bkrantz
Jan 11 2020, 11:09 PM
QUOTE(sixnotfour @ Jan 10 2020, 02:36 AM)
backdate the attachment method for the heat shield....screws,, see the 70s...
What are the advantages?
raynekat
Jan 11 2020, 11:21 PM
I was thinking....maybe you could put hydrofoils on this car with a prop coming out of the back. Then you wouldn't need to buy that future bike?
I attached the muffler heat shield with screws on my car. It's been ceramic ally coated and is removable....as if I'll ever need to do that. Looks nice tho.
Good work there Bob.
bkrantz
Jan 12 2020, 08:54 PM
QUOTE(raynekat @ Jan 11 2020, 10:21 PM)
Thanks, Doug. Never too many bikes.
aggiezig
Jan 13 2020, 12:17 AM
Great build so far! Enjoyed reading your progress. Man, all that metalwork makes me thankful that I only had to do floors and trunks on my car. Keep up the good work
bkrantz
Jan 13 2020, 11:18 PM
QUOTE(aggiezig @ Jan 12 2020, 11:17 PM)
Thanks. I am actually enjoying this more than I expected. That could change when I get to more finish work.
bkrantz
Jan 20 2020, 09:21 PM
Back from "vacation" from my retired life, where I do some teaching, research, and consulting from my house in Colorado. Spent a week with my son in Arizona, and pretty much did the same thing.
Anyway, getting back to work on the 914, but first had to play with some new tools, including the Fein dust catcher attachment for the grinder. Works pretty well, and started on the welds around the floor seams.
bkrantz
Jan 20 2020, 09:23 PM
Dang, the photo posting still does not want to honor my right side up. I have tried opening and saving photos in different ways--and 914World still posts things sideways.
raynekat
Jan 20 2020, 11:18 PM
Bob....this is what I do with all my photos....and it seems to work.
After you load them on your computer and before posting them, pull them up in some kind of viewer.
On my iMac, it's just the built-in photo viewer.
Then rotate them 90 deg, 90 again, 90 again, and another 90 to get them back to where they started from.
So rotate them through a total of 360 deg (another way to say the above).
Then save them.
Now you should be able to post the pics on 914World (or other sites) right side up.
I don't know why this goofy little photo dance seems to work, but it always has for me.
Gud luk! Ha
bkrantz
Jan 21 2020, 09:35 PM
Thanks, Doug. That may have worked! I reposted the photo to my previous post, and it looks right.
bkrantz
Jan 21 2020, 09:37 PM
No garage work today. I only had a spare hour, and did this instead.
Kansas 914
Jan 22 2020, 06:06 AM
QUOTE(bkrantz @ Jan 21 2020, 08:37 PM)
I had a similar exercise as well.
It was some wet heavy stuff.
sixnotfour
Jan 22 2020, 07:10 AM
In UT. I call that WA. snow...
dust collector//
Kansas 914
Jan 22 2020, 09:33 AM
QUOTE(sixnotfour @ Jan 22 2020, 06:10 AM)
dust collector//
Jeff - I will remember that line.
bkrantz
Jan 22 2020, 10:02 PM
Back to work. First prepping all the joints, grinding out remains of spot welds and cleaning up metal.
bkrantz
Jan 22 2020, 10:04 PM
Then fitting the new floor section. First trim the excess around the edges, and then cut the remaining floor piece to fit. Decided to keep as much of the RD panel as possible since some of the rust extended forward of the cross brace.
bkrantz
Jan 22 2020, 10:06 PM
Other side.
Ferg
Jan 22 2020, 10:35 PM
Just found this thread, Nice work!
Mark Henry
Jan 22 2020, 10:40 PM
QUOTE(bkrantz @ Jan 21 2020, 10:37 PM)
Unique looking house.
raynekat
Jan 22 2020, 11:21 PM
QUOTE(Mark Henry @ Jan 22 2020, 08:40 PM)
It is....but he likes that.
His last house was an igloo.
Kansas 914
Jan 23 2020, 07:28 AM
QUOTE(Ferg @ Jan 22 2020, 09:35 PM)
Ferg,
Bob is doing a great job. It will be nice to have another 914 at Cars & Coffee in Durango!
