Full Version: Member's 914 Pictures
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113
rjames
You just need a rear valance on that puppy to complete the package.
rnellums
QUOTE(domer914 @ Mar 1 2012, 07:36 AM) *
I am kinda new. Had to wait a while to get mine back after burning her down a while ago.Click to view attachment
This looks really sharp
pnewman
Looks like the rear valance would be a project if you planned on keeping that muffler / exhaust tip set up.
I agree with the crowd. Very sharp set up. Gets my vote!
bandi
QUOTE(pnewman @ Mar 3 2012, 09:10 AM) *
My rather.... crispy parts car (engine donor!) has that same exhaust setup, and the PO has absolutely mangled what looked to be a decent rear valance to make it work.
domer914
QUOTE(bandi @ Mar 3 2012, 05:35 PM) *
It came with a valance, but I removed it along with the SuperTrap muffler. As was mentioned above, you would practically have to mangle the valance to get it to fit this car now.
pnewman
QUOTE(bandi @ Mar 3 2012, 03:35 PM) *
The last time that I saw a 4 tip exhaust like yours it was on my 1971 vw microbus.
I could imagine some fiberglass spoiler type of rear valances that might work but not the oem steel one. A muffler & tail pipe swap might be easier.
Whatever you do I am sure that it will look nice as your work so far looks top notch.
Good luck.
rnellums
JMKnight
QUOTE(AZ914 @ Aug 2 2011, 08:50 AM) *
JMKnight,
Looks nice! The 'original' sixes are now worth big bucks. Keep it stock!
Ok I will. I have the urge to change it out of my system now, took a while though.
bandi
Got the parts car home on the weekend. What an absolute shame, it was a 3 day old resto.
IPB Image
IPB Image
IPB Image
Luckily the firewall did its job and everything behind the passenger compartment is fine, with the exception of the rain tray.
rjames
Yikes. Fire damage? Usually they occur in the engine compartment. What happened?
abnrdo
OMG I got really sick after seeing what was under that tarp.
Fuel lines?
bandi
QUOTE(rjames @ Mar 21 2012, 03:51 PM) *
Apparently it was vandalism... I guess the guy who owned the shop which did most of the resto work had upset a few local people. This is the story I'm getting at least.
After I've stripped it I'm going to give it to Mike at Mike's 914s, the rear end of this thing is perfect and I'm sure he can use it to save another 914.
ezbngreen914
euro911
Been a while since I've posted in this thread.
Here's the old 'BB' the morning of it's inaugural journey with the new drive train. Took this shot just prior to leaving for the Lake Havasu 2012 Route-66 Run.
It's a '75 with '71 bumpers, ATS wheels with Michelin 195/60x15s, new calipers and M/C, S/S fuel lines, fresh Type-4-Unleashed 2056 with Weber 40IDFs and CSP throttle linkage, VJR4-BR8 dizzy with Pertronix, mated to a freshly rebuilt THOMAS transaxle, SSI H/Es and a Triad muffler.
Changed the interior from black to tan
It ran pretty good on it's 'maiden voyage', but still needs a little fine-tuning jetting work on the carbs and the front suspension rebuilt.
sixnotfour
Green
jshep
euro911
Original '6'?
jshep
QUOTE(euro911 @ Apr 9 2012, 10:19 PM) *
Original '6'?
Yes sir.
liebe
QUOTE(jshep @ Apr 10 2012, 08:02 PM) *
Original '6'?
Yes sir.
Hello Guys,
I am new around here. Would like to present myself I am Santiago and a couple of my 6,s. I live between Spain and Houston.
Rosito and Blue.
Gustl
beerchug.gif Gustl
euro911
etcmss
my 71 after restoration (with several minor items left to go), installed a 74 2.0 drive train.
liebe
QUOTE(etcmss @ Apr 15 2012, 11:37 AM) *
Thank you Wolfgang and guys. Its nice to see that there brothers are euqually nice, if i could like all of us, would have them in every color, be a 6 or a 4.
I will leave you guys with some pics of the 914,s and some of the garage too,
but will make some new shots tomorrow, have done some painting at the garage, so it lookes a tad better, not to my liking yet, but getting there.
