After seeing the straight across version, my immediate reaction was, like
@Cairo94507 Michael's, that the angled version needs more vents. As bold as those larger vents look, they seem a bit out of scale on the car.
And as
@buddyv Robert mentioned, the straights have a bit too much of a "home floor heater vent" look. Well, at least this current version does, IMO.
So, how to proceed? Well, I'm going all in on ANGLES! Frankly, it's important to me that I do all I can to honor
@Retroracer Tony's original design.
Plus, I think they fit the vibe of the build.
So, I spent a bit of time and worked up a new design. The key changes this time are:
- vents went from 45 to 60 degrees
- scaled the vents down to make room for a 7th vent (nature abhors even #s!)
- incorporated the "bend area" design from the straight version
IMO, this last point lends a more finished look to the final product. Compare the bend areas and you'll see that the current angle design is simply twisting a small area that I worry will crack at some point. The new approach leverages what I've seen on the commercially available vent products.
Not only does this seem a safer way to do the bend, it also means the upper edge of the vent moves outward, causing the top corner radii to finish proud of the inner edge of the frame. It just looks more "finished" to me.
Pics of the real one on the car in the next day or so. And if you're asking yourselves "when will this silliness end?", know that I'm wondering the same thing.
