bkrantz
Mar 25 2020, 08:20 PM
Yep, some quality time ahead.
911GT2
Mar 26 2020, 06:28 AM
QUOTE(bkrantz @ Mar 23 2020, 06:49 PM)
MIG time today. First, the patch in the left side of the cowl.
I think it would help to set the wire feed just a bit down.
Less time grinding the welds down.
bkrantz
Mar 26 2020, 07:28 PM
QUOTE(911GT2 @ Mar 26 2020, 06:28 AM)
Thanks for the suggestion. Each day it seems like the MIG responds differently.
bkrantz
Mar 26 2020, 07:33 PM
After more tweaks and bends, and cutting the top seam to fit, I clamped the fender in place. I then started measuring and comparing from right side to left side.
bkrantz
Mar 26 2020, 07:35 PM
I also propped the frunk lid in place, a good reference since this piece (not from this car) is almost certainly straight.
bkrantz
Mar 26 2020, 07:37 PM
Fit by the cowl (the fender is just a bit low and too far out).
bkrantz
Mar 26 2020, 07:39 PM
The front corner. The front panel still needs to shift inward, confirmed by measured lengths and angles.
bkrantz
Mar 26 2020, 07:41 PM
Along the headlight box, nearly there.
bkrantz
Mar 26 2020, 07:42 PM
A-pillar inside.
bkrantz
Mar 26 2020, 07:46 PM
A-pillar outside.
bkrantz
Mar 27 2020, 08:32 PM
Still trying to assess and adjust the fender fit. I would like to bolt on the door, but really can't without setting the body down from the rotisserie, and removing the braces (which would require cutting). So I made a cardboard template directly from the door, and got it as close as I could accounting for the curvature. I think it is accurate except for the upper part of the leading edge.
bkrantz
Mar 27 2020, 08:34 PM
Gaps are about 3/16 inch front...
bkrantz
And rear. I don't think the fender should shift any more rearward (and probably not forward).
bkrantz
Mar 28 2020, 06:45 PM
No 914 work today. I did some office work in the morning, and then started on a big outdoor project: removing and thinning the scrub oak that are too close to the house. This should help reduce danger from brush fires.
Here's the boss checking the first 10 minutes of work.
bkrantz
Mar 29 2020, 07:44 PM
After more brush clearing, I got back to the 914, still in measuring mode. I marked more reference points, and compared distances and angles from right to left.
bkrantz
And more.
bkrantz
Mar 29 2020, 07:46 PM
I also installed the eyebrows, as another way to check alignment and compare. Here's the right side from above.
bkrantz
Mar 29 2020, 07:47 PM
Left side from above.
bkrantz
Right side from in front.
bkrantz
Mar 29 2020, 07:48 PM
Left side from in front.
bkrantz
Mar 29 2020, 07:51 PM
To me, the alignment looks pretty good--about as good on the right as on the left, and the dimensions are within 1/16 from side to side in most cases.
The only mismatch is the recess in the fender lap edge, where it clears the mounting area in the headlight box for the pivot.
bkrantz
Mar 29 2020, 07:52 PM
Compared to the left side, where the recess sits more centered above the mounting point.
bkrantz
Mar 30 2020, 08:27 PM
With the encouragement from fellow 914Worlders, I decided to do the right thing and mount the door in order to assure a good fit for the front fender. To do that, I had to remove the interior brace. And to do that, I had to lower the car onto jack stands and take the weight off the rotisserie mounts.
Odd to see the interior looking empty, without the brace for the first time in months.
bkrantz
Mar 30 2020, 08:29 PM
I had doubts that the brace could come out in one piece, but with a bit of persuasion it did.
bkrantz
Mar 30 2020, 08:34 PM
Here's the door in place, without much adjustment.
bkrantz
Mar 30 2020, 08:36 PM
The rear gap looks just a bit narrow, but even from top to bottom.
bkrantz
Mar 30 2020, 08:37 PM
The front gap is a little wider, but also even.
bkrantz
Mar 30 2020, 08:39 PM
At the top, where the door, fender, and cowl come together, it looks good (the top of the door needs to move in--easy adjustment). I am feeling good about the fender position fit.
sixnotfour
Mar 30 2020, 08:49 PM
raynekat
Mar 30 2020, 09:13 PM
Bob, my car has a slightly wider door gap in the leading edge (front) vs the trailing edge (rear). Just like yours. Now that doesn't mean it's correct, but that's just how mine is.
bkrantz
Mar 31 2020, 08:43 PM
Somewhere between OCD perfection and famous 914 factory imprecision is the happy way. Or just keep the car in the dark.
bkrantz
Mar 31 2020, 08:45 PM
Once last session to check the fender fit. I adjusted the door to align better.
bkrantz
Mar 31 2020, 08:47 PM
The final judgement: this is good enough to proceed, and get the fender welded on.
Kansas 914
Apr 1 2020, 05:46 AM
Great work Bob!
I should have my cars out of their Winter nap soon if you need reference.
Happy April - stay well - cheers!
bkrantz
Apr 1 2020, 07:55 PM
Thanks, Mike. I agree that we got our last snow in town, and the city has been cleaning the grit off the roads.
I appreciate your offer, and will probably come up with questions and needs for measurements!
bkrantz
Apr 1 2020, 07:56 PM
Getting on with the final fender fit, working on all the seams and junctions now, starting with the top seam near the cowl.
bkrantz
Apr 1 2020, 07:57 PM
And near the headlight box.
bkrantz
Apr 1 2020, 07:59 PM
And the junction with the front panel. Fun fitting lumpy to lumpy.
bkrantz
Apr 2 2020, 08:04 PM
More fiddly work today. Welded the holes and tears in the fender, and some other minor bits.
bkrantz
Apr 2 2020, 08:07 PM
And some adjustments to the front flange and the tabs on the headlight box wall.
I sure hope all this slow, deliberate fitting before I weld the fender on pays off.
bkrantz
Apr 3 2020, 07:46 PM
No 914 work today, since I spent the afternoon clearing brush and got pretty tired. But at least that job is done in time for our annual city curbside waste collection next week.
I did have enough energy to sit, look over the car, and make a list of all the things still to do before the rough body work is done. Even with some detail, the list fits on one page. The end is in sight!!!
bkrantz
Apr 4 2020, 08:48 PM
Last prep job is filling the gap in the weatherstrip channel. When I cut the fender for removal last year, I sliced down the middle of the channel.
bkrantz
Apr 4 2020, 08:49 PM
Here's the patch, made from more recycled 914 sheet metal. I even got some curvature to match the overall arc.
bkrantz
Apr 4 2020, 08:50 PM
Welded in place, ground down, and trimmed to fit.
bkrantz
Apr 4 2020, 08:53 PM
And finally, after fooling with it for almost 2 weeks, here is the fender welded in place. The alignment looks good--I hope I can say that after final assembly with the frunk lid and bumper in place.
bkrantz
Apr 5 2020, 08:19 PM
Today, I finished the rest of the plug welds inside and along the front seams, and did some quick grinding.
bkrantz
Apr 5 2020, 08:20 PM
And completed welding the seam in the top channel. The fender should be pretty well stuck on.
bkrantz
Apr 5 2020, 08:23 PM
I removed the door, re-installed the interior brace, and lifted the car off the jack stands. Next is the first of the "minor" list jobs, tidying up the rear panel.
bkrantz
Apr 6 2020, 08:33 PM
Got a start today, on the left side. When I last touched this area in December, I left some crude weld spots.
bkrantz
Apr 6 2020, 08:34 PM
After some grinding, a quick check of tail light fit.
