bkrantz
May 6 2022, 07:57 PM
Installed.
bkrantz
May 6 2022, 08:00 PM
My lid was missing the trunk safety bumper. Here is the new rubber piece, but I did not have the metal retaining brace.
bkrantz
May 6 2022, 08:01 PM
So I made a substitute from 1/16" aluminum.
bkrantz
May 6 2022, 08:02 PM
Installed.
bkrantz
May 6 2022, 08:05 PM
I had time to play with the layout of PORSCHE on the grille. It might not be stock, but I made room for the 914World badge on the right side. Now I need the postal service to deliver the retaining speed nuts I ordered.
nivekdodge
May 6 2022, 08:52 PM
QUOTE(bkrantz @ May 5 2022, 10:39 PM)
Thanks, guys. Off the top of my head I can't think of anything major. I might suggest waiting to install carpeting until as much as possible, even engine start-up, is done and confirmed working.
Your quite welcome. I'm actually disappointed the nights you don't post.
Kevin
bkrantz
May 7 2022, 07:54 PM
OK, today is the day. Time to put the car on its own feet, er, wheels.
One last look at the car up in the air. It has been on jack stands or a rotisserie since September of 2019. I think that means almost 3 years.
bkrantz
May 7 2022, 08:05 PM
All 4 wheels went on easy. I take that as a good sign.
bkrantz
May 7 2022, 08:08 PM
bkrantz
May 7 2022, 08:10 PM
Front wheel clearance. Pretty even on both sides but about 25 1/2 inches from the fender lip to the ground.
bkrantz
May 7 2022, 08:11 PM
Rear clearance. Fender lip about 23 1/2 inches high.
bkrantz
May 7 2022, 08:12 PM
Front rocker seam height, about 7 1/2 inches.
bkrantz
May 7 2022, 08:14 PM
Rear rocker seam height, almost 8 inches.
My first guess is that the car is about 2.5 inches too high. This might be good for a safari style 914, but not what I have in mind.
bkrantz
May 7 2022, 08:15 PM
I also measured the angle of the front A-arms, and got 10° on both sides. My guess is that this should be more like 2 or 3°.
Tomorrow I can start trying to lower both ends.
bkrantz
May 7 2022, 08:18 PM
Too soon for real measurements, but I dug out my camber gauge. This dates from my racing days in the 80s and 90s, but was useful back then.
bkrantz
May 7 2022, 08:22 PM
Trying to remember how to use the gauge, just long enough for 15" wheels. Anyway, I got something like +0.2° camber in the front on both sides, and -0.25° and +1.25° in the rear. Of course, the camber will change as the car gets lowered, so these numbers are not quite real. But I am happy that I did not see anything like 5°!
ndfrigi
May 7 2022, 08:55 PM
I think you should roll the car back and forth so it will seat well and get the proper height.
930cabman
May 8 2022, 06:07 AM
QUOTE(ndfrigi @ May 7 2022, 08:55 PM)
Agreed, even better take her around the block to settle the suspension
iankarr
May 8 2022, 06:44 AM
Congrats! Huge milestone. Here’s the “official” factory diagram for the front ride height in case you don’t have it. Keep in mind that this is for stock tires…and rumors are that the DOT mandated a slightly higher rake in front to optimize bumper positioning. I think having the front about an inch lower still looks stock and handles great…but I’m sure the suspension safety gurus will chime in. Small changes in the adjuster have a bigger effect than you might expect. But as others have said, the car needs to bounce/settle between every adjustment to really see the difference.
Again…super impressive work and thanks so much for detailing every step so well. This thread will be useful forever.
EDIT: revised pic (replaces the one I mistakenly uploaded for 911)
Cairo94507
May 8 2022, 06:45 AM
@bkrantz - Bob, absolutely a milestone to get her back on her own feet.
