bkrantz
Sep 13 2020, 06:53 PM
Thanks, Blown. I enjoy stopping to take phots, and it keeps me from rushing at times. And posting online gives me some motivation to keep up momentum.
bkrantz
Sep 13 2020, 06:55 PM
I inspected the shift rods today. The both look fine, just in need of paint (or powder-coat).
bkrantz
Sep 13 2020, 06:56 PM
The linkage, though, looks a bit (or more) loose. The plastic bushings might be worn.
bkrantz
Sep 13 2020, 06:58 PM
It took about 30 seconds to remove the pivot shaft with my press. The bushings are definitely done.
bkrantz
Sep 13 2020, 07:01 PM
Speaking of the press, I installed the rear wheel bearings in the trailing arms today. Based on my bench testing, I decided to coat the bearing cavity in the arm, which was blasted to bare metal, with Boeshield T-9.
Very easy to press the bearing, with little force required.
bkrantz
Sep 13 2020, 07:02 PM
I like using a press with a pressure gauge, so that when the bearing is seated, I can see the pressure ramp up.
bkrantz
Sep 13 2020, 07:04 PM
Bearing in place.
bkrantz
Sep 13 2020, 07:05 PM
And retainer with shiny new hardware. Mmmm.
bkrantz
Sep 13 2020, 07:06 PM
Good reason to tap into my newly created home hardware supply, sourced from McMaster-Carr.
bkrantz
Lots of shiny stuff!
bkrantz
Sep 13 2020, 07:07 PM
Then time to press in the wheel flanges. Note: inner races of the bearing supported from below.
bkrantz
Sep 13 2020, 07:09 PM
Flange in place.
bkrantz
Sep 13 2020, 07:10 PM
Trailing arms done!
Kansas 914
Sep 13 2020, 08:01 PM
Terrific work Bob.
I have a bead blaster you are welcome to use if you need to work on some of the really bad stuff.
djway
Sep 13 2020, 11:37 PM
Tools are Swell!
bkrantz
Sep 14 2020, 07:30 PM
QUOTE(djway @ Sep 13 2020, 11:37 PM)
Tools are Swell!
Agreed. Here's my latest that I picked up from the local freight delivery company today. I was stupid when I bought the Dake bench top model since the working height is only about 16 inches. My excuse is that I replaced an older bench top press.
But I need something with more reach, so I got the Dake floor model. This has a 38 inch working height.
My son will inherit the bench model.
bkrantz
Sep 14 2020, 07:33 PM
Another batch of parts after Evaporators-rust treatment.
bkrantz
Sep 14 2020, 07:36 PM
One of the half-shaft flanges has some upturned edges on the inside.
bkrantz
Sep 14 2020, 07:37 PM
Took care of those with a flat file.
bkrantz
Sep 14 2020, 07:40 PM
To test the flange flatness, as was discussed in another thread, I scuffed the mounting faces on some emery paper. Looks good.
brant
Sep 15 2020, 03:27 PM
I just went through the whole thread
amazing
really really nice!
great metal work!
brant
bkrantz
Sep 15 2020, 07:39 PM
QUOTE(brant @ Sep 15 2020, 03:27 PM)
amazing
really really nice!
great metal work!
brant
Thanks, Brant. Good to meet you, and thanks for using your 914 to deliver 914 parts!
bkrantz
Sep 15 2020, 07:41 PM
I took a closer look at one of the CV joints, with all the parts showing lots of wear. Here's the outer housing.
bkrantz
And the cage.
bkrantz
Sep 15 2020, 07:43 PM
And the inner flange. I suspect these show extreme wear. Time for new CVs?
bkrantz
Sep 15 2020, 07:45 PM
With all the parts and supplies in hand, I started rebuilding the steering rack.
bkrantz
I never removed the inner pivot bearing, just cleaned out as much old grease as possible.
bkrantz
Sep 15 2020, 07:46 PM
I made my own grease injector, to fill below the lower bearing.
bkrantz
Sep 15 2020, 07:48 PM
Then I greased up the rack, and slid that into place, maintaining the original left vs. right.
bkrantz
Sep 15 2020, 07:50 PM
Here's the pivot, with the upper bearing in place, all greased.
bkrantz
Sep 15 2020, 07:51 PM
Then packed the interior with more grease.
bkrantz
Sep 15 2020, 07:53 PM
With the rack centered, I installed the pivot. This took some patient twisting of the rack and pivot to get everything aligned.
bkrantz
Sep 15 2020, 07:54 PM
Next, the shims I removed and the lock ring.
bkrantz
Sep 15 2020, 07:56 PM
With everything installed, I checked for end play: zero.
bkrantz
Sep 15 2020, 07:57 PM
Then the pivot shaft seal, which I found based on dimension.
bkrantz
Seal in place.
bkrantz
Sep 15 2020, 07:58 PM
Then center the rack...
Kansas 914
Sep 15 2020, 07:59 PM
QUOTE(bkrantz @ Sep 15 2020, 07:56 PM)
Well done. I need to do that on one of my cars. Thanks for the documentation.
bkrantz
...and install the yoke, oriented vertically.
bkrantz
With the rack flipped over, I installed the pressure block.
bkrantz
Sep 15 2020, 08:01 PM
The end of the block sits just below the housing face. I measured 0.1 mm.
bkrantz
Sep 15 2020, 08:02 PM
Next, I measured the recess in the cover plate, 1.7 mm.
bkrantz
Sep 15 2020, 08:04 PM
Then I measured the thickness of the original shim, and the gasket.
bkrantz
Sep 15 2020, 08:07 PM
Here's the math. The total gap, including the gasket, is 2.1 mm. The designed gap is 0.2 mm. Can you spot my math error? The desired shim should be 1.9 mm! But the original shim is 1.85 mm, so all is well.
bkrantz
Sep 15 2020, 08:08 PM
Here's the pressure spring, and the cover plate with shim ready to install.
bkrantz
Finally, here is the rack all done.
autopro
Sep 16 2020, 11:59 AM
This is awesome, I will be doing this to my rack soon. Thanks for the picture of the seal as finding a replacement was one of my concerns.
bkrantz
Sep 16 2020, 07:40 PM
Steering rack, part 2.
I started with the eye-bolt build kit.
bkrantz
Sep 16 2020, 07:42 PM
No instructions, so I made up my own.
Here's the bushing and eye-bolt on the press, with plenty of liquid soap. Centering is important.
bkrantz
Sep 16 2020, 07:44 PM
After the first attempt to press in the bushing. Watch out for pinching the rubber edge between the piston and the eye-bolt. Ask me how I know.
