bkrantz
Jun 24 2023, 08:04 PM
Now thinking about the oil pressure sender. I know there are options, but I am worried most about oil leaks now, so simple is better. I will mount the VDO sender directly to the case, and like with the "aggressive" idiot light.
In the future I might try something else so I can use the stock idiot light sender. I do feel nervous about any flexible hoses, and will keep thinking about options.
bkrantz
Jun 24 2023, 08:06 PM
But the VDO threaded stud is longer than stock.
bkrantz
Jun 24 2023, 08:07 PM
And the VDO sender bottoms out in the case hole.
bkrantz
Jun 24 2023, 08:09 PM
I rummaged through my miscellaneous hardware and found an aluminum M10 spacer. That plus a pair of copper washers should do it.
bkrantz
Jun 24 2023, 08:10 PM
Plus a bit of thread sealant.
bkrantz
Jun 24 2023, 08:11 PM
I sure hope this cures the worst leak I had.
bkrantz
Jun 24 2023, 08:12 PM
A quick check on electrical conductivity--looks good.
bkrantz
Jun 24 2023, 08:14 PM
One more thing. The stock sheet metal hole will not clear the VDO sender.
bkrantz
Jun 24 2023, 08:16 PM
I got out my die grinder for the first time since working on the body in 2021.
bkrantz
Jun 24 2023, 08:17 PM
I painted the raw edges (primer and black). The rest of it is still powder-coated.
bkrantz
Jun 24 2023, 08:18 PM
Then a bit of vinyl edging.
bkrantz
This should work.
bkrantz
Jun 25 2023, 04:21 PM
Mini-marathon today to see if I can get everything back on the motor and be ready for putting in back in the car.
I remembered to check the tightness of the oil pressure release valve cap.
bkrantz
Jun 25 2023, 04:22 PM
That means I get to use my special tool. I was able to tighten the cap about1/4 turn. Maybe another leak?
bkrantz
Jun 25 2023, 04:23 PM
Then the oil cooler, with new seals.
bkrantz
Jun 25 2023, 04:24 PM
As is traditional, a dab of grease to hold them in place.
bkrantz
Cooler installed, but...
bkrantz
Jun 25 2023, 04:25 PM
Not enough clearance to bolt on the oil filter mount. Grrr.
bkrantz
Jun 25 2023, 04:26 PM
So, remove the oil cooler and give the new filter mount gasket a smear of sealant.
bkrantz
Jun 25 2023, 04:28 PM
And bolt on the mount with a new filter. BTW, I have used at least 4 filters since last summer. I think I am getting about 100 mpg (miles per filter).
bkrantz
Jun 25 2023, 04:30 PM
Cooler back on, and make double sure the seals are in place.
bkrantz
Jun 25 2023, 04:31 PM
With everything closed up, I did another cleaning to remove any remaining oil spill residue.
bkrantz
Jun 25 2023, 04:33 PM
Time to start with sheet metal and other air cool system parts. Here's the baffle that mounts behind the oil cooler.
bkrantz
Uh-oh. This also does not clear the VDO pressure sender.
bkrantz
Jun 25 2023, 04:35 PM
Another 10 minutes with the die grinder and the hammer and dolly. This should work.
bkrantz
Jun 25 2023, 04:36 PM
Before I forget, a new head gasket for the intake manifold. I like to install this before the sheet metal to make sure it sits on the head.
bkrantz
Jun 25 2023, 04:37 PM
And another small thing: the Hall sensor and bracket.
bkrantz
Jun 25 2023, 04:38 PM
Check the clearance with the trigger wheel.
bkrantz
Jun 25 2023, 04:39 PM
OK, with motor mounts and the cross bar, ready for the blower housing.
bkrantz
Jun 25 2023, 04:40 PM
Housing installed.
bkrantz
Jun 25 2023, 04:41 PM
Including the 2 bolts on the side for the oil cooler bracket.
bkrantz
Jun 25 2023, 04:42 PM
Right side upper sheet metal.
bkrantz
Thermostat spring and cable.
bkrantz
Jun 25 2023, 04:43 PM
Right side intake manifold.
bkrantz
Jun 25 2023, 04:44 PM
Crank trigger wheel for good. I think I got it in the right position.
bkrantz
Blower cage.
bkrantz
Jun 25 2023, 04:45 PM
Left side duct work.
bkrantz
Right side duct work.
bkrantz
Jun 25 2023, 04:46 PM
Alternator and belt.
bkrantz
Jun 25 2023, 04:47 PM
Alternator lead to starter, and insulated with 3M rubber tape.
bkrantz
Front sheet metal.
bkrantz
Jun 25 2023, 04:48 PM
Speaking of leads, I made a new jumper to connect the "stock" oil pressure sender wire to the VDO sender.
bkrantz
Jun 25 2023, 04:50 PM
It goes here.
bkrantz
Jun 25 2023, 05:11 PM
That's it. The motor is ready to install (again). And test for leaks (again).
Cairo94507
Jun 26 2023, 06:39 AM
Fingers crossed.
bkrantz
Jun 26 2023, 07:06 PM
QUOTE(Cairo94507 @ Jun 26 2023, 06:39 AM)
Fingers crossed.
Thanks.
bkrantz
Jun 26 2023, 07:07 PM
Ready to go up.
bkrantz
Jun 26 2023, 07:08 PM
Engine bolted in place. Then the two bottom sheet metal pieces.
bkrantz
Jun 26 2023, 07:10 PM
CV joints bolted to flanges, with new gaskets and Schorr washers.
bkrantz
Jun 26 2023, 07:11 PM
Shift rod.
