bkrantz
Mar 15 2023, 07:39 PM
Looks pretty good.
bkrantz
Mar 15 2023, 07:40 PM
I plugged the odometer reset cable in.
bkrantz
Mar 15 2023, 07:42 PM
Before installation, I needed to deal with there length of the speedo cable. Right now, it only barely reaches the gauge when installed.
bkrantz
Mar 15 2023, 07:45 PM
I pulled up the carpet and re-routed the cable.
bkrantz
Mar 15 2023, 07:46 PM
Now there is plenty of spare length.
bkrantz
Mar 15 2023, 07:47 PM
I put the rubber retaining ring on the gauge.
bkrantz
Mar 15 2023, 07:48 PM
Speedometer installed. It sure looks clean. The tach does not look as bad as the photo shows, but I already feel the need to take the glass off and clean it.
bkrantz
Mar 15 2023, 07:49 PM
Here's the reset cable.
bkrantz
Mar 15 2023, 07:51 PM
And everything put back together underneath. I did look at the brake pedal arm to see about trying to move the pedal a bit to the left, but that will have to wait for another time.
bkrantz
Mar 15 2023, 07:52 PM
Making progress.
bkrantz
Mar 15 2023, 07:53 PM
And losing progress. It looks like the oil strainer cover plate is leaking.
Van B
Mar 15 2023, 08:05 PM
A billet part here would be totally worth the money!
nivekdodge
Mar 15 2023, 08:26 PM
I've been trying to remove the set screw on the knurled nut for two years. Is there something I need to know? reverse thread or some thing? It's sitting in a sandwich bag with oil .
Kevin
930cabman
Mar 16 2023, 06:04 AM
I always use new paper gaskets and permatex sealant at this connection
bkrantz
Mar 16 2023, 09:39 PM
QUOTE(nivekdodge @ Mar 15 2023, 08:26 PM)
Kevin
Kevin, I had to drill out the original set screw, and then tap new larger threads. I made my own set screw from a cut-off section of machine screw.
bkrantz
Mar 16 2023, 09:47 PM
QUOTE(930cabman @ Mar 16 2023, 06:04 AM)
That's what I did. My best guess is that one of the gaskets did not seat properly.
I will have to drain and toss the new oil fill. I guess 4 quarts is cheap to make sure I get this leak stopped.
nivekdodge
Mar 17 2023, 12:47 PM
[quote name='bkrantz' date='Mar 16 2023, 11:39 PM' post='3065643']
[quote name='nivekdodge' post='3065396' date='Mar 15 2023, 08:26 PM']
Kevin
[/quote]
Thanks Bob
Kevin
bkrantz
Mar 18 2023, 10:05 PM
Another trip to Tucson, and another stop at my favorite (metal) store, Industrial Metal Supply. All kinds of steel and aluminum, including amazing cut-off scrap plate and bar sold by the pound. A true candy store for some of us.
ogdougy
Mar 18 2023, 10:25 PM
Hey, thats my second home. So many sheets of metal and trips to the scrap bin there.
bkrantz
Mar 27 2023, 07:15 PM
Home again, and the strainer cover continued to leak while I was gone.
bkrantz
Mar 27 2023, 07:17 PM
There goes 4 new quarts of Valvoline race oil.
And then I could not find my bag of spare gaskets, so have to order some for the strainer cover. Best I could tell, the leak was from the center retaining nut.
bkrantz
Mar 29 2023, 07:31 PM
While waiting for new gaskets, I got back to the interior. Earlier, I removed and replaced the internal door latch mechanisms, and also rebuilt the door stays. I got another liner kit from 914 Rubber.
bkrantz
Mar 29 2023, 07:32 PM
Starting on the left door, with adhesive strip attached all around.
bkrantz
Mar 29 2023, 07:34 PM
Plus the plastic liner. Note that with extreme adhesion of the butyl strip, this is essentially permanent--or at least not reusable.
bkrantz
Mar 29 2023, 07:35 PM
Door card on, plus the winder and the latch surround.
bkrantz
Mar 29 2023, 07:38 PM
Then my least favorite part: the retaining spring for the cover of the armrest bin. Last year this took me 20 minutes. This time, I got it on the first try.
bkrantz
Mar 29 2023, 07:39 PM
All done.
bkrantz
Mar 29 2023, 07:40 PM
Then I did the right door, with basically the same procedure.
bkrantz
Mar 29 2023, 07:41 PM
The difference is the lower part of the armrest. To install, this slides rearward onto these L-shaped fittings on the bottom of the armrest.
bkrantz
Mar 29 2023, 07:42 PM
Done here, too.
bkrantz
Mar 29 2023, 07:43 PM
View from the inside. Looks ready to drive.
bkrantz
Apr 9 2023, 06:54 PM
Back home again, and with snow mostly gone, it was time to start swapping out snow tires. I got two vehicles done, and then decided to do some sit-down work. Since I rebuilt the speedometer--and cleaned the glass--the other gauges have bothered me. So I yanked the tach.
bkrantz
Apr 9 2023, 06:56 PM
Unlike the speedo, the tach had never been opened, and it took some time to work around the retaining ring and slowly pry open the flange.
bkrantz
50 years of stuff on the inside of the glass.
bkrantz
Apr 9 2023, 06:57 PM
All cleaned and back together. Yes, the rim paint needs some touch-up.
bkrantz
Apr 9 2023, 06:59 PM
Back in place, and looks good. Now the left gauge needs cleaning. Maybe tomorrow.
bkrantz
Apr 10 2023, 07:34 PM
I removed the left gauge. I hope somebody took a picture showing where these wires go.
bkrantz
Apr 10 2023, 07:35 PM
Last one.
bkrantz
Apr 10 2023, 07:36 PM
Not as bad as the tach glass, but still dirty.
bkrantz
Apr 10 2023, 07:37 PM
Cleaned and reassembled.
bkrantz
Apr 10 2023, 07:38 PM
Happy clean glass all across.
Dion
Apr 10 2023, 08:14 PM
Beautiful work on the gauges!
bkrantz
Apr 11 2023, 08:06 PM
QUOTE(Dion @ Apr 10 2023, 08:14 PM)
Thanks. Once I got over the idea of opening the bezel ring, it was pretty simple.
bkrantz
Apr 12 2023, 07:27 PM
I got some vinyl caps, designed for 2.5 inch fence posts.
bkrantz
Apr 12 2023, 07:28 PM
I tied them together in pairs.
bkrantz
Apr 12 2023, 07:29 PM
And now have some handy covers for the intakes.
bkrantz
Apr 12 2023, 07:30 PM
Then I got out new gaskets for the strainer and drain plug.
bkrantz
Apr 12 2023, 07:31 PM
Strainer and cover installed--and I made sure it was seated evenly.
bkrantz
Apr 12 2023, 07:32 PM
And torqued properly.
bkrantz
Apr 12 2023, 07:33 PM
And the drain plug, too. Maybe this time it will not leak.
