See, even though this build gets into a ton of stuff that you don't care about, occasionally, I pull out something that makes it worth following what I'm up to!
From a 2004 360 Modena. 400 hp @ 8500. Yes, there's matching 6-speed transaxle, ECUs, wiring harnesses, etc., etc. Essentially everything needed to make it run. It's got only 5K miles on it.
I've been debating posting about it because it sorta fell into my lap and I may or may not do anything with it. For example, while initial measurements indicate the engine/trans package will fit a 914, length-wise, it's clear that factory intake set up won't fit - at least not without a ton of rework to my engine compartment. And I'm not willing to do that.
So, current options being noodled on include:
1. Fab a set of manifolds and run a "standard" 8-stack ITB set up and stuff it into my chassis
2. Find another chassis and build a different 914 around it. Though it'd likely still need intake mods.
3. Stuff it into RacerBenz! It fits with no mods. But best of all? I could name the car... wait for it...
Benzo Ferrari! And come on, that would be so f-ing epic it's nearly impossible to resisit.
4. Do nothing. Which is probably the best option!
A friend of mine has a 360 street car and a 360 Challenge car. Plus, he's a MoTec dealer. I've been chatting with him about what's what so give me a bit to work out a few things and we'll see what happens. This isn't (yet) a front burner project but I'll update things as I make progress.
