Kansas 914
Nov 4 2020, 08:11 PM
QUOTE(bbrock @ Nov 4 2020, 07:07 PM)
QUOTE(Kansas 914 @ Nov 4 2020, 08:05 PM)
QUOTE(bkrantz @ Nov 4 2020, 06:42 PM)
Finally getting around to sorting parts to be plated. Any suggestions for vendors?
Hi Bob,
Check with Eric at PMB - now doing yellow and silver zinc plating.
Oh hell yeah! Didn't know he was offering plating now but that's a no brainer.
Here is a link if you have Facebook:
https://www.facebook.com/pmbplating/
bkrantz
Nov 8 2020, 08:46 PM
I had been planning a big weekend to make progress, and start really putting the body back together. But on Saturday morning I got a call from my son. He had just finished a week of camping near Zion NP with friends, and on the last morning in the park he stopped and found all the oil no longer in the engine.
bkrantz
Nov 8 2020, 08:52 PM
We both tried to determine options. The nearest VW dealer (St. George) did not have an oil pan in stock, and claimed about a week before they could do the job. For him to tow the car back home (Tucson) he would need to rent a trailer and box van from Uhaul, for at least several hundred $. Commercial towing would be silly expensive. So being a generous father, I volunteered to rent a tow dolly locally, and drive 400 miles to get him.
bkrantz
Nov 8 2020, 08:55 PM
We got it home and dropped the plastic oil pan. It was cracked on the rear edge, but no other visible damage. Parts should arrive tomorrow, and he can be on the way home Tuesday.
raynekat
Nov 9 2020, 05:39 PM
Good Pop.
sixnotfour
Nov 9 2020, 05:57 PM
Fuch, my son has the same VW,,Nice heads up.....
djway
Nov 9 2020, 08:30 PM
QUOTE(bkrantz @ Nov 8 2020, 06:55 PM)
Hope the car wasn’t hungry
bkrantz
Nov 9 2020, 08:59 PM
QUOTE(sixnotfour @ Nov 9 2020, 04:57 PM)
My son ordered an optional steel pan to replace the stock plastic piece. It should be tougher.
bkrantz
QUOTE(raynekat @ Nov 9 2020, 04:39 PM)
Good Pop.
Still useful!
bkrantz
Nov 10 2020, 08:33 PM
Here's the cracked plastic oil pan from the GTI.
bkrantz
Nov 10 2020, 08:34 PM
As a replacement, he ordered a steel replacement from URO.
bkrantz
Nov 10 2020, 08:35 PM
All done, successfully running again.
bkrantz
Nov 10 2020, 08:37 PM
While he was working, I started painting the spots I had scraped and primed, or applied seam sealer.
bkrantz
Nov 10 2020, 08:38 PM
First coat in the hell hole and below.
djway
Nov 10 2020, 08:51 PM
Beautiful.
UROpartsman
Nov 11 2020, 11:34 AM
QUOTE(bkrantz @ Nov 9 2020, 06:59 PM)
Well done Bkrantz!
• URO Parts has offered
steel Oil Pan
06J 103 600AF for
2008-2014 GTI (cars without oil level sensor also require Oil Level Sender Cover
03G 103 707) for about a year, with great feedback.
• We offer
aluminum pan
06K 103 600R-PRM for
2015-2016 GTI cars that originally came with the honeycomb plastic pan, which appears to be the factory pan on your son's car.
What year is your son's GTI? It looks like he may have bought the wrong pan, even if the flange bolt pattern is the same. The 2008-2014 steel pan is slightly deeper and will hang lower than the 2015-2016 honeycomb aluminum pan, and is more likely to catch speedbumps, etc. Sent you a PM.
bkrantz
Nov 11 2020, 07:32 PM
I finished spraying color today (I think), and got coverage on all the spots, including the added seam sealer. I will add some clear coat and call it done.
bkrantz
Other side
bkrantz
Nov 11 2020, 07:33 PM
Left side hell hole.
bkrantz
Nov 12 2020, 07:24 PM
I touched up the last few spots, including in the frunk weatherstrip channel.
bkrantz
Nov 13 2020, 07:25 PM
OK, except for a few very small spots, the paint is now complete. Time to start building.
