bkrantz
Jul 16 2021, 07:09 PM
Another back-tracking detail. I used some paint to black out the flange of the targa bar that was barely visible behind the pad (in this shot ,the pad is pulled forward a bit). And yes, this pad is not really good enough, but maybe someday...
bkrantz
Jul 16 2021, 07:12 PM
Now, onto the door frames. Here is a pair of new inner door seals.
bkrantz
I trimmed the carpet around the door frame edge.
bkrantz
Jul 16 2021, 07:13 PM
Trimming done.
bkrantz
Jul 16 2021, 07:14 PM
New aluminum sills.
bkrantz
Jul 16 2021, 07:15 PM
And new plastic rivets. BTW, I did discover that the center stud has to first be snapped off the base, and then inserted into the center hole.
bkrantz
Jul 16 2021, 07:16 PM
Left sill installed.
raynekat
Jul 17 2021, 05:04 PM
Too nice....you'll never drive it Bob. Hehe
930cabman
Jul 17 2021, 05:14 PM
True, I would take my shoes off before entering. Great work Bob and thanks for posting
bkrantz
Jul 17 2021, 08:33 PM
Thanks, guys. Maybe drive it inside?
Of course, I have to actually make it run before I worry about driving it.
bkrantz
Jul 17 2021, 08:35 PM
New inner door seals.
bkrantz
Jul 17 2021, 08:36 PM
Left side installed. It bulges a bit along the bottom.
bkrantz
Jul 17 2021, 08:37 PM
Now for the inner sill trim pieces.
bkrantz
Jul 17 2021, 08:38 PM
Installed with screws.
bkrantz
Starting on the right side.
bkrantz
Jul 17 2021, 08:39 PM
And done.
bkrantz
Jul 17 2021, 08:43 PM
I noticed the carpet I tried to stretch into the hand brake recess had pulled loose along one side. I came up with an injection of contact cement.
bkrantz
Jul 17 2021, 08:44 PM
I tried to squirt it around inside the loose area.
bkrantz
Jul 17 2021, 08:46 PM
And then clamped the inner corner in place.
bkrantz
Jul 17 2021, 08:47 PM
I got some rubber sheets, here 1/8".
bkrantz
Jul 17 2021, 08:48 PM
I used one piece to pad the mounting of the charcoal canister.
bkrantz
Jul 17 2021, 08:49 PM
Canister installed.
bkrantz
And then the expansion tank.
Puebloswatcop
Jul 18 2021, 07:40 AM
She is looking beautiful Bob. She is almost whole again, cant wait for the engine to come back.
bkrantz
Jul 18 2021, 07:06 PM
QUOTE(Puebloswatcop @ Jul 18 2021, 07:40 AM)
Thanks. I do hope to get onto the engine again soon.
bkrantz
Jul 18 2021, 07:08 PM
Not too much today, but I cleaned up the plastic tubing segments for the evaporative control system. These could be the last parts that I have to deal with PO red overspray and undercoating.
bkrantz
Jul 18 2021, 07:10 PM
That's better. Once again, Goofoff works well to remove crud, and also leaves a bit of shine on the plastic.
bkrantz
Jul 18 2021, 07:12 PM
Just for fun, I test fit the pieces. I need to get some vent hose and grommets before I can install these for real.
Left front fender well.
bkrantz
Left outer sill.
bkrantz
Jul 19 2021, 08:52 PM
I took the clamps off the carpet in the hand brake lever indentation. It seems stuck on now.
bkrantz
Jul 20 2021, 07:16 PM
While I am waiting for stuff, I got out the fender liner kit from 914 Rubber.
bkrantz
Jul 20 2021, 07:17 PM
First trial fitting, in the front.
bkrantz
Jul 20 2021, 07:18 PM
And the rear.
I need to think about how to best attach these.
raynekat
Jul 20 2021, 11:25 PM
QUOTE(bkrantz @ Jul 20 2021, 06:18 PM)
And the rear.
Here's how I did mine.....
They worked out great and are quick & easy to remove if you need to.
http://www.914world.com/bbs2/index.php?sho...amp;hl=raynekat
bkrantz
Jul 21 2021, 06:21 PM
QUOTE(raynekat @ Jul 20 2021, 11:25 PM)
And the rear.
http://www.914world.com/bbs2/index.php?sho...amp;hl=raynekatThanks, Doug. I had actually book-marked your fender installation. See the following.
bkrantz
Jul 21 2021, 06:24 PM
I decided to keep going with the fender liner installation. Here are the mounting clips from 914 Rubber, now in stainless.
bkrantz
Jul 21 2021, 06:28 PM
Most are designed for pop-rivets (included in the kit). I decided to use screws to attach the liners to the clips, the raynekat method. Two of the clips have riv-nuts attached, but my OCD wants them all the same, so I used a file to undo the rib-nuts. BTW, I treated myself to new files for the first time in at least 30 years--wow!
bkrantz
Jul 21 2021, 06:29 PM
Now all the clips match!
bkrantz
Jul 21 2021, 06:31 PM
On the leading edge, the clips fit over the fender flange deep enough for the holes to line up.
bkrantz
Jul 21 2021, 06:33 PM
On the trailing side, the clip base is not deep enough to reach the hole.
bkrantz
Jul 21 2021, 06:35 PM
This is how far off the hole position is.
bkrantz
Jul 21 2021, 06:36 PM
I tried unfolding the clip, but the stainless stock was too brittle.
bkrantz
Jul 21 2021, 06:41 PM
With the liner seated evenly, the length seems too long, by about 3/4". When I forced the flu length in, the liner does not sit tightly against the inside of the fender.
bkrantz
Jul 21 2021, 06:42 PM
I trimmed the liner with a jig saw.
bkrantz
Jul 21 2021, 06:45 PM
Speed nuts on the clips.
bkrantz
Jul 21 2021, 06:47 PM
I fitted the liner again, marked and drilled the holes, and then screwed the liner to the clips.
bkrantz
Jul 21 2021, 06:49 PM
One problem: when unmolested, the liner sits snug against the outer fender.
bkrantz
Jul 21 2021, 06:50 PM
But the liner is free to shift about an inch to the inside.
bkrantz
Jul 21 2021, 06:51 PM
Rather than drill holes in the inner fender wall I decided to make a small block from aluminum stock and 3M adhesive tape.
bkrantz
Jul 21 2021, 06:52 PM
That should be enough to keep the liner from shifting inward.
