bkrantz
Sep 22 2021, 07:50 PM
But the coating was a bit too thick, so I sanded each rail until the slider moved easily.
bkrantz
Sep 22 2021, 07:51 PM
Ready to slide.
bkrantz
Sep 22 2021, 07:52 PM
Then it was time to install the tilt control levers. Rebuild kit from 914Rubber, with inner and outer bushings, and new split pins (more about those in a minute).
bkrantz
Sep 22 2021, 07:54 PM
Bushings installed.
bkrantz
Sep 22 2021, 07:56 PM
Easy to get to this point, with all the parts in place, including the spring. But how to twist the spring AND insert the split pin?
bkrantz
Sep 22 2021, 07:57 PM
I was able to use an awl to push the spring and align it with the hole. But then I can't insert the pin.
bkrantz
Sep 22 2021, 07:59 PM
So how about a piece of 1" aluminum bar, to prop the end of the spring? OK...
bkrantz
Sep 22 2021, 08:02 PM
And then, while holding my breath, remove the awl and insert the spilt pin. But the new ones are a bit too large in diameter. While trying to tap and then bang it in, the aluminum prop popped out, the spring un-sprung, and the pin went flying, and is now AWOL in my garage.
bkrantz
Sep 22 2021, 08:03 PM
Instead, I used the original pins, that still fit tight but I was able to insert with moderate tapping.
bkrantz
Sep 22 2021, 08:04 PM
Last piece: the knob for the tilt lever.
bkrantz
Sep 22 2021, 08:05 PM
The final part is new seat adjuster handles.
bkrantz
All ready for the seat!
bkrantz
Sep 23 2021, 08:41 PM
More seat time. Runners bolted to the seat shell bottom.
bkrantz
Sep 23 2021, 08:42 PM
Seat base bolted into car.
bkrantz
And then slide the seat into place.
bkrantz
Sep 23 2021, 08:44 PM
Both sides including bottoms (and I could not resist mounting the steering whee).
bkrantz
Another view.
930cabman
Sep 24 2021, 05:00 AM
Looking good Bob, any updates with the mill?
Cairo94507
Sep 24 2021, 06:53 AM
Very clean looking interior. Nicely planned.
bkrantz
Sep 24 2021, 07:37 PM
QUOTE(930cabman @ Sep 24 2021, 05:00 AM)
Thanks. Getting a mill is still a dream.
bkrantz
Sep 24 2021, 07:38 PM
QUOTE(Cairo94507 @ Sep 24 2021, 06:53 AM)
Thanks. I am glad the vision I had looks good for real.
bkrantz
Sep 24 2021, 07:41 PM
Some more interior bits today. Here are three shift lever boots, from left to right:
original?
first replacement
second replacement
bkrantz
Sep 24 2021, 07:45 PM
Why two replacements? Because the first is made from a cheesy fake leather, and the outer skin separated from the inner layer, which is falling apart. The second replacement, on the right, is made from real leather. I got this from an eBay vendor in the UK. Much better.
bkrantz
Sep 24 2021, 07:46 PM
I mounted the boot directly to the console panel underside, using contact cement.
bkrantz
Sep 24 2021, 07:47 PM
Before installing the panel, I wanted to hide the bight stuff visible through the slot for the heater control lever.
bkrantz
Sep 24 2021, 07:48 PM
A scarp of black vinyl took care of that.
bkrantz
Sep 24 2021, 07:49 PM
The final bit on the panel is the "Defroster" indicator. This now has an LED bulb.
bkrantz
Sep 24 2021, 07:50 PM
Wiring from the underside.
bkrantz
Sep 24 2021, 07:52 PM
I sourced a new knob for the lever, in brick red instead of the bright red.
bkrantz
Sep 24 2021, 07:53 PM
I also have a new shift knob and bushing.
bkrantz
New knobs!
bkrantz
Sep 24 2021, 07:58 PM
A final trinket: after many months of searching, I found a Porsche crest button for the Nardi wheel that came on the car. I know after-market steering wheels upset some people, but one of the things I changed on my first 914 was the wheel.
bkrantz
Sep 24 2021, 07:59 PM
And I like this as the only Porsche crest on the car.
bkrantz
Sep 24 2021, 08:01 PM
After that, I fastened down the arm rest, with the hidden control for the hidden audio system, complete with USB plug for phones.
bkrantz
Sep 24 2021, 08:02 PM
Here's a shot of the interior, complete except for doors and windshield.
djway
Sep 24 2021, 10:19 PM
SWEET
seanpaulmc
Sep 25 2021, 05:13 AM
QUOTE(bkrantz @ Sep 24 2021, 10:02 PM)
Outstanding!
bkrantz
Sep 25 2021, 07:53 PM
Thanks, guys. I hope all the bits stay together when I try driving.
bkrantz
Sep 25 2021, 07:55 PM
More tools! Thats why we play amateur mechanic, right?
I rationalized getting a 12 inch caliper to deal with measuring push rods. And a new dial gauge since my near-antique Sears model was acting odd.
bkrantz
Sep 25 2021, 07:56 PM
And while I was shopping, why not a better dial gauge support thing?
bkrantz
Sep 25 2021, 07:57 PM
But before playing with new toys, I played with new hardware. I got some M5 Allen head bolts.
bkrantz
Sep 25 2021, 07:59 PM
Two of these replace the temporary bolts I used in the centers of the lower sheet metal pieces. This makes my OCD happy, since they match the M6 Allen heads I used for the other spots.
bkrantz
Sep 25 2021, 08:01 PM
OK, time to play with the pushrod lengths again. Here is my new dial gauge set up.
bkrantz
Sep 25 2021, 08:03 PM
I also made a cardboard template to help with judging alignment. This wedge is 14 degrees, which matches the inclination of the valves relative to the perpendicular of the cylinder head faces.
bkrantz
Sep 25 2021, 08:05 PM
Here's a measurement of valve lift on the #1 intake, with a 268 mm push rod length. The lift is .432". I was able to repeat that multiple times.
bkrantz
Sep 25 2021, 08:07 PM
And at half-lift, the rocker arm and adjuster nut line up nicely, so the adjuster and valve stem should be in a straight line.
bkrantz
Sep 25 2021, 08:09 PM
On the exhaust valve, I got a max lift of .410. As expected, this is less than the intake valve lift, since the rocker arm ratios are a little different. I also got excellent alignment. Again, this was with my adjustable pushrod set to 268 mm.
bkrantz
Sep 25 2021, 08:17 PM
For "fun", I installed stock 271 mm pushrods, and .074" shims under the rocker shaft supports. Still on cylinder #1, I got these results:
intake, .432" lift, excellent alignment
exhaust, .412" lift, excellent alignment
I confirmed these by putting the same shims under the rocker shaft supports for #4, with
intake, .432" lift
exhaust, .409" lift
both with excellent alignment
Now I need to decide on my solution: adjustable pushrods or shims.
barefoot
Sep 26 2021, 04:21 PM
QUOTE(bkrantz @ Sep 25 2021, 09:59 PM)
Yes !!! death the cheese heads, so much easier to deal with using long allen head wrenches
bkrantz
Sep 26 2021, 07:45 PM
QUOTE(barefoot @ Sep 26 2021, 04:21 PM)
Agreed. Just don't say that in Wisconsin.
