QUOTE(sixnotfour @ Aug 22 2019, 05:03 PM)
square cut around trunk latch....just sayin...
Man,
@Dion called it. Tough crowd, indeed! You guys are making me think I should wait until each part is "done" before posting any pics... Nah, my skin's thicker than that!
@sixnotfour - The square cut is essentially required to get those edges of the shroud as close to the latch mechanism as possible. This to prevent air from finding a way out that isn't through the radiator. I tightened up the opening to get it as close as I could.
If what you mean is that I didn't address the "plainness" of that area, we're on the same page. As I've developed my approach to the stamping process I use,
it's sometimes easier for me to come back and do a secondary operation on one or more areas of a panel, and that's the case here.
What works best for me is to make my stamping die set the exact same outside shape as the panel being stamped. It ensures I get a nearly perfect dimension on the step of each recessed area. But with this panel, it meant I couldn't/didn't stamp anything around the latch cut out.
That said, to address the latch area, I'll make an "edge stamp" die set and form something that's more interesting than just the plain cut out.
Once I've finished, I'll post pics of all the dies I made for this piece.
Could I have done it all differently? Probably, but as I mentioned, this is the process that (currently) works for me.
I find it really helpful to hear other folks' opinions and ideas so keep the cards and letters coming!
