bkrantz
Jul 17 2020, 08:56 PM
Right side.
bkrantz
Jul 17 2020, 08:57 PM
Lids.
bkrantz
Jul 17 2020, 08:58 PM
Some other projects around the shop, in progress (on on pause?).
Kansas 914
Jul 18 2020, 08:22 AM
It is nice to see that the body shop is progressing!
Can't wait to see it with color on it.
See you Tuesday!
bkrantz
Jul 18 2020, 08:19 PM
Back at home, I tried some paint remover on the blower housing.
bkrantz
Jul 18 2020, 08:21 PM
Most of the paint came off the inner half, but not so much on the outer half. It might have had more paint, so I will try again.
bkrantz
Jul 18 2020, 08:22 PM
I also got into the engine sheet metal.
bkrantz
Jul 18 2020, 08:23 PM
The upper pieces all needed a bit of metal work.
bkrantz
Jul 18 2020, 08:26 PM
The upper right piece had some half-ass brazing done, which did not cover all the cracks. Next step will be grinding off the brazing.
bkrantz
Jul 20 2020, 07:43 PM
Back to work on the sheet metal today. Step 1 was grinding off all the brass brazing.
bkrantz
Jul 20 2020, 07:44 PM
Then a bit of welding.
bkrantz
Jul 20 2020, 07:46 PM
And grinding. I will give this another pass, since I plan to powder-coat the engine sheet metal so can't use filler.
bkrantz
Jul 21 2020, 07:35 PM
Today, after 2 more rounds of weld and grind. I think this is good enough, and ready for the powder coat shop.
bkrantz
Jul 21 2020, 07:37 PM
And also another round of paint stripper on the outer blower housing. Not sure what will come next.
bkrantz
Jul 21 2020, 07:38 PM
And then I opened the dreaded box I have ignored for months.
bkrantz
Jul 21 2020, 07:39 PM
The engine/FI harness is in pretty good shape, but needs all new connector boots.
bkrantz
Jul 21 2020, 07:40 PM
The main harness has several PO modifications.
bkrantz
Jul 21 2020, 07:41 PM
Another
bkrantz
And another
bkrantz
Jul 22 2020, 07:36 PM
I stopped by the body shop again today, which is about 3 weeks since they started work.
bkrantz
Jul 22 2020, 07:37 PM
They are almost done with the second phase of filler, getting the surface smoothness and contours precise.
bkrantz
Jul 22 2020, 07:38 PM
With luck, the car will be in primer in a few days.
Frankvw
Jul 23 2020, 06:08 AM
nice to see this progress, and good luck with the wireloom ! although it has some PO-modifications, it does not look too bad (from the pics at least). Good that you have created a space for it to work on !!
bkrantz
Jul 23 2020, 08:40 PM
QUOTE(Frankvw @ Jul 23 2020, 06:08 AM)
Thanks. I took a more careful look, and removed most non-stock coverings. I flagged all the problems with blue tape, and then chickened out and put it back in the box.
bkrantz
Jul 23 2020, 08:41 PM
I also wanted to clear my table so I could lay out the suspension. Here are all the parts as they came off the car last September.
bkrantz
Jul 23 2020, 08:43 PM
I surveyed everything and spotted some minor problems, including worn and loose bushings and a beat-up steering rack boot flange.
bkrantz
Jul 23 2020, 08:44 PM
I took apart the front struts. Interesting inserts, and look relatively new.
bkrantz
Jul 23 2020, 08:48 PM
Unfortunately, the left strut housing has a bigger problem: the threads on the inside are worn away on one side. My guess is that the original insert got loose and wore away the threads.
bkrantz
Jul 23 2020, 08:49 PM
I will need to replace this. Any specific years that match (or not) my 1973? Here's the only number I could find on the strut housing.
bkrantz
Jul 24 2020, 09:00 PM
I had a busy day taking the suspension components apart. Here's my method for removing the end fittings and bushings on the front A-arm: using my cheater extension to rotate and twist the fitting off.
bkrantz
Jul 24 2020, 09:03 PM
Once the end fitting is off, I then pried the bushing out.
bkrantz
Jul 24 2020, 09:04 PM
I also removed the ball joints. Given the neat and tidy bending of the cotter pins, I bet these were original.
bkrantz
Jul 24 2020, 09:06 PM
Next, I took the rear shocks and springs apart. Pretty easy with my trusty spring compressor. I originally bought these for working on 914 springs almost 30 years ago.
bkrantz
Jul 24 2020, 09:07 PM
These springs have green color code.
bkrantz
Jul 24 2020, 09:09 PM
I then got on to pressing out the rear wheel bearings and hubs. I know this Jenga set up looks sketchy.
bkrantz
Jul 24 2020, 09:10 PM
This was going to be just a mock-up, but when I put just a small amount of pressure on the hub, it moved.
bkrantz
Jul 24 2020, 09:12 PM
On one side, the bearing came out intact, but on this side one bearing race came out on the hub.
bkrantz
Jul 24 2020, 09:14 PM
That led to one extra step on the press.
bkrantz
Jul 24 2020, 09:15 PM
The bearing grease on that side was almost dry and hard.
bkrantz
Jul 24 2020, 09:16 PM
Trailing arms without bearings!
bkrantz
Jul 24 2020, 09:18 PM
The last step was pressing out the axle. I pressed one end in far enough to clear the bushing.
bkrantz
Jul 24 2020, 09:19 PM
I could then pry the bushing out.
bkrantz
Jul 24 2020, 09:20 PM
I then pushed the other end of the axle in past the bushing, and pried out that side.
bkrantz
Jul 24 2020, 09:21 PM
Trailing arm axles out!
bkrantz
Jul 24 2020, 09:22 PM
And I found the traditional hieroglyphics on the trailing arms.
bkrantz
Jul 24 2020, 09:24 PM
I am curious about the paint. One trailing arm has reasonably intact black paint, but this side is almost paint-free.
raynekat
Jul 24 2020, 11:14 PM
Great tear down pics Bob.
Keep up the fantastic work.
bkrantz
Jul 25 2020, 08:19 PM
QUOTE(raynekat @ Jul 24 2020, 11:14 PM)
Thanks, Doug. Still in tear-down mode, but at least I can imagine how these pieces will go back together.
bkrantz
Jul 25 2020, 08:24 PM
I forgot the last two rubber bushings, in the strut top mounts.
bkrantz
Jul 25 2020, 08:25 PM
That took about 60 seconds with the press.
