Full Version: 914World Garage
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762, 763, 764, 765, 766, 767, 768, 769, 770, 771, 772, 773, 774, 775, 776, 777, 778, 779, 780, 781, 782, 783, 784, 785, 786, 787, 788, 789, 790, 791, 792, 793, 794, 795, 796, 797, 798, 799, 800, 801, 802, 803, 804, 805, 806, 807, 808, 809, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, 822, 823, 824, 825, 826, 827, 828, 829, 830, 831, 832, 833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848, 849, 850, 851, 852, 853, 854, 855, 856, 857, 858, 859, 860, 861, 862, 863, 864, 865, 866, 867, 868, 869, 870, 871, 872, 873, 874, 875, 876, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888, 889, 890, 891, 892, 893, 894, 895, 896, 897, 898, 899, 900, 901, 902, 903, 904, 905, 906, 907, 908, 909, 910, 911, 912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924, 925, 926
  1. OT: Birthday Fairy News for 19 Dec 2016 (10 replies)
  2. Shout out to Eric and PMB (11 replies)
  3. Turn signal fittings (2 replies)
  4. Any smog geeks here? Help with a '03 Carrera 996 requested. (27 replies)
  5. Original Fuel Pump - Rebuildable? (5 replies)
  6. Installed a trickle charger jack port in wheel well (15 replies)
  7. correct trim location (3 replies)
  8. McQueen Le Mans Novel (Cartoon) has a 914 in it (7 replies)
  9. Floor Pan Replacement - Need How To Advice (7 replies)
  10. Opening Tach? (3 replies)
  11. 914-6 Alternator question (12 replies)
  12. GE60 Grind (6 replies)
  13. OT: Birthday Fairy News for 17 Dec 2016 (8 replies)
  14. Glove Box Door (5 replies)
  15. Anyone in St. Louis, MO area? (5 replies)
  16. Cool Dutch training course (2 replies)
  17. After years of less than adequate illumination on dark nights, let there BE LIGHT! Flat panel, low voltage LEDs... (10 replies)
  18. what are the measurements of ians shift cables for a subaru trans (1 replies)
  19. Rubber Gasket needed (1 replies)
  20. Holiday breakfast. (11 replies)
  21. OT: Birthday Fairy News for 18 Dec 2016 (8 replies)
  22. Not shifting well (16 replies)
  23. Rear trunk cable release is DONE! (20 replies)
  24. Bleeding front brakes (4 replies)
  25. How can I repair dents in header pipes? (8 replies)
  26. Need alternator housing restoration advice (10 replies)
  27. Price Check NOS Early Seat Belts (5 replies)
  28. LED headlights...did we get any updates? (8 replies)
  29. Injector Flow Rate Matching (15 replies)
  30. Q for AZ members re smog test (13 replies)
  31. Type IV 2.4 L carb jetting. (3 replies)
  32. needing to find a washer (18 replies)
  33. Mini Truck conversion advice (8 replies)
  34. Instrument issues (7 replies)
  35. 1.7 Engine Build Questions (12 replies)
  36. 914 stock camshaft question (1 replies)
  37. The official Mike Wills 3.2 Conversion Thread. (274 replies)
  38. 914Rubber - Missed connections (32 replies)
  39. No Bright Lights - help? (8 replies)
  40. AAR from L-Jet (13 replies)
  41. '75 Dash Facing, left side only (5 replies)
  42. Flat 6 Replicas (19 replies)
  43. Recent starting problem...possible short (3 replies)
  44. Engine oil leaks. (10 replies)
  45. Found 914/6 Value Help Please (51 replies)
  46. The first 911 cabriolet prototype (9 replies)
  47. 1.8 mufflers (4 replies)
  48. Relay Identification (6 replies)
  49. Case line boring (7 replies)
  50. Looking for rim 4 to 5 lug adapters for Fuch style rims (8 replies)
  51. Hole in the Head (5 replies)
  52. More new stuff - Heat exchanger cover plate gasket Kit (41 replies)
  53. New fuel pressure regulator setpoint? (5 replies)
  54. Silly 914 Question (13 replies)
  55. I fuching hate theives (34 replies)
  56. OT: Birthday Fairy News for 15 Dec 2016 (9 replies)
  57. Moved: Suspension lever (-- replies)
  58. Rear sway bar link bushings (6 replies)
  59. rust on prospective purchase (17 replies)
  60. Part Number Confirmations (12 replies)
  61. Mikey914 (3 replies)
  62. Replaced TPS board (5 replies)
  63. Got some light rust? (2 replies)
  64. oil pump cover nuts (4 replies)
