bkrantz
Apr 7 2022, 08:10 PM
Rear window channel with new fuzzy.
bkrantz
Apr 7 2022, 08:12 PM
New rear cap, after screwing the channel top to the door.
bkrantz
Apr 7 2022, 08:13 PM
Whoops! I went right past the 5000th post in my build thread. Now if only somebody can make an index.
bkrantz
Apr 8 2022, 06:39 PM
More on the left door today. New inner fuzzy and outer scraper.
bkrantz
Apr 8 2022, 06:40 PM
Bottom of rear window channel attached with oval head screws, as per PET. I went back to the right door to correct this, too.
bkrantz
Apr 8 2022, 06:42 PM
And then a new door weatherstrip. Again, a decent press fit without adhesive.
bkrantz
Apr 8 2022, 06:44 PM
Left door done for now. Final alignment will have to wait until I get my targa top back from the paint shop.
But it is nice to hear both doors close with a solid "thump".
bkrantz
Apr 8 2022, 08:21 PM
Latest white board.
bkrantz
Apr 10 2022, 07:09 PM
I started to track down my problem with the oil temp. The gauge seems to work (it flicks up slightly to indicate "cool"), but I have never seen it register any "heat".
I understand the sender should register about 1000 ohms when room temp. But I read a wide open circuit. (How do you like my custom probe extension?)
bkrantz
Apr 10 2022, 07:14 PM
While I was pondering the oil temp sender, the Fedex driver delivered my new brake master cylinder. This one is genuine ATE.
bkrantz
Apr 10 2022, 07:17 PM
Since I have been burned by bad warning swtiches, I tested the new one--and found the circuit closed. i.e. it would trigger the warning light.
bkrantz
Apr 10 2022, 07:19 PM
I pulled the new switch, and reset the plunger by pulling it out. Now the circuit is open.
bkrantz
Apr 10 2022, 07:21 PM
But I want to use my new dual-connector switch. I checked it again, installed it, and the circuit is open, as it should be.
bkrantz
Apr 10 2022, 07:22 PM
Now to install new washers and rubber bushings in the MC.
bkrantz
Apr 10 2022, 07:23 PM
Just a photo to remind me that I did not forget the washers!
bkrantz
Apr 10 2022, 07:25 PM
And new grommets, lubed with brake fluid.
bkrantz
Apr 10 2022, 07:26 PM
Meanwhile, in the car I detached the brake reservoir and pushed it down.
bkrantz
Apr 10 2022, 07:28 PM
This lets the lines project out the bottom, with enough slack to work the lines into the MC.
bkrantz
Apr 10 2022, 07:29 PM
Like this.
bkrantz
Apr 10 2022, 07:30 PM
Here's the new MC installed, with all the lines connected the the emergency warning switch leads attached.
bkrantz
Apr 10 2022, 07:33 PM
Hallelujah! For the first time I can turn on the ignition and the warning light is off!
bkrantz
Apr 10 2022, 07:34 PM
I re-attached the reservoir with the retaining strap, and I am ready (kinda) to start the bleeding process again.
raynekat
Apr 10 2022, 07:49 PM
Nice job on the master brake cylinder sleuthing Bob.
Puebloswatcop
Apr 11 2022, 05:49 PM
Really nice work Bob. Glad you resolved the brake mc problem.
bkrantz
Apr 11 2022, 06:54 PM
Thanks, guys. I guess the 914 "curse" affects even new parts.
bkrantz
Apr 11 2022, 06:57 PM
Meanwhile, I drive down to Albuquerque today to pick up my new windshield. Local vendors were not interested or able to help me. Rich at 914Werke came through, with the option to collect at a wholesale glass distributor.
Here's how to transport glass when your truck has an oil leak (and your wife's Mercedes is more comfy to drive, anyway).
Cairo94507
Apr 12 2022, 09:23 AM
Glad you sorted that master cylinder warning light issue. Nice windshield!
DRPHIL914
Apr 12 2022, 12:47 PM
QUOTE(bkrantz @ Apr 11 2022, 08:54 PM)
good job! looking good! I really hate that job, ihve ahd to do a new MC 3x in 12 years, most recently a year ago. i hope not to have to do this again for a long while.
car is looking great!!
Phil
930cabman
Apr 12 2022, 01:18 PM
QUOTE(bkrantz @ Apr 10 2022, 07:33 PM)
+1, every victory counts, what is your ETR?
Puebloswatcop
Apr 12 2022, 03:37 PM
Hey, That windshield looks quite comfy (and safe) in the wife's Mercedes, nice of her to allow such comfort for you both.
bkrantz
Apr 12 2022, 07:39 PM
QUOTE(Puebloswatcop @ Apr 12 2022, 03:37 PM)
Yes, my wife is very good to me--probably better than I deserve.
bkrantz
Apr 12 2022, 07:40 PM
QUOTE(930cabman @ Apr 12 2022, 01:18 PM)
I hate to set dates, but I am hoping for a first road test in June. We'll see.
bkrantz
Apr 12 2022, 07:41 PM
My one minute windshield installation! Just kidding. But I could not resist checking the fit. And for now, this is a relatively sage place.
bkrantz
Apr 12 2022, 07:42 PM
In case anyone is interested, here is the manufacturer info.
bkrantz
And the stocking info.
bkrantz
Apr 12 2022, 07:47 PM
Then I got onto to bleeding the brakes, for the second time. I used "dry" pressure again, up to about 30 psi.
bkrantz
Apr 12 2022, 07:48 PM
I made the rounds of all the calipers 3 times, and got a pretty firm pedal.
bkrantz
And used (so far) almost 3 liters of brake fluid.
bkrantz
Apr 14 2022, 07:28 PM
After the car sat for 48 hours, I checked the system for leaks--none. And the pedal feel--firm. But I decided to use the rest of the open bottle of brake fluid and bleed the system again. I got a couple of small bubbles from the rear calipers.
bkrantz
Apr 14 2022, 07:29 PM
I am feeling confident, so I put the reservoir fill screen back in.
bkrantz
And got out the new bleed nipple caps.
bkrantz
Apr 14 2022, 07:30 PM
Fingers crossed--the brake work is done, at least until after the initial break-in.
bkrantz
Apr 14 2022, 07:32 PM
With my confidence high, I got out the front suspension under tray. Kinda lumpy, but nicely powder-coated. And new edge rubber.
bkrantz
Rubber installed.
bkrantz
Apr 14 2022, 07:34 PM
I had to chase the threads in the mounting tabs on the cross member. My powder coat shop was generally very good about protecting threads, but these got coated. Not much room to spin the tap.
bkrantz
Apr 14 2022, 07:35 PM
Under tray installed. Reflections from my dryer vent tubing make it look lumpier than it is.
bkrantz
Apr 14 2022, 07:36 PM
Latest white board check. When all this is done, the car should be ready for a first road test.
930cabman
Apr 15 2022, 10:12 AM
QUOTE(bkrantz @ Apr 14 2022, 07:36 PM)
bkrantz
Apr 15 2022, 08:03 PM
I picked up my targa top at the paint shop today. Not quite stock (and not as glossy as it looks in the photo). I like it.
bkrantz
Apr 15 2022, 08:04 PM
Close up of texture.
