bkrantz
Jun 13 2022, 07:31 PM
I used 5/16" butyl tape I ordered through NAPA, which came in a store brand box.
Puebloswatcop
Jun 13 2022, 07:34 PM
QUOTE(bkrantz @ Jun 13 2022, 06:25 PM)
Big day today! Car friends Chuck and Mike (Kansas 914) came over to help with some jobs that need extra hands (thanks, guys!).
First up, the windshield. Here we are checking the fit and adjusting spacers. Note that I tried to find Speed Yellow suction cups, but had to settle for Sunflower.
Gee Bob, Guess now you have to re-paint the car Sunflower so it matches the suction cup handles....
bkrantz
Jun 13 2022, 07:35 PM
I took about 10 minutes to lay the butyl in the recess. At first, I put it about 1/8" back from the inner edge. When we started to lay the windshield in, I rolled the butyl inward to be even with the edge.
Also note the extra short bits of tape to mark the positions of the plastic clips.
bkrantz
Jun 13 2022, 07:39 PM
With lots of hopeful thoughts we laid the glass in place, starting with the bottom edge on the rubber spacers. Our luck held, and we got it in centered and even.
bkrantz
Jun 13 2022, 07:43 PM
This is the amount of butyl tape left over from the 15' roll, maybe 2 to 3'.
bkrantz
Jun 13 2022, 07:44 PM
Upper left corner with the initial adhesion. Later the car went in the sun.
bkrantz
Jun 13 2022, 07:47 PM
But before that, we mounted the trunk lid. That is a easy job for 3 people--not so easy for one.
bkrantz
Jun 13 2022, 07:52 PM
After a few minutes of adjustment, the fit was pretty good, just a bit close to the edge of the engine lid. More about this later.
bkrantz
Jun 13 2022, 07:58 PM
So then, time to actually drive the car, if only 30 ft. It started on the first crank, got in reverse, and backed out of the garage. You have to imagine this video with sound.
bkrantz
Jun 13 2022, 07:59 PM
Almost complete 914 in the sun. The paint looks pretty good.
bkrantz
Jun 13 2022, 08:01 PM
After a bit more than an hour in the summer sun, the butyl was definitely softer, and I pushed all around to get a full seal.
bkrantz
Jun 13 2022, 08:04 PM
Another outside shot. I can't help it.
bkrantz
Jun 13 2022, 08:06 PM
Back inside, I tried to shift the engine lid forward, but it rubbed against something when opening. So I removed the lid and found the point of contact at one of the pad retaining tabs.
bkrantz
Jun 13 2022, 08:09 PM
I did a bit of impromptu metal work to bump the tab even with the rest of the firewall ridge. Now I need to touch up the paint here and where it rubbed on the inner edge of the engine lid.
bkrantz
Jun 13 2022, 08:11 PM
More done.
930cabman
Jun 14 2022, 04:51 AM
jaredmcginness
Jun 14 2022, 05:17 AM
Amazing progress. Paint looks GREAT in the sun!
Cairo94507
Jun 14 2022, 06:46 AM
Looks amazing and even more amazing in the sun.
mb911
Jun 14 2022, 06:56 AM
Looks fantastic great job. I believe you have one of my last mufflers as well. looks great.
autopro
Jun 14 2022, 08:55 AM
Looks awesome out in the sun, that paint really shines. Oh and congrats on the test drive!
bkrantz
Jun 14 2022, 07:27 PM
Thanks, everyone. That might have been the shortest test drive ever.
bkrantz
Jun 14 2022, 07:30 PM
I put the engine lid back on, and adjusted it to be as forward as possible.
bkrantz
Jun 14 2022, 07:32 PM
Clearance between the engine and trunk lids is better.
bkrantz
Jun 14 2022, 07:35 PM
I got out the trunk lid pin.
bkrantz
Jun 14 2022, 07:36 PM
And did one more test in the latch, to make sure it will open.
bkrantz
Jun 14 2022, 07:39 PM
First attempt, with the pin installed. Good news: it latches. Better news: it opens.
But the level of the closed lid is too high.
bkrantz
Jun 14 2022, 07:41 PM
I took the pin off, and adjusted the exposed length to be shorter.
bkrantz
Jun 14 2022, 07:42 PM
After two attempts, I have the height where I want it.
bkrantz
Jun 14 2022, 07:43 PM
So then I tried putting the roof into the trunk with the lid on. It fits into the clips and rubber latches and looks good.
bkrantz
Jun 14 2022, 07:45 PM
But...the lid will not close. ARGH!
bkrantz
Jun 14 2022, 07:46 PM
The rubber latches are already as far down as the stock adjustment allows.
bkrantz
Jun 14 2022, 07:50 PM
So I removed the latches, put the roof in, and the lid closes. The roof was sitting on the metal brackets that hold the latches, and the roof corners still had clearance above the tail light bodies.
bkrantz
Jun 14 2022, 07:51 PM
That means the latches have to sit about 3/16" lower, as shown here.
FlacaProductions
Do you have the top pushed all the way forward into the white clips up front?
bkrantz
Jun 14 2022, 07:52 PM
Trigger warning: purists might not want to look!
Step one: elongate the latch bolt holes.
bkrantz
Jun 14 2022, 07:54 PM
Step 2: modify the brackets so there is clearance between the notch for the roof edge and the top of the brackets.
bkrantz
Jun 14 2022, 07:55 PM
Here's my initial mod. I will neaten this up and make a couple of spot welds.
bkrantz
Jun 14 2022, 07:57 PM
Meanwhile, I got out my new PCA badge.
bkrantz
Jun 14 2022, 07:58 PM
This has the same problem as the 914 World badge: the 5mm studs are too thick for the stock grill holes. And the stud spacing is not quite right.
bkrantz
Jun 14 2022, 08:00 PM
So I did some drilling and filing, and then stuck some 4mm studs into the holes with JB weld.
Dion
Jun 14 2022, 08:53 PM
Looking fantastic. Paint looks outstanding in the sunshine.
Glad it fired up for ya. Quite the journey.
bkrantz
Jun 15 2022, 07:29 PM
QUOTE(Dion @ Jun 14 2022, 08:53 PM)
Thanks, Dion. The color still does not look true on my screen, but that's not a real problem.
bkrantz
Jun 15 2022, 07:32 PM
Before welding, I disconnected the battery, but first checked the clock: perfect after about 24 hours.
bkrantz
Jun 15 2022, 07:33 PM
I also disconnected the Megasquirt brain.
bkrantz
Jun 15 2022, 07:35 PM
Then I welded the new corners on both brackets. I used all the rags I had handy to protect paint and other surfaces from splatter. Also a good way to set lots of little fires.
bkrantz
Jun 15 2022, 07:36 PM
Then some grinding followed by a flappy sanding wheel.
bkrantz
Jun 15 2022, 07:37 PM
Primed (with a brush, since I figured I could get a final paint finish at least as good as it was).
bkrantz
Jun 15 2022, 07:39 PM
And painted. Should be ready to reassemble tomorrow.
bkrantz
Jun 15 2022, 07:40 PM
Meanwhile, I mounted the modified grille badge.
bkrantz
Jun 15 2022, 07:41 PM
Hardware below the grille.
