Pics of progress for those who simply can't wait until the next video is released.
tygaboy
Sep 4 2023, 05:28 PM
@Dave_Darling Dave - I hope this level of visibility meets with your approval.
tygaboy
Sep 4 2023, 05:30 PM
Other side fitting underway. @Andyrew Andrew - Sorry, upright is always better!
Cairo94507
Sep 4 2023, 07:09 PM
bkrantz
Sep 4 2023, 07:27 PM
Heat shielding for trans?
mgp4591
Sep 4 2023, 08:19 PM
QUOTE(tygaboy @ Sep 4 2023, 05:30 PM)
Now THAT is downright sexy...
markhoward
Sep 4 2023, 08:41 PM
This is the best one yet!
BuddyV
Sep 4 2023, 10:16 PM
Videos are getting better and better!
Love this project!
tygaboy
Sep 5 2023, 08:36 AM
QUOTE(bkrantz @ Sep 4 2023, 06:27 PM)
@bkrantz - A few folks have asked about this. Here's a shot of the clearance. I may add a shield.
bkrantz
Sep 5 2023, 07:27 PM
QUOTE(tygaboy @ Sep 5 2023, 08:36 AM)
I figured you had something in mind.
Dave_Darling
Sep 6 2023, 05:20 PM
QUOTE(tygaboy @ Sep 4 2023, 04:28 PM)
--DD
watsonrx13
Sep 6 2023, 05:24 PM
QUOTE(markhoward @ Sep 4 2023, 09:41 PM)
Fantastic...
tygaboy
Sep 6 2023, 05:37 PM
The car is leveled and the passenger side muffler is set to the same position as the driver side. As you can see by the gap in that last 90 degree tube, I'm nearly there. One final trimming and it'll be good to go.
Couldn't resist a pic of things at this stage of completion. I should have it all wrapped up, including the exits, in the next post.
Cairo94507
Sep 7 2023, 06:55 AM
tygaboy
Sep 7 2023, 01:07 PM
Ready for final welding and some exhaust tips. Nearly there.
Shivers
Sep 7 2023, 01:56 PM
QUOTE(tygaboy @ Sep 7 2023, 12:07 PM)
That is really cool looking. It looks like it will work well, more so it will sound just as good. My brain wants to know about the temps you expect in the trunk. And are we in for some awesome fresh air intake design. Spooky cool dude
burton73
Sep 7 2023, 05:01 PM
I sent you a PM.
Best Bob B
burton73
Sep 7 2023, 05:14 PM
sorry doubble post
tygaboy
Sep 8 2023, 07:06 PM
QUOTE(Shivers @ Sep 7 2023, 12:56 PM)
@Shivers - Yes, you are. But no promises. I'm entering uncharted waters, at least for me. But I'll do my best to keep you entertained as I learn what is and what is not possible!
tygaboy
Sep 8 2023, 07:14 PM
Martin was At The Red Barn today and we focused on getting the exhaust tips fitted and final welded. They haven't been trimmed to length but I'm super happy with this new exhaust. It met the targeted goals: - symmetry that pleases my eye? Check - mufflers all but invisible? Check - transmission totally visible? Check
I did want the center exit exhaust but this one has it's own sort of style points. Less elegant, more brutish, which certainly fits the build. It's not as "Porsche" as a center exit but it does a lot to add to the "that is a wide 914!" look.
On to the next thing I decide to do!
cassmcentee
Sep 8 2023, 09:51 PM
tygaboy
Sep 9 2023, 07:07 AM
And the latest video to get you current on the exhaust fab.
I love the look and can't wait to see the finish length of the tips as well as hear it run.
technicalninja
Sep 9 2023, 09:14 AM
You could add exhaust cut outs before the X and have the cut out exits in the center...
You've got plenty of room.
It would be LOUD!
Your mounts are very well designed. They look like they should work fine. Very tidy.
I'd add some type of expansion connection to both sides before the X section.
Might be as simple as slip tubes and springs or true flex sections on v-bands.
I think the temperature swings that the system will go through will over stress that x section and it will fail without some type of stress relief.
Sure looks pretty like it sits...
Edit: Love the new intake. On the LARGE size! You need a built motor to go along with that! 13:1 with nearly 300 degrees of duration. 600+HP will be attainable through that intake. You just don't have a car that can apply that power to the ground. Car will need to weight 4K plus to make that work well.
@SirAndy@markhoward - Hey, guys, you know I'm all about METAL! Speaking of which, @buddyV Robert stopped by yesterday and poo-poo'd my initial rear mount. Constructive critisism is great because if forces me back to the design board and (IMO) I invariably come up with something I like more. In this case, it's a folded sheet metal bracket that has WAY more style points. Me likee! Plus, I'll maybe back it up with some mesh, like on the rear panel. Thanks Robert!
technicalninja
Sep 10 2023, 12:09 PM
That's a bunch stronger as well!
tygaboy
Sep 11 2023, 03:06 PM
Rear mount fully welded, including a set of underside gussets. Martin was by today and we noodled out a design for the exhaust tip hangers. He's back to his shop (lathe and mill, which I don't have) to whip up the needed parts.
tygaboy
Sep 14 2023, 10:05 AM
This one is a bit different. You've heard me mention Martin and all the help he's been on my builds. Here's a bit of an intro and a peek into his background. Talk about a man with passion and skills! And if you're at all into slot cars, this is a must see! Plus, you'll get a teaser about an episode on his experience designing/building ProStock drag bikes. Enjoy!
