bkrantz
Jul 21 2021, 06:53 PM
Then I did the same on the right side.
bkrantz
Jul 21 2021, 06:54 PM
Time for a new white board list. Engine stuff still has to wait for getting my case back.
raynekat
Jul 21 2021, 09:17 PM
QUOTE(bkrantz @ Jul 21 2021, 05:42 PM)
I trimmed the liner with a jig saw.
Did the same in a number of places for a "better" fit.
raynekat
Jul 21 2021, 09:18 PM
QUOTE(bkrantz @ Jul 21 2021, 05:52 PM)
That should be enough to keep the liner from shifting inward.
Great idea!
bkrantz
Jul 22 2021, 07:14 PM
New hose and grommet stock!
bkrantz
Jul 22 2021, 07:16 PM
Grommets are for the same hole size (20-22 mm) but with inner diameters for the plastic tubing or the braided hose.
bkrantz
Plumbing done in fender well.
bkrantz
Jul 22 2021, 07:17 PM
And along the rocker.
bkrantz
Jul 22 2021, 07:18 PM
Into the engine compartment.
bkrantz
Jul 22 2021, 07:19 PM
And by the fuel tank.
bkrantz
Jul 22 2021, 07:20 PM
Then I got out the rocker covers. They are a little lumpy, but I had them powder-coated so no filler allowed.
bkrantz
Jul 22 2021, 07:22 PM
I used stainless screws so I can easily open things up for cleaning.
bkrantz
Jul 22 2021, 07:23 PM
Left side on, and now I can finish the fender liners.
bkrantz
Jul 23 2021, 07:06 PM
I started on the left rear fender liner. I modified another clip for the leading edge
bkrantz
Jul 23 2021, 07:09 PM
Leading edge clip in place.
bkrantz
Jul 23 2021, 07:10 PM
On the trailing edge, the clip just reaches the hole.
bkrantz
Jul 23 2021, 07:13 PM
Test fitting the liner. It sits snugly against the outer edge, but leaves a gap along the inner wall, just in the line of fire of debris coming off the tire.
bkrantz
Jul 23 2021, 07:16 PM
Time to use some 1/8" rubber sheet, pop-riveted to the liner.
bkrantz
Jul 23 2021, 07:19 PM
Of course, today my rivet tool choked on one of the studs. I had to take it apart, and then it took me three attempts to get it back together and working properly.
bkrantz
Jul 23 2021, 07:20 PM
First fitting attempt: a bit wobbly.
bkrantz
Jul 23 2021, 07:22 PM
Second attempt: some slits, and the flaps lay tight against the inner fender.
bkrantz
Jul 23 2021, 07:24 PM
Of course, fussing with the rear side made me think about the exposure on the leading side. Stuff going this way creates the classic dirt pile inside the rocker covers.
bkrantz
Jul 23 2021, 07:27 PM
Maybe something like this? I need bigger rubber sheets. And to think some more.
bkrantz
Jul 23 2021, 07:29 PM
For now, it looks like this.
bkrantz
Jul 23 2021, 07:30 PM
The last thing I did today was mount the right side rocker cover.
bkrantz
Jul 24 2021, 07:16 PM
Next interior bit: speakers and pods.
I decided to use the standard design, since they take less physical and visual space. And since audio is a secondary goal for me.
bkrantz
Jul 24 2021, 07:18 PM
Here's how the left side fits, with limited space inside the box--as everyone knows.
bkrantz
Jul 24 2021, 07:20 PM
I got these Infinity plate speakers, which should fit, as bbrock demonstrated.
bkrantz
Jul 25 2021, 07:17 PM
The right side box sits too high for the screw holes to line up, by about 2 mm.
bkrantz
Jul 25 2021, 07:18 PM
I used a new utility blade to shave about 1.5 mm off the base edge.
bkrantz
Jul 25 2021, 07:21 PM
That was enough for things to line up.
bkrantz
Jul 25 2021, 07:23 PM
Now to develop some speaker mounting adapters.
bkrantz
Jul 25 2021, 07:25 PM
I made these from 1/4" MDF. Once I get some hardware I can see if everything fits.
bkrantz
Jul 26 2021, 07:00 PM
Here is my first version: the mounting board sits between the grill and the speaker.
bkrantz
Jul 26 2021, 07:01 PM
That leaves almost 1/2" between the grill and the face of the speaker.
bkrantz
Jul 26 2021, 07:02 PM
It does sorta fit, by bending the pod a bit.
bkrantz
Jul 26 2021, 07:04 PM
Here's the problem: the magnet of the mid-range speaker projects beyond the mounting plane of the back side of the pod.
bkrantz
Jul 26 2021, 07:13 PM
Here is version 2. Like Brent, I moved the mounting board to sit on the back side of the speaker plate.
bkrantz
Jul 26 2021, 07:14 PM
Modified boards, repainted.
bkrantz
Jul 26 2021, 07:16 PM
One more mod: for the speaker to sit closer to the grill, it has to sit between the pod mounting studs. But the speaker plate is about 4 mm too wide.
bkrantz
Jul 26 2021, 07:17 PM
So, a quick trim of the speaker plate. Original on the left, trimmed on the right.
bkrantz
Jul 26 2021, 07:18 PM
Now the speaker fits between the studs, and can sit flush on the inside of the grill.
bkrantz
Jul 26 2021, 07:20 PM
So now the speaker and the pod mount to the same side of the board. There is still a bit of space between the grill and the speaker.
bkrantz
Jul 26 2021, 07:22 PM
Now the speaker magnet protrudes just a little bit. But that's OK because...
bkrantz
Jul 26 2021, 07:23 PM
With the tweeter down, the mid range magnet almost aligns with the body panel hole.
bkrantz
Jul 26 2021, 07:24 PM
The paper template shows where the magnet projects, near the edge of the body hole.
bkrantz
Jul 26 2021, 07:26 PM
Just a quick bit of hammer work to ease the lower edge of the hole into the body cavity.
bkrantz
Jul 26 2021, 07:28 PM
A bit of paint touch-up.
bkrantz
Jul 26 2021, 07:31 PM
Everything fits, and the speaker magnet does not come close to contact with the body panel. Once I get all the necessary hardware and a few more components, I can mount the speakers for real.
bkrantz
Jul 28 2021, 08:13 PM
I counter-sunk the holes on the front of the speaker.
