bkrantz
Oct 9 2021, 07:52 PM
Ready for new pushrod tubes and seals.
bkrantz
Oct 9 2021, 07:56 PM
Lots of oil on the seals before rolling them onto the tubes, and then I pushed the tubes into place.
bkrantz
Oct 9 2021, 07:57 PM
I even remembered the pushrod retaining wires.
bkrantz
Oct 9 2021, 08:02 PM
After lubing the rockers, shafts, spacers, pushrods, and adjusters, I put everything together and torqued the new high-strength retaining nuts. And then I gave the adjusters a quick clearance setting. One side done!
bkrantz
Oct 10 2021, 08:10 PM
I just got started on the other side today, when the weather outside proved too tempting.
bkrantz
Oct 10 2021, 08:13 PM
We took a 3 hour hike in the San Juan Mountains, and the aspen colors were stunning.
nivekdodge
Oct 10 2021, 09:35 PM
QUOTE(bkrantz @ Aug 5 2021, 09:44 PM)
Here's the re-plated latch installed.
Those pieces look fantastic, may I ask the process?
Puebloswatcop
Oct 11 2021, 07:57 AM
QUOTE(bkrantz @ Oct 10 2021, 07:13 PM)
That is the one thing I do miss about Colorado, Fall is so beautiful
bkrantz
Oct 11 2021, 07:20 PM
QUOTE(nivekdodge @ Oct 10 2021, 09:35 PM)
Easy process! Just clean the old parts and send to FPS (www.fpswi.com), and specify what finish you want. They are quick and cost-effective.
bkrantz
Oct 11 2021, 07:23 PM
Left side valve gear in place and quickly adjusted.
bkrantz
Oct 11 2021, 07:25 PM
OK, finally--time to keep going on engine assembly.
I reached into the powder coat part box, with everything still wrapped.
bkrantz
Pretty valve covers and new gaskets.
bkrantz
Oct 11 2021, 07:27 PM
Valve covers in place--looks more complete!
bkrantz
Oct 11 2021, 07:29 PM
Oil filter mount and new filter. Gotta remember to fill this later when I get close to startup.
bkrantz
Oct 11 2021, 07:32 PM
Then it was time for the oil cooler. I bought a new "Original Equipment" version from Pelican.
bkrantz
Oct 11 2021, 07:34 PM
A test fit, and interference with the bracket for the EFI Hall sensor. So the sensor and bracket had to come off.
bkrantz
Oct 11 2021, 07:37 PM
I also found very minor interference with the upper nut on the oil filter mount. That led to a quick re-contouring of the cooler frame. It is all aluminum so pretty easy to adjust.
bkrantz
Oct 11 2021, 07:39 PM
Then new cooler seals.
bkrantz
Oct 11 2021, 07:40 PM
New oil cooler mounted, but...
bkrantz
Oct 11 2021, 07:42 PM
The replacement cooler has extended edges on the outer wall. Compare to the dirty original.
bkrantz
Oct 11 2021, 07:44 PM
The wall is also aluminum, so pretty easy to trim with a new blade.
bkrantz
Same on the other side.
bkrantz
Oct 11 2021, 07:46 PM
Good clearance now for the bracket.
iankarr
Oct 11 2021, 08:10 PM
QUOTE(bkrantz @ Oct 11 2021, 09:29 PM)
There's some debate about this. Jake Raby advises not to fill the filter first...so maybe one less thing to do
Everything looks awesome, as usual!
http://www.914world.com/bbs2/index.php?sho...p;#entry1595700
bkrantz
Oct 12 2021, 07:34 PM
QUOTE(iankarr @ Oct 11 2021, 08:10 PM)
http://www.914world.com/bbs2/index.php?sho...p;#entry1595700Thanks Ian. And interesting info on pre-filling the filter.
bkrantz
Oct 12 2021, 07:36 PM
Next, the engine mount brackets and bushings.
bkrantz
Oct 12 2021, 07:37 PM
Done.
bkrantz
Oct 12 2021, 07:39 PM
Then the thermostat. Here are the old and new parts.
bkrantz
Oct 12 2021, 07:40 PM
I installed the pulley and mounting bolt with some teflon dry lube.
bkrantz
Oct 12 2021, 07:48 PM
New thermostat. I hope this is not the operating temp.
bkrantz
Oct 12 2021, 07:50 PM
And new cable, which looks very suspiciously like a bicycle gear shift cable.
bkrantz
Oct 12 2021, 07:52 PM
Assembled on the mounting bracket (another powder-coated piece).
bkrantz
Installed.
bkrantz
Oct 12 2021, 07:53 PM
Checking the whiteboard--making progress.
bkrantz
Oct 12 2021, 08:03 PM
Next up: the blower housing. I had this lightly blasted to remove the PO red paint. Instead of leaving the magnesium bare, I plan to paint this with epoxy matte clear. Any opinions?
Cairo94507
Oct 13 2021, 06:31 AM
I think the epoxy matte clear is the perfect choice. Your car and work is just amazing.
FlacaProductions
Oct 13 2021, 10:24 AM
Great work here - is that the Awesome Powdercoat thermostat bracket or OEM?
bkrantz
Oct 13 2021, 07:51 PM
Thanks, guys. The thermostat bracket is OEM, done by a local shop, Evolution Powder Coating in Durango--highly recommended.
bkrantz
Oct 14 2021, 08:57 PM
Got to Tucson today, after stopping in Lake Havasu City yesterday, to drop my trans off at California Motorsport.
Here is the alternator rebuilt by Tucson Alternator Exchange.
bkrantz
Oct 14 2021, 08:58 PM
Complete rebuild for $150.
Puebloswatcop
Oct 15 2021, 08:08 AM
Thats a very reasonable price and the product looks great
930cabman
Oct 15 2021, 01:50 PM
QUOTE(bkrantz @ Oct 14 2021, 08:58 PM)
Good value and spending your $$ locally.
Can't beat that with a stick
bkrantz
Oct 15 2021, 05:51 PM
I like to take advantage of resources in Tucson, since I visit here frequently. This city still has lots of grass-roots shops and other old school automotive resources.
So far, besides the alternator, I have used Tucson vendors for bumper rechroming, upholstery work, fuel tank boiling out, and attempts to save my original cylinder heads.
bkrantz
Oct 16 2021, 08:21 PM
No work to report today, but I want to celebrate the 2 year anniversary of my first post.
Here is the car when I picked it up in September 2019.
bkrantz
Oct 16 2021, 08:22 PM
First day in the home garage.
bkrantz
Oct 16 2021, 08:24 PM
Interior stripped out.
bkrantz
Oct 16 2021, 08:25 PM
Engine out. Red paint!
bkrantz
Oct 16 2021, 08:31 PM
Right front inner and outer fender gone, front panel and floor work underway.
bkrantz
Oct 16 2021, 08:36 PM
Rear panel off, right rear outer fender off. Test fit of rear trunk floor--first new sheet metal.
bkrantz
Oct 16 2021, 08:37 PM
Rear back together.
