bkrantz
Apr 12 2023, 07:34 PM
Before tempting fate too much, I poured in one quart. Watching the floor--no drips (yet).
bkrantz
Apr 12 2023, 07:35 PM
My next task is dealing with brakes. First step: remove the Textar pads and go back to Porterfields. Originally, I could get the front brakes to lock but not with Textar.
bkrantz
Apr 12 2023, 07:37 PM
Starting in the front, Textar pads removed.
bkrantz
Apr 12 2023, 07:38 PM
I lightly scuffed the disk with some medium emery paper.
bkrantz
And did the same with the pads.
bkrantz
Apr 12 2023, 07:40 PM
Left front done.
bkrantz
Apr 12 2023, 07:41 PM
And the right front.
bkrantz
Apr 12 2023, 07:43 PM
I started on the rears, but got side-tracked. The retaining ring for the inner piston bellows fell out. This is a job for tomorrow.
bkrantz
Apr 13 2023, 07:46 PM
No drips! So I put in another 2 quarts.
And then got distracted by other tasks in the garage.
bkrantz
Apr 18 2023, 08:06 PM
I had a few minutes between other stuff today, and searched out a tool to seat the caliper seal retaining ring. I found one in my wife's spice cabinet. Don't tell her.
bkrantz
Apr 18 2023, 08:08 PM
Tool in use. Just big enough to fit over piston.
bkrantz
Success (I hope).
bkrantz
Apr 18 2023, 08:09 PM
Uh-oh. The tool looks a little worn. Now to get it back to the kitchen.
Dion
Apr 19 2023, 07:13 AM
necessity the mother of invention!
930cabman
Apr 19 2023, 09:26 AM
QUOTE(bkrantz @ Apr 18 2023, 08:09 PM)
Oops, good thing your wife is forgiving, or get that hunk of junk out of the garage for once and for all
bkrantz
Apr 19 2023, 07:36 PM
QUOTE(Dion @ Apr 19 2023, 07:13 AM)
And trying to not get caught.
Puebloswatcop
Apr 20 2023, 05:29 PM
Well Bob, I think she might have you pegged this time. Nice tool invention though.. I will keep it in mind......LOL
bkrantz
Apr 22 2023, 09:11 PM
QUOTE(Puebloswatcop @ Apr 20 2023, 05:29 PM)
Well, I got busted. She caught me before I could hide the jar in the back. At least parsley is not expensive or important, so I got off with a warning.
bkrantz
Apr 26 2023, 07:22 PM
I had a distracting week, especially with a good friend from Scotland who spent an extra long weekend, when we drank a good bit of the whisky he brought.
Once I sobered up, I finally finished swapping the brake pads, back to the Porterfield pads I started with. Here I have the right rear ready for adjustment.
bkrantz
.004" clearance.
bkrantz
Apr 26 2023, 07:23 PM
And I had a chance to use my Facom angle wrench, the perfect tool for the outer adjuster.
bkrantz
Apr 26 2023, 07:24 PM
Left side done, too.
bkrantz
Apr 26 2023, 07:25 PM
With that, I have done just about everything on the winter list.
FlacaProductions
Apr 26 2023, 07:35 PM
You set the inside, as well - right?
bkrantz
Apr 27 2023, 07:54 PM
QUOTE(FlacaProductions @ Apr 26 2023, 07:35 PM)
Yes I did--thanks for the reminder check. And the pedal feels very firm so I will skip another round of bleeding for now.
bkrantz
Apr 30 2023, 06:40 PM
Still thinking about the somewhat weak brake performance from last summer, I remembered to see how much flex the master cylinder shows with the pedal pushed hard. With me in the car and my wife looking in from the side, I pushed and she said "It moves!"
When I restored the floor the area around the pedal cluster looked very solid.
bkrantz
Apr 30 2023, 06:42 PM
I pulled the splash pan off and confirmed that I could pull the MC down . The motion is mostly vertical.
bkrantz
Apr 30 2023, 06:45 PM
I know that people have applied different devices that brace the MC against the suspension cross tube. For fun, I tried to create something new. Here's my solution, a section of 1/8 x 1.5" bar, with a short bracket welded to it. I notched the bar to fit between the trailing braces on the cross tube.
bkrantz
Apr 30 2023, 06:47 PM
Close up of the bracket, made from a piece of 1/8 x 3/4" stock.
bkrantz
Apr 30 2023, 06:50 PM
First installation. I know the hose clamp is a bit ghetto, but I want to see how it works. I used some 1/8" dense rubber sheet as a pad. The end of the MC sits in metal to metal contact on the new bracket.
bkrantz
Right end.
bkrantz
Apr 30 2023, 06:52 PM
The MC seems much stiffer when I pulled on it, and my wife claims it did not move when I pushed hard on the brake pedal. This might work. I will test it on the road, and then see if I can refine the mounting method.
930cabman
May 1 2023, 12:23 PM
How is she running? oil leak?
bkrantz
May 1 2023, 08:34 PM
QUOTE(930cabman @ May 1 2023, 12:23 PM)
I have to admit I don't know yet--but stay tuned.
bkrantz
May 1 2023, 08:36 PM
I decided to add one more brace to the master cylinder, and made a sandwich of two 1/4" aluminum scrap pieces. They fit snug and will keep the MC from flexing forward.
bkrantz
May 1 2023, 08:37 PM
I re-installed the splash shield. Some dirty spots hide the lumpiness.
bkrantz
May 1 2023, 08:39 PM
Time to put the wheels on--got out the mounting lugs, even though those little 914 Fuchs wheels are nice and light.
bkrantz
May 1 2023, 08:41 PM
My 914 is back on its own wheels for the first time since last December.
bkrantz
May 1 2023, 08:42 PM
That pretty much clears the winter task list.
bkrantz
May 1 2023, 08:44 PM
OK, here's the start to the driving season list. I really want to learn Tuner Studio and optimize the MegaSquirt this year.
930cabman
May 2 2023, 05:58 AM
Short lists are good
Puebloswatcop
May 3 2023, 05:37 PM
Someday I hope my list gets that short.....
bkrantz
May 3 2023, 07:41 PM
Busy garage day. First I put the summer tires on my 911.
bkrantz
May 3 2023, 07:42 PM
Then I put the street treads on my Suburban (saving the AT tires for the dirt).
bkrantz
May 3 2023, 07:43 PM
Then I fired up the 914, let it warm up, and balanced the idle setting air flow through the L and R throttle bodies.
bkrantz
May 3 2023, 07:44 PM
Last parts to install: air filters.
bkrantz
May 3 2023, 07:45 PM
That's 100% of the engine bay again.
bkrantz
May 3 2023, 07:47 PM
I went for a 20 minute drive and all was good. Best of all, the brakes finally feel pretty strong, even with the pads not quite bedded in again. I felt a pull to the right with hard braking.
Stopped to fill the tank on the way home.
bkrantz
May 3 2023, 07:49 PM
Some other good news: I like my new oil pressure gauge. This is at about 1500 RPM. At idle when hot I saw about 10 psi. When running at speed I think it was about 40.
bkrantz
May 3 2023, 07:52 PM
I almost forgot I replaced the door stays. Nice for the doo to stay open on a slight incline.
In other news, the odometer now works!