Bob used to campaign a 914 in Texas a few years ago.
Ferg
Jan 23 2020, 08:11 PM
QUOTE(Kansas 914 @ Jan 23 2020, 06:28 AM)
Ferg,
Sounds like the Durango crew just keeps getting better
bkrantz
Jan 23 2020, 09:27 PM
QUOTE(Mark Henry @ Jan 22 2020, 09:40 PM)
Thanks. We found a local architect who designed the house to fit the site--and our preferences. Of course, I should have made the garage bigger.
bkrantz
QUOTE(raynekat @ Jan 22 2020, 10:21 PM)
Only half the year.
bkrantz
Jan 23 2020, 09:31 PM
QUOTE(Ferg @ Jan 23 2020, 07:11 PM)
Ferg,
I have really enjoyed getting to know the local car crowd, and feel welcomed. If we could only get Colorado DOT to stop laying down gravel instead of sand on winter roads.
bkrantz
Jan 24 2020, 10:07 PM
A few things to do before I can start welding in the floor. Item #1: welding the web of cracks in the left inner long, at the parking brake handle recess. A little sloppy (my excuse: upside down, which I could have corrected by rotating the rotisserie, but...).
bkrantz
Jan 24 2020, 10:08 PM
And then grinding (and then some more welding and grinding).
bkrantz
Jan 24 2020, 10:17 PM
And before I forget, I welded the rear sway bar mounts to the new trunk floor.
bkrantz
Jan 26 2020, 09:29 PM
Item #2: Straightening the bottoms of both sills, with dents probably from jacking incidents. Here is the right sill.
bkrantz
Jan 26 2020, 09:30 PM
And the left sill.
bkrantz
Jan 26 2020, 09:31 PM
I made some studs that can be welded onto the sill seam, and screw into an adapter for my slide hammer.
bkrantz
Jan 26 2020, 09:32 PM
One on each sill, welded onto the seam at the center of each dent.
bkrantz
Jan 26 2020, 09:33 PM
Slide hammer in action. Each side took a good number of hard hits to get close to straight.
bkrantz
Jan 26 2020, 09:34 PM
Left side, after cutting off the stud and grinding away the weld.
bkrantz
Jan 26 2020, 09:35 PM
And the right side.
bkrantz
Jan 26 2020, 09:37 PM
Item #3: patching the hole in the front inner right sill, where rust ate through (fortunately from outside in). Here's the hole after cutting.
bkrantz
Jan 26 2020, 09:39 PM
I made a patch from a section of 914 front fender.
bkrantz
Jan 26 2020, 09:40 PM
Patch in place. Magnets are helpful.
bkrantz
Jan 26 2020, 09:41 PM
Welded in place.
bkrantz
Jan 26 2020, 09:42 PM
And after grinding. I was less aggressive, and left some of the weld since the sheet metal here is relatively thin.
Kansas 914
Jan 27 2020, 07:30 AM
The great work continues!
FourBlades
Jan 27 2020, 11:25 AM
Nice job, making great progress!
John
bkrantz
Jan 27 2020, 09:40 PM
Thanks, guys. Keeping the progress going...
Item #4: the. front floor corners. Here's the patch for the left side, again made from genuine 914 sheet metal.
bkrantz
Jan 27 2020, 09:41 PM
Test fit.
bkrantz
Jan 28 2020, 09:20 PM
Jumping ahead to #5: treating and painting the rust inside the lower firewall.
bkrantz
Jan 30 2020, 09:31 PM
Back to Item#4: the floor front corners. I decided to reshape my patches to better duplicate the original floor channels.
Here's the left side, ready to weld.
bkrantz
Jan 30 2020, 09:32 PM
And the right side, still needs a few tweaks.
bkrantz
Jan 31 2020, 09:27 PM
Left side welded in, and a quick grinding. A few spots to re-weld and then grind it pretty.
bkrantz
Feb 1 2020, 10:42 PM
Finishing up #4. Here's the left side done.
bkrantz
Feb 1 2020, 10:43 PM
And from the inside.
bkrantz
Feb 1 2020, 10:45 PM
Right side welded in.
