bkrantz
Jul 5 2020, 08:31 PM
New tool in use.
bkrantz
Jul 5 2020, 08:32 PM
Pressure relief valve parts.
bkrantz
Jul 5 2020, 08:34 PM
More inspection of the case. I am still waiting on new solvent for my parts cleaner.
bkrantz
Jul 5 2020, 08:35 PM
I found evidence of where a PO got rough separating the case halves.
bkrantz
I swear it wasn't me!
bkrantz
Jul 5 2020, 08:36 PM
Cylinder head marking 1.
bkrantz
Jul 5 2020, 08:37 PM
Marking 2.
bkrantz
Jul 5 2020, 08:38 PM
The new work list.
ClayPerrine
Jul 6 2020, 07:18 AM
QUOTE(bkrantz @ Jul 5 2020, 09:35 PM)
That's gonna cause an oil leak.....
Kansas 914
Jul 6 2020, 07:30 AM
Bob,
Do you plan on tapping/threading the oil galley plugs?
EDIT: I looked at previous pictures and it appears to be done already.
bkrantz
Jul 6 2020, 08:32 PM
QUOTE(ClayPerrine @ Jul 6 2020, 07:18 AM)
Most likely. On the list to fix.
bkrantz
Jul 6 2020, 08:33 PM
QUOTE(Kansas 914 @ Jul 6 2020, 07:30 AM)
Bob,
Yeah, Mike--already done for all the galley plugs.
bkrantz
Jul 7 2020, 07:59 PM
More inspection today.
The left cylinder head has a pulled exhaust stud.
bkrantz
Jul 7 2020, 08:01 PM
The type 1 oil pump made contact, probably with a camshaft. But not the cam I removed, since the bolt heads on the cam gear are pristine.
bkrantz
Jul 7 2020, 08:04 PM
Some ID info, cast into the cam. This looks like a CWC cam. But with an intake lift of about .318 and exhaust lift of .306, it is far from stock--and probably not compatible with the stock FI.
bkrantz
Jul 8 2020, 08:06 PM
I stopped by the body shop today. They finished stripping the paint yesterday, with a dustless blaster rig.
bkrantz
Jul 8 2020, 08:07 PM
First good news: no surprises under the paint.
bkrantz
Jul 8 2020, 08:08 PM
Second good news: the guys at the shop at least acted reasonably impressed with all my work.
bkrantz
Jul 8 2020, 08:10 PM
The shop owner just bought a rotisserie, and will keep my car mounted for now, probably through painting the underside.
bkrantz
Jul 8 2020, 08:11 PM
Shop owner Lin Coates.
Lilchopshop
Jul 9 2020, 08:14 AM
Looking really good!
Can’t wait to get to that point on my rustoration! I think a a few months away still, but seeing this gives me huge motivation. One question. What is the shop going to do with the existing seam sealer? I’ve had to dig a lot of it out in order to repair rust and I’m debating taking all of it out before blasting. My thought is that this would uncover any more rust that may be lurking beneath and would allow for a good coat of primer under the new seam sealer. Your opinion on this?
bkrantz
Jul 9 2020, 09:03 PM
QUOTE(Lilchopshop @ Jul 9 2020, 08:14 AM)
During all my work, I probed the existing sealer, especially around the edges. Anything that looked detached or with evidence of rust underneath, I removed--at least until I found clean metal. The shop will continue with this strategy. I did not want to remove all existing sealer. BTW, my shop owner is a firm believer in applying sealer (and filler) directly to metal, and then prime over that.
bkrantz
Jul 10 2020, 08:37 PM
I got my parts washer going again today with new solvent, and did a quick cleaning of the engine case. Looks like the previous rebuild used black silicone on everything, including the case seam (but red silicone on the push rod tubes).
raynekat
Jul 10 2020, 09:39 PM
QUOTE(bkrantz @ Jul 10 2020, 07:37 PM)
Better get a case of that "Goof Off" stuff.
