The goal is no soldered joints anywhere in the car. Soldering turns stranded wire into solid wire and increases the chances of a vibration or stress-related failure.
While there are lots of examples of soldered joints not failing, I'm opting for open barrel crimps.
Good Man!
Crimps ARE better and more reliable than soldering. Aerospace knows this, automotive, and F1 motorsport all know this. Proven out by millions of hours of test and development - not a theory.
"Crimping is an efficient and highly reliable method to assemble and terminate conductors, and typically provides a stronger, more reliable termination method than that achieved by soldering." Excerpted from NASA document.
https://workmanship.nasa.gov/lib/insp/2%20b...quirements.html
See section 2.01 for source of the quote and the graphic
Totally understand the move to avoid the Deutsch Autosport connector.
Nice to see you using proper sealing shrink wrap too.
Wiring is another top notch touch that is going to set your car above the usual hack and whack resto-mods out there. Really nice! Everytime I view your thread I'm blown away.
How many sets of barrel crimp tools do you now own? As a former electronics tech that used to work on multi-pin connectors just like that, the inner geek in me really enjoyed the precise ratchet sound and click that the barrel crimp tools made. Having a whole bench of just the right tool for each connector style was a luxury I no longer have but still envy!
