bkrantz
Jun 26 2023, 07:12 PM
Clutch cable.
bkrantz
Jun 26 2023, 07:13 PM
Speedo cable, with a "boot" made from 3M rubber tape.
bkrantz
Jun 26 2023, 07:14 PM
Muffler and new flange gaskets.
bkrantz
Jun 26 2023, 07:15 PM
O2 cable, and then all the cables bundled and wrapped. Everything underneath done.
bkrantz
Jun 26 2023, 07:18 PM
Here is photo proof that I took the rag out of the oil fill cavity. No dumb spill this time.
bkrantz
Jun 26 2023, 07:19 PM
Oil filler in place. Tomorrow I will finish up.
Puebloswatcop
Jun 26 2023, 07:27 PM
Hoping for the best end of the leaks
bkrantz
Jun 27 2023, 07:35 PM
OK, all the wires laid out and first connections.
bkrantz
Jun 27 2023, 07:36 PM
And more photo evidence that I did not leave things inside other things.
bkrantz
Jun 27 2023, 07:38 PM
ITBs, more cables, vacuum lines, and fuel lines.
bkrantz
Jun 27 2023, 07:41 PM
OK, everything installed (except the air filters).
bkrantz
Jun 27 2023, 07:43 PM
The last thing I did today was test the fuel system. I cycled the key on about 3 times and listened for the pump going on and shutting itself off. No visible or smellable leaks.
bkrantz
Jun 28 2023, 08:12 PM
First test today. I cycled the ignition a few more times to check again for fuel leaks, and then started it. BTW, happy with the ITB injection and ignition that starts and idles on the first try.
I let it run for a few minutes, and then looked underneath--all good. Then I let it run for more than 20 minutes and it got up to temperature. Oil pressure reads good, and no idiot light--yet.
bkrantz
Jun 28 2023, 08:13 PM
Once warmed up, I checked the airflow balance from left to right.
bkrantz
Jun 28 2023, 08:14 PM
I shut it down and checked underneath. No leaks (yet) from the front galley plugs.
bkrantz
Jun 28 2023, 08:17 PM
And no signs of leaking (yet) from the cooler seals, and the overlying sender.
I will NOT claim any success until I can drive it a few times.
cassmcentee
Jun 28 2023, 09:40 PM
Congrats!
bkrantz
Jun 29 2023, 07:52 PM
Fudge! I checked underneath today after the engine cooled overnight. And this was waiting for me.
bkrantz
Jun 29 2023, 07:57 PM
It looks like the stock screw-in galley plug is leaking. The other plugs and seals don't show any leaks so I guess that's something.
Not sure what I want to do now. I might see if I can R&R the plug without dropping the engine, at least all the way.
bkrantz
Jul 1 2023, 05:00 PM
OK, fellow maniacs, I thought about this for a couple of days, including laying under the car to eye-ball and imagine, and I decided to try getting to the plug with the engine in place.
To do this, I removed the shift rod, all the heating ducts on the left side, the engine support cross bar, and the left front motor mount. At that point the access was not bad. (note the cross bar is still captured by the clutch cable)
bkrantz
Jul 1 2023, 05:01 PM
And here's the little bugger*, aka stock threaded galley plug.
*I have used other words not fit for a family 914 website.
bkrantz
Jul 1 2023, 05:02 PM
Even while unscrewing the plug, the leak is obvious, with oil-wet threads and no solid sealant.
bkrantz
Jul 1 2023, 05:03 PM
OK, now I have you!
bkrantz
And we will deal with you later.
Cairo94507
Jul 2 2023, 06:25 AM
Is that a crack running under the plug? Its appears like it has something on it right below the plug? I hope and pray I am wrong.
bkrantz
Jul 3 2023, 02:18 PM
QUOTE(Cairo94507 @ Jul 2 2023, 06:25 AM)
Not a crack (I hope!) but a surface scratch and/or a casting mark.
bkrantz
Jul 3 2023, 02:19 PM
OK, I decided to try sealing the plug today. First I made sure it was as clean as possible, and without any problems with threads.
bkrantz
Jul 3 2023, 02:20 PM
Then I did the same for the galley opening.
bkrantz
Jul 3 2023, 02:21 PM
I reverted to the sealant that worked the first time with this plug.
bkrantz
Jul 3 2023, 02:22 PM
Plug installed, along with the engine mount and cross bar. I plan to let this sit for 24-48 hours, and then run the engine and check for leaks before I put and ductwork and other stuff back together.
930cabman
Jul 4 2023, 06:52 AM
Steel plug/aluminum case. I have seen this debate in the past ......
