bkrantz
Feb 13 2023, 09:15 PM
Time for one more step: get the back end hoisted up and check a few more things in the engine compartment. I think I am ready for lifting the engine.
nivekdodge
Feb 14 2023, 03:13 PM
QUOTE(bkrantz @ Feb 12 2023, 09:04 PM)
Instead of 914 work I spent a couple of hours playing with old snow. I shoveled back snowbanks in the shade not melting (except a little each day which then makes ice on the driveway), and big ice dams at the street that makes a skating rink every morning. Party my OCD and partly my wife's worries about slipping.
I would do this for the elderly neighbors so they didn't have to lift if I was at work.
Fingers crossed I'm back in too
Kevin
bkrantz
Feb 15 2023, 08:27 PM
OK, progress today!
Step 1: get the engine off jack stands and on my wood platform on the motorcycle lift.
bkrantz
Feb 15 2023, 08:28 PM
Step 2: Lowered down to maneuver.
bkrantz
Feb 15 2023, 08:29 PM
Step 3: roll into place under the car. Plenty of vertical clearance for the ITBs.
bkrantz
Feb 15 2023, 08:32 PM
Step 4: begin lifting. But not enough side clearance for the ITB fuel rails.
bkrantz
Step 5: unbolt the ITBs.
bkrantz
Feb 15 2023, 08:34 PM
My solution to get another 2 inches of lift from my AC floor jack.
bkrantz
Feb 15 2023, 08:35 PM
Step 6: get the car back to horizontal.
bkrantz
Feb 15 2023, 08:36 PM
Engine-trans mounting hardware.
bkrantz
Feb 15 2023, 08:37 PM
Coming up--check from the top side.
bkrantz
Some cardboard for...
bkrantz
Feb 15 2023, 08:38 PM
Protecting the side sheet metal from the suspension nuts.
bkrantz
Feb 15 2023, 08:39 PM
Step 7: bolt the engine and trans in place. Yay, back in again!
bkrantz
Feb 15 2023, 08:41 PM
A good chance to connect the fuel lines, before bolting the right ITB in place. My preference is to double clamp all the connections where possible.
bkrantz
Feb 15 2023, 08:43 PM
ITBs back in place, with all fuel lines connected.
bkrantz
Now just hook up all the cables and bits, and off we go! (Yes, I need a work cover--got something in the works.)
Puebloswatcop
Feb 15 2023, 10:14 PM
Fingers crossed Bob. Glad to see it go back together.
bkrantz
Feb 16 2023, 10:05 PM
QUOTE(Puebloswatcop @ Feb 15 2023, 09:14 PM)
Thanks. I hope to find out soon.
bkrantz
Feb 18 2023, 08:20 PM
Speaking of work covers, here's what I'm thinking. I got some 1/4" wool felt.
bkrantz
Feb 18 2023, 08:22 PM
I figure one wide piece across the trunk and hanging down the sides, with some short side extensions to protect the fenders under the targa sails.
930cabman
Feb 19 2023, 05:31 PM
McMaster Carr?
bkrantz
Feb 19 2023, 08:07 PM
No, the vendor I found is Madison Speaker Components, who sell this stuff by the yard for lining speaker enclosures.
bkrantz
Feb 20 2023, 08:50 PM
Back under the car today. First, I connected the ground strap before I forget.
bkrantz
Feb 20 2023, 08:52 PM
Then the shift rod, starting with the front coupling.
bkrantz
Feb 20 2023, 08:54 PM
Then the rear.
bkrantz
Feb 20 2023, 08:57 PM
The back cover is easy, and I was able to re-use the clamp.
bkrantz
Feb 20 2023, 08:58 PM
But I hate the front rubber cover. It took me 20 minutes to get it around the flange on the firewall.
bkrantz
Feb 20 2023, 09:01 PM
I decided to make a checklist for the engine installation--maybe the next time I will not forget something.
bkrantz
Feb 21 2023, 09:26 PM
Here's the first version of my work cover. Total length is a about 3 yards, with cuts to fit into the engine compartment.
bkrantz
Feb 21 2023, 09:27 PM
Plus a couple of magnets. (I decided to get some bigger and stronger magnets.)
bkrantz
Feb 21 2023, 09:28 PM
Taped to the front corners.
bkrantz
Feb 21 2023, 09:29 PM
Magnets stick to the sails on vinyl.
bkrantz
I think this could work.
bkrantz
Feb 21 2023, 09:30 PM
View on the inside. The edge tucks under the torsion bars and release cable tube, so the trunk lid edge is protected.
bkrantz
Feb 21 2023, 09:33 PM
I tested the cover with some work on the engine top. I hooked up the vacuum lines, including the line that goes through the trunk wall to the EFI CPU.
bkrantz
Feb 21 2023, 09:35 PM
And I installed the air filter bases and intake horns. Now to connect all the stock and EFI cables.
bkrantz
Mar 2 2023, 08:59 PM
Back in town and on the job. I need to connect things below and above.
In prep for bolting on the heat exchangers, I gave the copper gaskets a heat treatment.
bkrantz
Mar 2 2023, 09:01 PM
Then time for rubber surround clips. They might look like office supplies, but they are actually custom 914 parts.
bkrantz
Mar 2 2023, 09:02 PM
Here's a clip as initially installed.
bkrantz
Mar 2 2023, 09:05 PM
And then with the special chrome handles removed.
BTW, after my initial engine installation last year, the rubber surround kept pulling away from the sheet metal. This was an effective fix.
bkrantz
Mar 2 2023, 09:07 PM
Then I got out all the CV joint hardware, especially new gaskets and Schnorr washers.
bkrantz
Mar 2 2023, 09:09 PM
Gasket installed. The fit is tight, and it was a bit tricky to keep the gasket in place in the CV body recess.
bkrantz
Mar 2 2023, 09:10 PM
CVs bolted up and torqued.
bkrantz
Mar 2 2023, 09:12 PM
I then worked on making all the EFI cable connections, and tying down the cables.
nivekdodge
Mar 2 2023, 09:14 PM
My buddies we'll be quite impressed with my car, as long as they never see yours. Looks great Bob
bkrantz
Plus the connections on the relay board. The alternator cable is stock, but the 12 pin cable is a hybrid of original wires plus new leads for the EFI.
bkrantz
Mar 2 2023, 09:15 PM
Relay cover and custom strap.
bkrantz
Mar 2 2023, 09:17 PM
Then the throttle cable
bkrantz
Mar 2 2023, 09:20 PM
Last thing today, connect all the breather hoses.