I am sure you will get the height sorted to your liking in no time.
bkrantz
May 8 2022, 07:50 PM
QUOTE(930cabman @ May 8 2022, 06:07 AM)
Yes, but that will have to wait until I actually attach the windshield.
bkrantz
May 8 2022, 07:52 PM
QUOTE(iankarr @ May 8 2022, 06:44 AM)
Click to view attachmentThanks, Ian. I do want the front to be level or just a bit lower. See my other posts today about following the factory method.
bkrantz
May 8 2022, 07:55 PM
To get the car lower, I removed the rear springs/shocks. Step 1 is disconnecting the sway bar links.
bkrantz
May 8 2022, 07:56 PM
Shock and spring on the bench.
bkrantz
And all apart.
bkrantz
May 8 2022, 07:57 PM
The perch was set on the 4th groove from the bottom.
bkrantz
May 8 2022, 07:58 PM
Just to see how low the car can get, I moved the perch to the lowest groove.
bkrantz
May 8 2022, 08:02 PM
Of course, when reassembled, the spring is now shorter than the full shock length. I will think about tying the spring to the upper and lower perches.
bkrantz
May 8 2022, 08:06 PM
The rear sits lower now, by about 1.5". I think I was able to get the springs on bot sides to seat properly in the upper perches.
bkrantz
May 8 2022, 08:07 PM
Tire clearance inside the right fender is tight--maybe a bit less than 1/8". The left side clears by about 1/4".
bkrantz
May 8 2022, 08:10 PM
Then I worked to lower the front. I remembered to empty the weight I had in the frunk (that helped keep the weight balance forward).
bkrantz
May 8 2022, 08:12 PM
I then jacked up each side and unscrewed the torsion bar adjusters two full turns.
bkrantz
May 8 2022, 08:13 PM
Front A-arm angles both dropped from 10° to 8°.
bkrantz
May 8 2022, 08:17 PM
I also measured the height of the torsion bar centers about 7.4" on both sides. Subtracting this from the hub center height (11.8") gives 4.4". The factory spec is 3.5".
bkrantz
May 8 2022, 08:20 PM
But to get the front lower, I will need to reset the caps on the torsion bars since the adjuster screws are almost bottomed out.
bkrantz
May 8 2022, 08:21 PM
The car is lower than yesterday, but now the nose is high.
Cairo94507
May 9 2022, 06:43 AM
Is 1/8" enough clearance on the rear fender well lip? I am not sure how much these wheels move outward at the top when driving. I can slip my pinky finger between my tires and the rear lips. I was very concerned about tires rubbing anything painted when selecting tires.
Here is mine sitting in the driveway Friday after a little drive. I do like the 914 low, but I do not want to be dragging over speed bumps. But they look so much better, in my mind, when lowered. BTW, I am running deep 6 wheels with 195x55x15 Yokohama tires. If I could have got 205x60x15 tires I would have.
bkrantz
May 9 2022, 07:17 PM
QUOTE(Cairo94507 @ May 9 2022, 06:43 AM)
Click to view attachmentThat looks good.
I agree that 1/8" is not enough. I started working on that today.
bkrantz
May 9 2022, 07:23 PM
Ride height fun day 3. To lower the front more, I had to reset the torsion bar caps. Here is the right side the way I first installed it (with the adjusting screw removed).
bkrantz
May 9 2022, 07:24 PM
New position, to maximize the amount I can lower it.
bkrantz
May 9 2022, 07:25 PM
Same on the left side.
bkrantz
May 9 2022, 07:27 PM
After another round of bouncing and rolling, I first checked the A-arm angles. 5° on the left.
bkrantz
May 9 2022, 07:28 PM
And 5° on the right. This might be as low as I want to go.
bkrantz
May 9 2022, 07:30 PM
Torsion bar centers are now both at 6.8" above the floor, about 3/4" lower than yesterday. Front fender lips are now 24.4 (L) and 24.5 ®.
bkrantz
May 9 2022, 07:32 PM
The car now sits about level, with the rocker seam about 6.3" above the floor F and R on both sides.
bkrantz
May 9 2022, 07:33 PM
Since I had to pull the rear shocks again anyway, I decided to raise the rear just a bit.
bkrantz
May 9 2022, 07:35 PM
I moved the spring perch up 1 groove.
bkrantz
May 9 2022, 07:36 PM
To tie the spring to the upper perch, I drilled a pair of holes, and then smoothed the edges.
bkrantz
May 9 2022, 07:38 PM
I got out my trusty safety wire and pliers. I used to wire up all kinds of stuff on race cars in the 90s and 2000s.
bkrantz
Upper perch wired to the spring.