Also the RennTransport for the 914,S or at least thats the intention
santiago
liebe
QUOTE(liebe @ Apr 15 2012, 05:50 PM) *
santiago
neyen14
QUOTE(liebe @ Apr 15 2012, 07:50 AM) *
santiago
Ferg
santiago
Welcome aboard Santiago!
ndfrigi
Hi, here is my '75 1.8 F.I. acquired last Aug. 2011. A few history of this car, got from my nearby neighbor sitting on his drive way with Non-op with last registration of 2003. We just pushed the car from previous owner house to my house about a quarter mile. Bought new battery, remove the gas tank and amazing the left gas I drained is clean and no rust on the tank, changed all fuel lines underneath the tank (still original rubber fuel lines), replaced all fuel lines along engine and all vacuum lines, changed oil and transmission fluid, changed tires from 165x15 (I believed still the original tires made from Brazil tire) to 185x65x15. I had a hard time starting it until after more trials of starting it, it did start. So did checked and replaced brake pads and some cleaning on the pedals. Still a little bit sticky on the brake pedal. Now I've been using it once in while and running it for about 30 to 40 minutes drive, the temperature does not even go half way of the temp gauge. Still a lot of things to fix on this car but I love driving it even without the 1st gear (issue on the transmission which they said is common on 914).
Before I got it:
How it looks now:
ndfrigi
more picture: Click to view attachment
ndfrigi
ndfrigi
ndfrigi
dlee6204
euro911
If you're having a hard time getting first, check the shifter bushings (one at the firewall, the other at the rear shift console) - replace as needed.
If they're OK, try adjusting the linkage.
ndfrigi
QUOTE(dlee6204 @ Apr 18 2012, 12:07 PM) *
thanks and God Bless!
ndfrigi
QUOTE(euro911 @ Apr 18 2012, 12:31 PM) *
Hi sir, I did replaced all the bushings and tried adjusting linkage from stick shift and still 1st gear just make rumbling sound and pops out while releasing the clutch.
euro911
QUOTE(ndfrigi @ Apr 18 2012, 02:16 PM) *
It sounds like it's still not adjusted right. Bring it to the G&R swap meet and we'll see if we can assemble a crack team of scientists to fix it party.gif
ndfrigi
QUOTE(euro911 @ Apr 18 2012, 02:39 PM) *
Sir, what is G&R swap meet? is it a group of 914s?
euro911
QUOTE(ndfrigi @ Apr 18 2012, 10:30 PM) *
Well, in a nutshell - yes. The G&R is a semi-annual gathering of 914 nuts enthusiasts, sponsored by 'G' (Glenn), and 'R' (Ron), consisting of a swap meet and an awesome BBQ. Lots of good, knowledgeable folks attend the event(s).
There happens to be one coming up Sunday, May 6th. If you're free that day, try to attend. Click here for details.
And please, quit referring to me as 'Sir' ... makes me feel like an older fart than I am laugh.gif
ndfrigi
QUOTE(euro911 @ Apr 19 2012, 12:06 AM) *
And please, quit referring to me as 'Sir' ... makes me feel like an older fart :than I am laugh.gif
Wow it would be nice to attend this and I really would love too! But sunday is my family church service and my wife and I has different ministry that we are doing for our church. Just wondering, do you know about the 914 group that meets every 3rd saturday of the month at the Orange City, CA? Take care!
jrrhdmust
My Project
ezbngreen914
ezbngreen914
914pwer
IPB Image
euro911
QUOTE(ezbngreen914 @ May 2 2012, 11:47 PM) *
How did you process this pic?
It looks like a drawing or water color - cool
lennyhope
IPB Image
IPB Image
IPB Image
Hi from Andy near Liverpool, England....
ezbngreen914
ezbngreen914
IIRC iPhoto
Tom
Pics of pics.
70 1.7 with flares in San Diego 1976
70 in desert coming back from New Mexico 1976
75 1.8 at dry Creek , California 1981
1970 Neun vierzehn
lennyhope
IPB Image
