bkrantz
Feb 2 2022, 08:34 PM
Front flex lines and calipers.
bkrantz
Feb 2 2022, 08:36 PM
For good access to the fittings on top, I removed the rear calipers. These were the most leaky junctions.
bkrantz
Feb 2 2022, 08:42 PM
And then re-installed the calipers and connected the flex lines. I still need to get to the fittings on the pressure regulator. But dinner time.
Dutchy914
Feb 3 2022, 03:34 PM
anyone is the E-brake guide (tunnel) standard on all 914's ? I remember my 75 in Netherlands didn't have it.
bkrantz
Feb 3 2022, 08:43 PM
QUOTE(Dutchy914 @ Feb 3 2022, 02:34 PM)
I think so. If you ask the question in a new thread, you will get more answers.
bkrantz
Feb 3 2022, 08:46 PM
I got my spare mounted, a Vredestein Sprint Classic, 155SR-15, on a stock Fuchs wheel.
bkrantz
Feb 3 2022, 08:47 PM
This tire is almost as tall as the ones on my 2017 991.
bkrantz
Feb 3 2022, 08:49 PM
But the 991 rear is just a bit wider.
bkrantz
Feb 3 2022, 08:51 PM
Test fit in the frunk: the width of the tire is just less than the spare cavity (see the tiny gap below the silver straight edge).
bkrantz
Feb 3 2022, 08:53 PM
I dug out the spare retaining hardware.
bkrantz
Feb 3 2022, 08:55 PM
Here's the spare in place and tied down. But the gap towards the rear is about 2 inches, and leaves the floor unsupported.
bkrantz
Feb 3 2022, 08:56 PM
Looking around in my junk pile, I found a pair of brackets I made for something years ago.
bkrantz
Feb 3 2022, 08:57 PM
The bracket is just the right height.
bkrantz
Feb 3 2022, 09:00 PM
I got out some screws and JB Weld.
bkrantz
Feb 3 2022, 09:01 PM
Here's the bracket attached like a prop under the floor.
bkrantz
Feb 3 2022, 09:03 PM
Now the custom floor I made sits level, and supported near the back edge.
bkrantz
Feb 3 2022, 09:04 PM
Last thing today: I checked the brake line attachments at the rear calipers for leaks. The left caliper looks dry.
bkrantz
Feb 3 2022, 09:05 PM
But the right side is still leaking. I will need to work on this side again.
raynekat
Feb 3 2022, 10:07 PM
QUOTE(bkrantz @ Feb 3 2022, 06:53 PM)
Click to view attachmentWhoa, whoa, whoa.....
Dude. Are you actually putting a part looking like this back in that car of yours?
OMGGGGGGGGGGGG
I'm mean the plating, the cleanliness, etc, etc.
I might not be able to sleep tonight without notifying the concour polizei.
hahaha
Looking good as always Bob.
Fun to watch all the progress.
930cabman
Feb 4 2022, 07:22 AM
QUOTE(bkrantz @ Feb 3 2022, 10:05 PM)
Is the tubing "bubble" flared?
My local NAPA informed me of the bubble, I had no prior idea. Single flare, double flare but never heard of a bubble
bkrantz
Feb 4 2022, 08:53 PM
QUOTE(raynekat @ Feb 3 2022, 09:07 PM)
OMGGGGGGGGGGGG
hahaha
Doug, I feel your pain.
I forgot a few things when I sent out my hardware for re-plating. I figure that I should have a few "original" parts on the car, right?
bkrantz
Feb 4 2022, 09:07 PM
QUOTE(930cabman @ Feb 4 2022, 06:22 AM)
Yes, they have bubble flares--and I trust the source (PMB) to provide the correct flares.
bkrantz
Feb 4 2022, 09:09 PM
I got the rest of the old tires removed today, and just in time. These all have some scratches, and even a bit of curb rash, but seem to be straight and true. Just dirty.
bkrantz
Feb 4 2022, 09:12 PM
I ordered Sumitomo HTR A/S in 195/65-15 from Tire Rack yesterday afternoon, and they showed up at 6pm today. No supply chain issues!
bkrantz
Feb 5 2022, 09:31 PM
I started processing the remaining Fuchs wheels so I can get the new tires mounted.