Kansas 914
Nov 13 2020, 09:03 PM
QUOTE(bkrantz @ Nov 13 2020, 06:25 PM)
Great job!
Now the fun begins.
bkrantz
Nov 14 2020, 07:34 PM
QUOTE(Kansas 914 @ Nov 13 2020, 08:03 PM)
Great job!
Now the fun begins.
Indeed!
My initial plan:
1. Dynamat on floor and inside of firewall.
2. Fuel lines in tunnel.
3. Brake line in tunnel.
4. Cables in tunnel.
5. Wiring harness.
Comments?
bkrantz
Nov 14 2020, 07:40 PM
Before adding parts to the body, I decided to add some rust prevention in the cavities, especially the longs. I have had a couple of cans of Eastwood Internal Frame Coating sitting around for months.
bkrantz
Nov 14 2020, 07:41 PM
I used the access holes to get inside the longs.
bkrantz
Nov 14 2020, 07:42 PM
The nozzle and hose are small enough diameter to sneak past obstructions.
bkrantz
Nov 14 2020, 07:43 PM
Access to the upper part of the rear longs.
bkrantz
Nov 14 2020, 07:46 PM
And also inside the tunnel. The nozzle sprays a 180 degree pattern.
In addition, I sprayed inside the lower firewall, the closed brace by the driver pedal area, the cross brace in the trunk, and the side braces under the fuel tank.
bkrantz
Nov 14 2020, 07:47 PM
Prelims almost done.
Kansas 914
Nov 14 2020, 08:02 PM
Great work!
djway
Nov 14 2020, 09:56 PM
I usually use about 10 of those cans on a car before paint. I do everything I can find.
I have had it come out other holes and get everywhere, hence, Before paint.
Blankets and tape everywhere while working and all will be well.
Let the fun begin.
bkrantz
Nov 15 2020, 08:08 PM
Thanks. I probably should have done it before paint, but I managed to get the sealer where I wanted without too much mess.
bkrantz
Nov 15 2020, 08:37 PM
Some schedule changes means some work plan changes. I will have a chance to drop off the fuel tank for cleaning, so I pulled it from storage.
bkrantz
Nov 15 2020, 08:39 PM
Tank stripped of fittings and sender.
bkrantz
Nov 15 2020, 08:41 PM
A peek inside--some surface rust.
Kansas 914
QUOTE(bkrantz @ Nov 15 2020, 07:39 PM)
Are you using the radiator shop in town on N. Main? He is pretty good.
He did my friends 356 tank last year.
bkrantz
Nov 15 2020, 09:18 PM
We are making a run to Tucson. At least one shop there offers the RENU process. I am also taking some interior parts, including the seats, to talk with some custom upholstery shops.
bkrantz
Nov 16 2020, 08:49 PM
Here's what my seats looks like now, essentially a stock look. A couple of the side bolsters are a bit lumpy. The bottom cushions are original (I think--could be extra padding on top), but are maybe a bit thick for me--I will need every bit of head room, at least with the top on.
bkrantz
Nov 16 2020, 08:50 PM
The bottoms are also attached with custom PO bolts.
bkrantz
Nov 16 2020, 08:51 PM
Now that's some quality work right there.
bkrantz
Nov 16 2020, 08:53 PM
No retaining clip on the base board.
raynekat
Nov 16 2020, 10:03 PM
QUOTE(bkrantz @ Nov 16 2020, 06:53 PM)
Hence the nice "bolt work" from the PO.
bkrantz
Nov 17 2020, 08:08 PM
Another slight detour: I remembered that to mount the engine compartment deflectors I needed to drill holes, something else I forgot before send the car to the paint shop.
Here's the deflector kit from 914 Rubber, and the page from the shop manual with the magic spacing dimension.
bkrantz
Nov 17 2020, 08:09 PM
Holes drilled from below.
bkrantz
Nov 17 2020, 08:10 PM
Test fit.
bkrantz
Nov 17 2020, 08:11 PM
Holes touched up.
bkrantz
Nov 19 2020, 08:52 PM
I picked up some of my engine parts from Competition Engineering in Phoenix.
bkrantz
Lots of air-cooled clutter.
bkrantz
Nov 19 2020, 08:54 PM
Heads with complete (stock) valve job.
bkrantz
Nov 19 2020, 08:55 PM
Crank checked and journals polished.