bkrantz
Jul 11 2020, 08:13 PM
QUOTE(raynekat @ Jul 10 2020, 09:39 PM)
I don't want to mess things up with the wrong solvent. I expect the machine shop to know better.
bkrantz
Jul 11 2020, 08:16 PM
While taking a break from cleaning engine parts, I decided to make an official 914 bracket for my engine stand. This mount to the right half of the case, with two thick-wall tubes for the bolts.
bkrantz
Jul 11 2020, 08:17 PM
I made the semi-circle ring that rests on the case flange from 3/16 by 1.5 inch bar.
bkrantz
Jul 11 2020, 08:19 PM
The part that attaches to the engine stand plate is 1/4 by 2 inch bar.
bkrantz
Jul 11 2020, 08:20 PM
This should be a fun TIG welding project for my son next week.
Kansas 914
Jul 12 2020, 06:53 AM
Good job!
I should have taken this opportunity to build an engine along with you.
I have all parts to build a 2.0 in storage. The case was decked by Len Hoffman - new pistons and cylinders - wrist pins machined by Jon Larson (Cap'n Krusty).
Another project for another day...
bkrantz
Jul 12 2020, 10:07 PM
Mike, you just have to give up sleeping.
Kansas 914
Jul 13 2020, 01:22 PM
QUOTE(bkrantz @ Jul 12 2020, 10:07 PM)
Sleep is highly over-rated.
Are you going to use the machine shop out by Cortez?
bkrantz
Jul 13 2020, 08:08 PM
QUOTE(Kansas 914 @ Jul 13 2020, 01:22 PM)
Not sure yet. I have been talking with Dan at Competition Engineering in Phoenix.
bkrantz
Jul 13 2020, 08:09 PM
I cleaned up the heads a bit. Still lots of baked-on crud. I discovered the #1 spark plug hole has an insert.
bkrantz
Jul 13 2020, 08:11 PM
And the right side sheet metal has a bunch of cracks, and a nasty PO repair.
bkrantz
Jul 13 2020, 08:14 PM
I disassembled the blower housing. Yes, that is awesome red paint.
bkrantz
Jul 13 2020, 08:16 PM
Separating the front and rear was a bit difficult, with the front stuck on the locater pins.
bkrantz
Jul 13 2020, 08:18 PM
After some penetrating oil, and patience, and a bit of gentle prying from the inside, it cam apart.
76-914
Jul 14 2020, 07:49 AM
Great progress Bob. I like your resourcefulness when needing a tool or part. Momentum must be maintained and can be your best friend at times. BTW, received the front trunk metal piece. Thx again.
mbseto
Jul 14 2020, 11:30 AM
QUOTE(bkrantz @ Jul 11 2020, 10:16 PM)
...I decided to make an official 914 bracket for my engine stand...
I need to make one of these, I'll definitely crib from your notes. Nice work!
bkrantz
Jul 14 2020, 08:02 PM
QUOTE(76-914 @ Jul 14 2020, 07:49 AM)
Yeah, momentum and not knowing any better sometimes.
Glad the panel section will help.
bkrantz
Jul 14 2020, 08:03 PM
I spent some quality time with the blower housing and the parts washer today. Most of the dirt and grease came off, but not the lovely red paint.
bkrantz
Jul 16 2020, 09:29 PM
My son came back to our place again, and I put him to work on the TIG welder. Here's the 914 half-case bracket tacked together.
bkrantz
Jul 16 2020, 09:30 PM
All done.
bkrantz
On the engine stand.
bkrantz
Jul 16 2020, 09:31 PM
It works!
bkrantz
Jul 16 2020, 09:33 PM
I also had time to run all the engine sheet metal through the solvent washer. Most of the pieces look very good, with some work to do on the big upper pieces.
bkrantz
Jul 17 2020, 08:54 PM
I stopped by the body shop today to check on progress. They completed a bit more metal work and welding, and have moved onto filler and smoothing.
bkrantz
Jul 17 2020, 08:55 PM
Right front detail.
bkrantz
Jul 17 2020, 08:56 PM
Rear view.
