)
  96. Engine motor mounts (12 replies)
  97. my 914 is on the road (16 replies)
  98. Two completely unrelated questions (3 replies)
  99. Huge Lot of Parts for Sale Near Hershey (6 replies)
  100. crooked headlight assembly (6 replies)
  101. 914 sale @ barrett-jackson poll (82 replies)
  102. I'm stumped.... what size bolts for the seat belts? (9 replies)
  103. OT: Birthday Fairy Report for 24 Jan 2011 (7 replies)
  104. OT: Maybe this is why so many 914s are on jackstands (4 replies)
  105. Removing pivot shaft and bushings from rear trailing arm (6 replies)
  106. Speedster Question (8 replies)
  107. Subaru Throttle Cable Options (14 replies)
  108. Push Rod Tubes leaking (11 replies)
  109. parking brake (3 replies)
  110. Calling Stonham & Tamura (1 replies)
  111. Barrett Jackson lot#1292 (7 replies)
  112. importmotor.com los angeles (19 replies)
  113. What a difference a few years make (13 replies)
  114. OT: Birthday Fairy Report for 23 Jan 2011 (6 replies)
  115. blinking brake light on dash (7 replies)
  116. Removing center console gauges (2 replies)
  117. Transmission for sube conversion (10 replies)
  118. Used Dells off of Craigslist. (18 replies)
  119. Looking for some suspension bushing suggestions (36 replies)
  120. Favor from Denver 914 members? (13 replies)
  121. Moved: Do you like Mexican...or Mexi-can't (-- replies)
  122. The real car is in the background (8 replies)
  123. Shopping for parts washers. (22 replies)
  124. Removing Rear Suspension (12 replies)
  125. Gearbox (4 replies)
  126. 70 fog lights (2 replies)
  127. Cable shifter (11 replies)
  128. Lowering kit? (17 replies)
  129. velocity ring (1 replies)
  130. Threshold Sill and carpet strips (14 replies)
  131. OT: Birthday Fairy Report for 22 Jan 2011 (6 replies)
  132. 73 914-4 for $25K (24 replies)
  133. Compatibility Question (7 replies)
  134. passing from 1.7 to 2.0 (5 replies)
  135. 914s in Austin? (8 replies)
  136. Webercarboutlet on eBay (3 replies)
  137. Dizzy swap questions (2 replies)
  138. Rear Caliper Restoration... (9 replies)
  139. Car on Craigslist...any info? (3 replies)
  140. LE Decals (15 replies)
  141. 911 help (3 replies)
  142. WOT! Need a GOOD parallel printer (12 replies)
  143. Salvaged title? (20 replies)
  144. OT: Birthday Fairy Report for 21 Jan 2011 (5 replies)
  145. Best brake pads (19 replies)
  146. Photo Thread: Before & After (64 replies)
  147. Wiring diagram for heater controls (1 replies)
  148. Any Clubs or 914 groups located in Northern Arizona? (7 replies)
  149. How do i get dead rodent smell out of my 914? (43 replies)
  150. Combustion Chamber CC (3 replies)