Fingers crossed, hope you got it this time. I think many of us are chasing a leak in this area, but I for one just leave it. Too many fish frying
bkrantz
Jul 4 2023, 08:43 PM
QUOTE(930cabman @ Jul 4 2023, 06:52 AM)
In the hot oil?
Speaking of hot oil, I ran the motor up to temp and shut it off. No visible leak yet, but I will wait to see after it cools off.
Cairo94507
Jul 5 2023, 07:34 AM
Puebloswatcop
Jul 5 2023, 06:20 PM
waiting with anticipation....
bkrantz
Jul 5 2023, 08:24 PM
And......no.
bkrantz
Jul 5 2023, 08:25 PM
Just like last time, the morning after was not good news. Still looks like the galley plug is leaking. I will have to remove the cross bar again to be sure. That means dumping another oil fill with 0 miles.
Lilchopshop
Jul 6 2023, 04:32 AM
Have you considered trying to find an Aluminum plug? The CTE will match the case material so you should have less gapping when the case gets warm. I don't know what thread size this is, but there are some aluminum galley plug kits available for VW motors.
You could also try thread tape instead of (or in addition to) the sealant you've been using. This stuff (available at big box home stores) will stand up to almost all fluids.
https://www.oatey.com/products/oatey-yellow...ape--1863212606I admire your determination and appreciate you sharing your trials and tribulations!
-Aaron
Cairo94507
Jul 6 2023, 06:49 AM
DRPHIL914
Jul 6 2023, 07:17 AM
@bkrantz man that sucks! wow, i agree that maybe different plug will fix this?
- the rest of it is soo clean! i wrapped my cables just like yours, i am also fighting a leak on my new 2.1 motor and i think its seeping from the head-cylinder interface!! verified my new oil cooler seals and pump seal and galley plugs are dry this time along with the new RMS no leaks but man i know how frustrating it is.
I have a question, what are you using for modern EFI
I control, is it the Holley system?
Phil
Ottomotion
Jul 6 2023, 08:53 AM
[/quote]
The more I look at the pics (not just this one) the more it looks like a crack repair......that has failed. Probably over torqued at some point in engine's past? otherwise strange spot for a crack.
BillJ
Jul 6 2023, 01:04 PM
When i had the 4cyl race engine done on the scca car (Gumby) the builder used aluminum not steel. The cooling differential is too high.
bkrantz
Jul 6 2023, 07:25 PM
QUOTE(DRPHIL914 @ Jul 6 2023, 07:17 AM)
Phil
Thanks.
I installed a MegaSquirt 2 with an integrated system put together by Mario at the Dub Shop. He supplied an initial tune file that started the first time, and then was modified by tuning on a dyno.
If I can ever get the oil leaks fixed, I will get back to tuning.
bkrantz
Jul 6 2023, 07:26 PM
[quote name='Ottomotion' date='Jul 6 2023, 08:53 AM' post='3087704']
[/quote]
[/quote]
Possible but I still think/hope not. See the photos below.
bkrantz
Jul 6 2023, 07:27 PM
I removed the cross bar and left motor mount again. Here's the plug, which looks much like last time with oil showing around the lower half of the plug-case joint.
bkrantz
Jul 6 2023, 07:29 PM
Under UV light before any cleaning. Most of the joint surrounding the plug looks oily.
bkrantz
Jul 6 2023, 07:31 PM
As I unscrewed the plug, the sealant was uncured and very fluid. Again.
bkrantz
Jul 6 2023, 07:34 PM
To check for a crack I used a mirror to get a look at the inside after cleaning it with solvent on a rag. I figure just like a normal crack test, any oil would act like a dye and light up the crack. I did not see anything like that.
bkrantz
Jul 6 2023, 07:35 PM
Just like last time, with different sealant, the plug threads look oily and without cured sealant--and potentially leaky.
bkrantz
Jul 6 2023, 07:50 PM
QUOTE(BillJ @ Jul 6 2023, 01:04 PM)
I have thought about this. As best I can tell the plug is M22 x 1.5, and the stock plug is steel. You are right: depending on the type of steel and and the aluminum alloy in the case, the thermal expansion will be 2 to 3 times higher in the case.
I cannot find an aluminum plug but did find a brass plug to order. Brass is much closer the the thermal expansion of aluminum.
Once I get this, I will use a "permanent" type sealer, like Form-a-gasket #1. If that does not work, I might go nuclear and use JB Weld.
r_towle
Jul 6 2023, 08:02 PM
Good luck, that is certainly a pesky annoying issue.
