bkrantz
Jun 18 2021, 07:09 PM
To check the fog light positions, I mounted the grills in the bumper. New repro grills from 914 Rubber.
bkrantz
Jun 18 2021, 07:10 PM
To make the speed nuts fit better, I trimmed the corners off the front plates.
bkrantz
Grills mounted.
bkrantz
Jun 18 2021, 07:12 PM
Here's all the hardware, old and new.
bkrantz
And the bumper top, mounted with new rubber spacer washers.
bkrantz
Jun 18 2021, 07:14 PM
Bumper bolts and spacers ready.
bkrantz
Jun 18 2021, 07:15 PM
Here's the bumper bolted in place.
bkrantz
Jun 18 2021, 07:18 PM
The fit looks pretty good, which makes me happy since the right side is where I pulled the outer fender, spliced in part of the inner fender and headlight box, and reconstructed the front panel.
bkrantz
Jun 18 2021, 07:19 PM
Top view, left side.
bkrantz
Jun 18 2021, 07:20 PM
And top view, right side. I might shave a few mm off the rubber spacer to draw the bumper in just a bit.
bkrantz
Jun 18 2021, 07:21 PM
New special speed nuts to fit the rectangular holes in the bumper.
bkrantz
Jun 18 2021, 07:22 PM
In place.
bkrantz
Jun 18 2021, 07:23 PM
Front plate bracket, powder-coated.
bkrantz
Jun 18 2021, 07:25 PM
Installed, and ready for a future plate.
bkrantz
Then I got out the rear bumper.
bkrantz
Jun 18 2021, 07:26 PM
And the original (?) bumper top.
bkrantz
Jun 18 2021, 07:29 PM
After I cleaned and treated the top, bolted it to the bumper with new spacer washers, I installed the bumper on the car. Now to deal with the license plate bracket and lights.
bkrantz
Jun 18 2021, 07:30 PM
Plate bracket, also powder-coated.
bkrantz
Jun 18 2021, 07:34 PM
Bracket and lights installed.
bkrantz
Jun 18 2021, 07:35 PM
One more detail.
bkrantz
Jun 18 2021, 07:36 PM
Done!
bkrantz
Jun 18 2021, 07:37 PM
I can't resist a few glamour shots.
bkrantz
Jun 18 2021, 07:38 PM
Looks more like a 914.
bkrantz
High angle shot.
bkrantz
Jun 18 2021, 07:39 PM
One more.
bkrantz
Jun 18 2021, 07:40 PM
The last thing I did today was replace all the fuses with new ones, plus a new cover.
bkrantz
Jun 18 2021, 07:42 PM
Ready for real volts.
Cairo94507
Jun 19 2021, 07:12 AM
Puebloswatcop
Jun 19 2021, 10:07 AM
bkrantz
Jun 19 2021, 07:57 PM
I got an assortment of retaining rings, hoping one size would work for the targa latches.
bkrantz
Jun 19 2021, 07:58 PM
Best fit are 6 mm.
bkrantz
Jun 19 2021, 07:59 PM
I bolted on the latches.
bkrantz
Jun 19 2021, 08:00 PM
And then installed the targa top pad. This has a few cracks, but will do for now.
bkrantz
Jun 19 2021, 08:01 PM
I then got out the targa side weatherstrips.
bkrantz
Jun 19 2021, 08:02 PM
Pretty easy to install. This was my initial attempt, which was a bit too high. I tried a second time, and left it sticking up just a little bit.
bkrantz
Jun 19 2021, 08:05 PM
More weatherstrip, here the bulkhead top seal (one of two).
bkrantz
One in the frunk.
bkrantz
Jun 19 2021, 08:06 PM
And one in the trunk.
bkrantz
Jun 19 2021, 08:07 PM
Speaking of the frunk, I got out the perimeter seal.
bkrantz
I installed this without any adhesive, so it can come out for cleaning the channel.
bkrantz
Jun 19 2021, 08:08 PM
Here's the trunk seal.
bkrantz
Jun 19 2021, 08:09 PM
Also an easy installation.
raynekat
Jun 20 2021, 12:15 AM
Getting there Brother.
Looking great.
bkrantz
Jun 20 2021, 06:42 PM
More weatherstrip fun today, getting the front targa top seals installed. This is now my (not so) favorite tool.
bkrantz
Jun 20 2021, 06:46 PM
Before installing either strip, I had to deal with the edge of the top pad, which is a bit mangled in places.
bkrantz
Jun 20 2021, 06:47 PM
Time again to dip into my lifetime supply of contact cement.
bkrantz
Jun 20 2021, 06:49 PM
I was able to get most of the edge glued, and also the "pads" where the front latches attach.
bkrantz
Jun 20 2021, 06:51 PM
I started on the left corner, and trimmed the metal tab to fit the shape of the indentation in the 914Rubber molding.
bkrantz
Jun 20 2021, 06:54 PM
Here's the recess, not quite rectangular.
bkrantz
Jun 20 2021, 06:56 PM
First attempt: almost. I started near the top of the straight section, and then worked into the upper curve. Note that the molding as-is prevents the outer edge of the trim piece to seat.