Step 1: remove the valve stem.
bkrantz
Feb 5 2022, 09:33 PM
Step 2: A bit of sanding on the curb rash--at least enough to take down any edges and reduce the visibility. I know this removes the anodizing, but I think the trade-off is worthwhile.
bkrantz
Feb 5 2022, 09:34 PM
Step 3: remove any existing stick-on weights, outside and in.
bkrantz
Feb 5 2022, 09:36 PM
Step 4: use Goof Off to remove the "recent" adhesive residue.
bkrantz
That works well, and easy.
bkrantz
Feb 5 2022, 09:38 PM
Step 5: attack any ancient adhesive residue.
bkrantz
Feb 5 2022, 09:39 PM
Also pretty easy, with Goof Off, and some scraping.
bkrantz
Feb 5 2022, 09:41 PM
Step 6: Attack the crud inside the wheel with cleaner. Note, this wheel and one other have a pretty solid coat of hardened brown crud.
bkrantz
Feb 5 2022, 09:43 PM
I tried letting the cleaner sit for about 20 minutes, and then scrubbing with a Scotch Brite sponge. A lot of scrubbing.
bkrantz
Feb 5 2022, 09:45 PM
After about an hour of scrubbing, this is what I got: partly cleaned but still lots of hard crud.
bkrantz
Feb 5 2022, 09:46 PM
So, Step 7: I tried some more Goof Off. Nothing.
bkrantz
Feb 5 2022, 09:48 PM
Step 8: acetone, no effect.
bkrantz
Feb 5 2022, 09:49 PM
Step 9: painters solvent, no effect.
bkrantz
Feb 5 2022, 09:50 PM
Step 10: Gumout, no effect.
bkrantz
Feb 5 2022, 09:52 PM
Step 12: parts cleaner, no effect.
OK, time for more thinking.
bkrantz
Feb 5 2022, 09:53 PM
I decided to attack the remaining wheel that had "normal" dirt. About 45 minutes with the wheel cleaner got this.
930cabman
Feb 6 2022, 07:12 AM
QUOTE(bkrantz @ Feb 4 2022, 10:07 PM)
What could it be other than the seat or the bubble flare? Is there a torque spec?
bkrantz
Feb 6 2022, 08:04 PM
QUOTE(930cabman @ Feb 6 2022, 06:12 AM)
I don't have a torque spec. I did hear from PMB, and the recommendation is to tighten fittings "aggressively". I will try one more time (waiting on a different wrench to get into the small spaces around the pressure valve).
bkrantz
Feb 6 2022, 08:06 PM
Still working on the two extra-cruddy wheels.
I left one wheel with Chemical Guys cleaner overnight, wrapped in a plastic bag. I was hoping for some magic, but after scrubbing and rinsing, most of the crud is still there.
bkrantz
Feb 6 2022, 08:09 PM
Based on something I found on the web, I tried one more material: iron removing liquid. I think this is based on the idea that the crud is a mix of dust from the disk, pads, and road grime.
bkrantz
Feb 6 2022, 08:11 PM
First application: as it works, it turns purple. It also smells pretty bad, like old-fashioned hair salon perm fluid.
bkrantz
Feb 6 2022, 08:12 PM
After 3 cycles of Iron-X, scrubbing, and rinsing. It works!
bkrantz
Feb 6 2022, 08:14 PM
Unfortunately, my bottle of Iron-X was almost empty, so I only got about one-fourth the way around. More stuff ordered.
raynekat
Feb 6 2022, 09:10 PM
QUOTE(bkrantz @ Feb 6 2022, 06:14 PM)
Viel besser!Slow wins the race.
One thing I found useful in cleaning the anodized Fuchs on 911's was a mixture of white vinegar and hot water.
Not sure if that would be helpful for you on the front sides?
Van914
Feb 7 2022, 05:44 AM
Have you tried Oven cleaner?
930cabman
Feb 7 2022, 12:25 PM
This is one project I am not running towards, just spend a few hours cleaning the exterior surfaces of a trans.
Thanks for posting Bob
