bkrantz
Mar 30 2024, 07:00 PM
Tie down installed. This cool updated design has a magnet to keep the ring from dangling when not in use.
bkrantz
Mar 30 2024, 07:05 PM
Both sides took about 10 minutes.
bkrantz
Loops tucked up, and ready to roll.
FourBlades
Mar 30 2024, 07:06 PM
Nice tie downs!
Your car is looking amazing.
John
bkrantz
Mar 30 2024, 07:09 PM
I am going to use editorial privilege here, and add in my Aluma trailer. I got this specifically to tow my 914 to events and other distant locations. My wonderful, wonderful wife wants to join in, but has declared she will not spend multiple hours in the right seat, just to get somewhere.
bkrantz
Mar 30 2024, 07:11 PM
To make loading easier (including on my marriage) I added a 3500 lb winch. I installed this using a 5/8 inch thick aluminum plate. The winch bolts to the plate, and the plate is held to the main trailer member with some big square-end U-bolts.
bkrantz
Mar 30 2024, 07:13 PM
My remaining task is the power system. I already have the relay and connections in a waterproof box. Now to mount this on the trailer.
bkrantz
Mar 30 2024, 07:14 PM
For now, I am using 3M industrial strength adhesive tape, with double tape layers to account for the nubs on the bottom of the box.
bkrantz
Mar 30 2024, 07:15 PM
Box installed, and power cables attached to the winch.
bkrantz
Mar 30 2024, 07:16 PM
Here's my setup version 1.0, with a stand-alone battery. The battery cables are very heavy gauge, with a big quick-connect.
bkrantz
Mar 30 2024, 07:17 PM
It works!
bkrantz
Mar 30 2024, 07:18 PM
Closed up for travel.
bkrantz
Progress!
bkrantz
Mar 31 2024, 09:54 PM
While sorting through garage boxes, I found my collection of personal car "souvenirs". This has some old shift knobs, wheel caps, and some bent valves. It also has the auxiliary gauges and panels I made for my 914 race car in the 1990s.
bkrantz
Mar 31 2024, 09:56 PM
And the mounting ears that broke off the transaxle of the racecar when I collided with a Miata during an SCCA IT enduro race. That was the end of my car.
76-914
Apr 1 2024, 07:52 AM
Great job and looks great too!
bkrantz
Apr 16 2024, 09:10 PM
I made a gravel screen from a single piece of .090 aluminum sheet. This was a little tough to bend, and I lent my son all my metal working tools, so the result is a little lumpy. (He recently began his own car project on an old mid-engine, two seater--but not a 914, a 1986 MR2.)
bkrantz
Apr 16 2024, 09:12 PM
With all the folds, I expect it to be fairly rigid. The last step was tying the folded top panel joints together.
bkrantz
Apr 16 2024, 09:14 PM
I reinstalled the winch, and should be ready to try loading my 914. Only 2 weeks until we tow to the R66C.
Cairo94507
Apr 17 2024, 05:44 AM
That is exactly what open trailers need. Your car should be nice and safe as it enjoys the ride.
bkrantz
Apr 17 2024, 10:26 PM
QUOTE(Cairo94507 @ Apr 17 2024, 05:44 AM)
I hope so.
bkrantz
Apr 24 2024, 07:55 PM
I finally had a chance to try loading my 914 on the trailer. I set aside an entire afternoon. It worked out OK, including adjusting the car position to set the hitch weight. The winch certainly made it easy.
bkrantz
Apr 24 2024, 07:57 PM
And then a short test drive. The 914 stayed on the whole time.
FlacaProductions
Apr 25 2024, 10:09 AM
That's fantastic. Really nice, thoughtful work.
Basic 914 question - do you use the tow loop under the spare for winching or some other point?
bkrantz
Apr 25 2024, 07:23 PM
QUOTE(FlacaProductions @ Apr 25 2024, 10:09 AM)
No, although the tow loop and floor seem to be fully intact, I don't trust it (or want to deform it). I used the tie down loops I bolted to the front suspension mounts, and a short section of cable across the loops--and then the winch hook on the cable. Sorry I did not get a picture of that.
