Cairo94507
Mar 3 2023, 08:32 AM
bkrantz
Mar 4 2023, 08:51 PM
Ready for mounting the exhaust. The copper gaskets are new--the "dirt" is from heat treatment.
bkrantz
Mar 4 2023, 08:52 PM
Gaskets installed. Pushed in just right, they stay in place.
bkrantz
I got to try my wobble extension.
bkrantz
Mar 4 2023, 08:53 PM
Just enough flex to reach past the exhaust tube.
bkrantz
Mar 4 2023, 08:54 PM
Heat exchangers installed.
bkrantz
Mar 4 2023, 08:58 PM
Muffler time. It did run kinda hot during the dyno tune session last summer.
bkrantz
New gaskets.
bkrantz
Mar 4 2023, 09:00 PM
Flanges aligned and bolted--I did have to loosen the nuts on the cylinder heads to get the exchangers lined up.
bkrantz
Mar 4 2023, 09:01 PM
And then the muffler mounting clamps.
bkrantz
Mar 4 2023, 09:02 PM
Exhaust all done.
Dion
Mar 5 2023, 07:38 AM
Fantastic work Bob. One hellava 914!
nivekdodge
Mar 5 2023, 07:56 PM
QUOTE(bkrantz @ Mar 4 2023, 10:01 PM)
My forehead would find those screws repeatedly. I never realized how good my hair prevented cuts and scrapes!!!!!
Kevin
bkrantz
Mar 5 2023, 08:23 PM
QUOTE(Dion @ Mar 5 2023, 06:38 AM)
Thanks. Maybe this year I can drive it more than wrench on it.
bkrantz
Mar 5 2023, 08:25 PM
OK, hoping today I can wrap up the underside. Getting tool old to enjoy hours on a creeper.
bkrantz
Mar 5 2023, 08:26 PM
J tube
bkrantz
Mar 5 2023, 08:27 PM
Mounted on the exchanger. I still prefer Allen head bolts.
bkrantz
Mar 5 2023, 08:28 PM
Fancy duct.
bkrantz
Installed.
bkrantz
Mar 5 2023, 08:29 PM
Heat valve.
bkrantz
Mar 5 2023, 08:30 PM
Plus hi-temp hose.
bkrantz
Mar 5 2023, 08:31 PM
And then the new sheet metal I dod not have last year. Let side piece.
bkrantz
Mar 5 2023, 08:33 PM
Installed.
bkrantz
Right side.
bkrantz
Mar 5 2023, 08:34 PM
Installed.
bkrantz
Mar 5 2023, 08:37 PM
Then time for the clutch cable. That means getting out my 11mm wrenches, including the slim wrench, so I can adjust the cable nut and lock nut.
bkrantz
Mar 5 2023, 08:38 PM
That's done.
bkrantz
Then the speedometer cable.
bkrantz
Mar 5 2023, 08:39 PM
Since this cable did not come with a boot, I made my own with 3M rubber tape.
bkrantz
Mar 5 2023, 08:41 PM
Then the O2 sensor cable.
bkrantz
Mar 5 2023, 08:42 PM
I bundled all the cables and covered then with the plastic cable wrap.
bkrantz
Mar 5 2023, 08:43 PM
Last thing: connecting the heater valve control cables. Seems like they work.
bkrantz
Mar 5 2023, 08:44 PM
OK, that should be everything underneath. Yay!
bkrantz
Mar 5 2023, 08:45 PM
Checklist check.
Van914
Mar 6 2023, 06:03 AM
Instead of plastic on cables you might want to use Fire Sleeve
bkrantz
Mar 6 2023, 09:26 PM
QUOTE(Van914 @ Mar 6 2023, 05:03 AM)
Thanks for reminding me. I had that on last year.
bkrantz
Mar 9 2023, 08:35 PM
I found the heat sleeve, and a metal zip tie.
bkrantz
Mar 9 2023, 08:37 PM
Time to get my new oil pressure sender and gauge wired.
bkrantz
Mar 9 2023, 08:38 PM
Back into crimp and heat-shrink mode.
bkrantz
Mar 9 2023, 08:39 PM
Sender end is done.
bkrantz
Mar 9 2023, 08:40 PM
The other end is more complicated.
bkrantz
Mar 9 2023, 08:42 PM
First of all, the gauge diameter is too small.
bkrantz
I have an idea: 1/8" thick rubber.
bkrantz
Mar 9 2023, 08:43 PM
Here's a 1/2" wide strip wrapped around the gauge.
bkrantz
Mar 9 2023, 08:44 PM
Now it's a snug fit, and looks pretty good.
bkrantz
Mar 9 2023, 08:48 PM
Time to sort out the wiring, so connect the battery for the first time since December.
That also let my cycle the fuel pump and check for leaks. Nothing obvious!
bkrantz
Mar 9 2023, 08:51 PM
I need a switched positive lead. I deleted the clock, but can't use the lead for that since it is unswitched. Instead, I will take power from the volt meter.
bkrantz
Mar 9 2023, 08:52 PM
That means time for a twin spade adapter.
bkrantz
Mar 9 2023, 08:53 PM
And a jumper lead.
bkrantz
And isolating the power lead for the clock.