Sweet. I can't wait to see the final tip length and hear it run.
tygaboy
Sep 16 2023, 12:42 PM
Embarking on another "I wonder if this will work" project. These are Nash Metropolitan doors, one of which I cut up. Will it work out? Place your bets now!
tygaboy
Sep 16 2023, 05:32 PM
For whatever reason, as I was moving the doors, I noticed the shape and thought, "I wonder if I could use that as the center section of a rear valance?" It'll take some work, but I think I can. Sort of diffuser-like and a pretty neat shape. I'd love to be able to say I used part of a '59 Metro on my build. We'll see how this goes.
tygaboy
Sep 16 2023, 05:35 PM
Back to necessary things. Here's the outboard muffler support in place. Not too noticable from the engine compartment side and totally invisible from the rear. Yes, it's single-shear but the other end is mounted in pretty pliable rubber so I'm not worried.
Shivers
Sep 16 2023, 06:25 PM
QUOTE(tygaboy @ Sep 16 2023, 04:32 PM)
I like it
Cairo94507
Sep 17 2023, 07:20 AM
I like where that is headed.
burton73
Sep 17 2023, 08:00 AM
The second I saw the metal from the Metro doors I knew what it was. I had a buddy that had a metro way back. Great idea for the rear valance. Dual out flared valance it's going to be nice. You know the thing is, you do your best to design an exhaust and until it cycles through high heat and cools a number of times you are not 100% sure what it is going to do.
@technicalninja Rick had men mentioned “I'd add some type of expansion connection to both sides before the X section.
I think the temperature swings that the system will go through will over stress that x section and it will fail without some type of stress relief.”
--- I had thought it may need some kind of Bellows because I remember what my 74 turbo 2.0 did after running it around very hard and the exhaust was glowing red and would bend a bit.I did have bellows on its SS custom system. ---
I guess if it has a problem in road testing it you will just rework it.
Anyway, your ideas as a designer and fabricator are fantastic and your work is as good as anything I have ever seen.
Best Bob B
tygaboy
Sep 17 2023, 11:07 AM
A quick errand this morning with everything done, including tips trimmed to length. I'd swear it's quieter, too.
Cairo94507
Sep 17 2023, 11:49 AM
Can we see a full-on side shot please? To my eye (and it could be the angle) they look a tiny bit long.
tygaboy
Sep 18 2023, 06:20 PM
QUOTE(Cairo94507 @ Sep 17 2023, 10:49 AM)
@Cairo94507 Michael - These are the same length as the dual asymmetric I just replaced. I'm going to live with them a while. Easy enough to shorten them if I decide that's what needs to happen.
Cairo94507
Sep 19 2023, 07:22 AM
Hi Chris- Now that I see them from the side they are fine. Sorry, they looked longer in the other angles. Cheers, Michael
tygaboy
Sep 26 2023, 05:20 PM
Back on the intake. I fabbed a test piece to verify the plenum base plate spacing measurements. Lots of stuff to work out but it's a start. Remember, whatever gets build, the goal is a clear top plate so you can see the stacks. Fingers crossed this actually works!
tygaboy
Oct 3 2023, 04:44 PM
I decided to make a heat shield for the new exhaust. I was going to try and make it from aluminum but figured it'd take quite a while, I'd screw up a bunch of material, etc. So I opted to do one in carbon fiber. First I need a mold and figured why not use it as an opportunity to learn a new skill. So I did a bit of research and ended up with this: - place a suitable sheet of ABS in a 225 degree oven until it "goes soft" - drape it over the shape you want to copy - press, weight, form and hold it in place until it cools enough to hold the shape
I was a little hesitant with the heat, what with it being my first time, and the first go didn't work out - the ABS wasn't soft enough to form a couple of the tighter areas. The cool (!) thing is I just popped it back in the oven (don't tell my wife), bumped the heat and let it bake until I could easily fold up a corner.
Then it was: pull it out, drape it on the exhaust and quickly form it as best I could. I used a bodywork sand bag to weigh it down while I worked downward force everywhere, as best I could. Once it was clear it was no longer formable, I removed the sand bag. Here's what it looked like at that point:
tygaboy
Oct 3 2023, 04:48 PM
Lift it off and BAM! One exhaust heat shield mold.
Pay no attention to the shape around the edges, the final part will be trimmed to look nice, be symmetrical, etc. Next, it's on to some carbon fiber layup.
It was a fun afternoon. I love adding to my skills tool box.