  65. Engine Cast Numbering (8 replies)
  66. Idle adjust on '73 1.7 (31 replies)
  67. Question for Mark at 914Rubber (2 replies)
  68. OT: Birthday Fairy News for 14 Dec 2016 (9 replies)
  69. Window adjustments (4 replies)
  70. Window adjustment (1 replies)
  71. QQ are you able to use the 914 cross member with 911 control arms? (4 replies)
  72. Touch up Paint for older codes (3 replies)
  73. Lateral trailing arm movement (23 replies)
  74. HSR Sebring 914-6 Video (15 replies)
  75. OT: Birthday Fairy News for 13 Dec 2016 (7 replies)
  76. Brake pads for Alfa 3" front calipers (9 replies)
  77. Who knows wheels (9 replies)
  78. Worth saving? (22 replies)
  79. OT: Birthday Fairy News for 12 Dec 2016 (10 replies)
  80. Gas gas (5 replies)
  81. Anyone familiar with this car from SoCal? (3 replies)
  82. Still can't get it running properly (9 replies)
  83. Reunited (21 replies)
  84. Adjustment of play- brake pedal rod into MC (5 replies)
  85. Converting from Fuel Injection to Carbs (56 replies)
  86. 'splain me about exhaust systems and heat exchangers... (30 replies)
  87. Oil Filler Cap for 914/6 (5 replies)
  88. Pegging the speedo (17 replies)
  89. Front Side Light Marker removal? (7 replies)
  90. Hey Beat Navy (5 replies)
  91. SOT: Bertone styled 911 (38 replies)
  92. Vintage Key Case (0 replies)
  93. Ebay Seats (33 replies)
  94. OT: Birthday Fairy News for 11 Dec 2016 (10 replies)
  95. Little OT but still a Porsche Bertone? (12 replies)
  96. Mallory Unilite (2 replies)
  97. Clutch pedal Question (8 replies)
  98. Christmas Sale at SpokeworksLED (4 replies)
  99. Used 914 2.0 price (13 replies)
  100. Thanks timothy_nd28 (3 replies)
  101. Steering Wheel Change (5 replies)
  102. Is this standard Exhaust? (5 replies)
  103. Paint formula printouts online? (9 replies)
  104. Build 1.7 into 2056 help (3 replies)
  105. McMark, I Have Your Old 914! (7 replies)
  106. Porsche 914 3D in Sketchup (43 replies)
  107. OT: Birthday Fairy News for 10 Dec 2016 (7 replies)
  108. Vendor recommendations for powder coating and CAD plating (7 replies)
  109. GTS Seats (8 replies)
  110. Where Is It Today (1 replies)
  111. Rust repair (6 replies)
  112. Color Chart L20E Question (8 replies)
  113. What the damn hell?! (6 replies)
  114. OT: Birthday Fairy News for 9 Dec 2016 (8 replies)
  115. Removing the eye brow? (16 replies)
  116. Fuel injector voltage (9 replies)
  117. kremer 914/6 (26 replies)
  118. Shipping Engines From UK to US? (10 replies)
  119. Targa Bar Cover Restoration (10 replies)
  120. Bilstein Jack Rubber strap (1 replies)
  121. OT (6 replies)
  122. Composite Dimensions (6 replies)
  123. Cool app for checking different tire and rim sizes and offsets (5 replies)
  124. Euromeisters (19 replies)
  125. Coffee? Pastries? 914s? - Oakland Dec 10 (16 replies)
  126. OT: How big is your carbon footprint? (2 replies)
  127. Best Paint for Roof? (14 replies)
  128. No start (20 replies)
  129. 916 bumper question (15 replies)
  130. Can you log on to PayPal? (7 replies)
  131. holiday specials on fiberglass parts? (0 replies)
  132. Rear PORSCHE lens (20 replies)
  133. Correct size for triple square bit tool for CV bolts ? (2 replies)
  134. OT: Birthday Fairy News for 8 Dec 2016 (8 replies)
  135. Mallory Unilite dizzy cap (7 replies)
  136. Synthetic or Regular Blinker Fluid (55 replies)
  137. Best place to install a small amp (8 replies)
  138. Rear mount turbo (16 replies)
  139. OT: Honda Powered BMW 2002 (19 replies)
  140. When you Want a McLaren F1 (3 replies)
  141. Passenger rear makes noise upon acceleration (17 replies)
  142. Need help with my 74 914 (23 replies)
  143. Mikey (9 replies)
  144. question about fittings on original 6 oil tank (18 replies)
  145. cushions/wire protectors (3 replies)
  146. Quick Tip (6 replies)
  147. Stock front torsion bar size 17.9mm? (14 replies)
  148. Will these work well on a flared car? (34 replies)
  149. OT: Birthday Fairy News for 6 Dec 2016 (8 replies)
  150. Fuel filter needs clamps? (10 replies)
