And in the spirit of full disclosure:
I've said it before - mostly you see the end result in the pics, not the gaps in knowledge or experience, or the 'n' number of attempts at getting things to work out. So, it's only fair I pay tribute to those parts and pieces that sacrificed themselves to the cause. These are the latest examples of my learning as I go.
Put these in the "Don't" column:
- You can't expect a good result unless you have thought ahead and allowed for enough tube length so that the front part of the die doesn't run off the end of the tube and totally gack the part. (Yes, that is a rip in the tube...)
- given a particular radius die, there are limits to how close you can bend two radii. If you think you can outsmart physics and magically get them closer, you are wrong.
- as with all things in life, the facts are the facts and no amount of lube will make any difference.
I should start a website called "FabFail.com".
I'd be a regular contributor...
