bkrantz
Jul 28 2021, 08:14 PM
Speaker mounted to board.
bkrantz
Jul 28 2021, 08:15 PM
Board and speaker mounted to pod.
bkrantz
Jul 28 2021, 08:16 PM
Pod, board, and speaker mounted to car.
djway
Jul 28 2021, 10:05 PM
Rock On
bkrantz
Jul 29 2021, 09:19 PM
QUOTE(djway @ Jul 28 2021, 10:05 PM)
Rock On
Now I just need a source!
bkrantz
Jul 29 2021, 09:21 PM
Today, I played with the frunk floor, starting with what came in my car. This looks essentially black.
bkrantz
Jul 29 2021, 09:24 PM
First, I undid some PO staples along the rear edge. This exposed a flap of perlon, and the original(?) gray color.
bkrantz
Jul 29 2021, 09:27 PM
After I removed all the perlon, I exposed the plywood, that I think is OE.
bkrantz
Jul 29 2021, 09:28 PM
But it looks just a little warped.
bkrantz
Jul 29 2021, 09:30 PM
The OE plywood fits almost precisely sitting on the floor, without a spare tire in place. Of course, this means a very sloppy fit when the plywood sits on top of a spare.
bkrantz
Jul 29 2021, 09:32 PM
Speaking of spares, this is what came in my car, a Sears Guardsman in 5.6 x 15.
bkrantz
Jul 29 2021, 09:33 PM
That's some serious tread--almost 4 inches wide!
bkrantz
Jul 29 2021, 09:35 PM
Here's what I am thinking about: a larger plywood piece, that will fit more precisely while sitting on top of the spare tire.
Puebloswatcop
Jul 30 2021, 07:20 AM
I really like the idea for the new frunk floor, I think it will be much better than the old one perched on top of the spare.
bkrantz
Jul 30 2021, 06:57 PM
QUOTE(Puebloswatcop @ Jul 30 2021, 07:20 AM)
Thanks. It should be more stable and usable. Plus I get to make another "improvement".
djway
Jul 30 2021, 10:36 PM
QUOTE(bkrantz @ Jul 29 2021, 08:19 PM)
Rock On
I'm going the phone to Bluetooth into the equalizer attached to an amplifier. Everything is out of sight.....mann
bkrantz
Jul 31 2021, 08:30 PM
QUOTE(djway @ Jul 30 2021, 10:36 PM)
Rock On
I have a similar idea--stay tuned (get it?).
bkrantz
Jul 31 2021, 08:32 PM
More hardware arrived, so I can finished my fender liner installation.
bkrantz
Jul 31 2021, 08:33 PM
Here is the right rear liner, with my rubber shield mod.
bkrantz
Jul 31 2021, 08:34 PM
Liner installed. If you missed my earlier posts, the rubber covers the gap between the liner and the inner fender wall.
bkrantz
Jul 31 2021, 08:36 PM
Then a bit of trivia. I dug out the jack tube covers.
bkrantz
Jul 31 2021, 08:37 PM
After a bit of clean-up.
bkrantz
Jul 31 2021, 08:47 PM
I finally got out the targa top. The outside actually look OK.
bkrantz
Jul 31 2021, 08:48 PM
At some time, a PO had it covered with vinyl. It has a few small nicks.
bkrantz
Jul 31 2021, 08:50 PM
But the vinyl is pulling away, especially along the "rain gutters".
bkrantz
Jul 31 2021, 08:51 PM
Inside, the front latches and pad look OK.
bkrantz
Jul 31 2021, 08:52 PM
But most of the rubber, and one mounting block are sad.
bkrantz
Jul 31 2021, 08:54 PM
Here's the inside all stripped. I will take the vinyl off the outside, and then figure out how to refinish it.
bkrantz
Aug 1 2021, 06:43 PM
Detail of the PO vinyl covering, wrapped over the trailing edge.
bkrantz
Aug 1 2021, 06:45 PM
I undid the various glues: contact cement over the main surface, red glue where the vinyl was wrapped under, and black silicone along some edges.
bkrantz
Aug 1 2021, 06:46 PM
Pulling the vinyl off. Surprise! Some earlier damage.
bkrantz
Aug 1 2021, 06:48 PM
De-skinned. More damage spots and lots of dried up contact cement, that was pretty impervious to all the solvents I tried.
bkrantz
Aug 1 2021, 06:50 PM
After an hour with a brass wire brush. Next, I will visit my paint shop and see if they can try to duplicate the original splatter finish.
bkrantz
Aug 2 2021, 07:51 PM
While waiting to get my engine case back, I found another diversion. When I got the body back from the paint shop, I noticed a few seams that needed more sealing. For various reasons, I did not take action early on--my bad. I went back and forth on leaving it alone, but finally decided to do something.
So, my half-baked and late plan: use some brush on seam sealer, followed by brush on primer and paint.
Here's where I started, on the right side along the edge of the new floor panel I welded in. On the right side, you can see the open seam edge. On the left, I started brushing on sealer, and then stippling it to look a little like the remaining sprayed-on sealer.
bkrantz
Aug 2 2021, 07:56 PM
I did both sides, plus seam across the floor between the new rear section and the original front section, and the front floor corners where I welded in patches.
bkrantz
Aug 3 2021, 07:26 PM
My engine case is back in the house (garage actually, but I did use the kitchen sink and sprayer to wash out any dirt and debris--don't tell my wife). Thanks to European Motorworks for rapid and quality work.
bkrantz
Aug 3 2021, 07:28 PM
George and crew did the decking, with a wide enough cut so my AA cylinders can sit flat.
bkrantz
Aug 3 2021, 07:30 PM
And also did a line bore, to 0.25 mm oversize. Now I can hope again that everything will be straight.
bkrantz
Aug 3 2021, 07:31 PM
I got out all the studs I had removed and cleaned.
bkrantz
Aug 3 2021, 07:32 PM
And I got started installing the studs in the case halves. Good thing I took notes on locations.
raynekat
Aug 3 2021, 11:02 PM
QUOTE(bkrantz @ Aug 1 2021, 05:50 PM)
Instead of going original splatter finish with your roof panel, consider this.....
A nice leopard vinyl might make your car really growl???
If that is too bold for you, perhaps it would work as your headliner.
Click to view attachment Click to view attachment Of course you might attract some of the local riff raff unfortunately.
djway
Aug 3 2021, 11:48 PM
Did you remember to get your thrust bearing cut?
autopro
Aug 4 2021, 09:39 AM
The work on your engine looks great. I just took mine over there a couple of weeks ago also. They are great guys to deal with.
Love all the picture, keep them coming.
bkrantz
Aug 4 2021, 08:58 PM
QUOTE(raynekat @ Aug 3 2021, 11:02 PM)
Click to view attachmentOK, now that's just silly. But maybe a shag finish?
bkrantz
Aug 4 2021, 09:06 PM
I got to work today, since I want to get the enginery assembly done ASAP so I can measure deck height.
Here are the cylinder studs ready, and new thread sealant.
bkrantz
Aug 4 2021, 09:07 PM
Then the threaded plugs.
bkrantz
Aug 4 2021, 09:08 PM
Engine case halves ready.
bkrantz
And the right half mounted on the stand again.
bkrantz
Aug 4 2021, 09:15 PM
Now to replace the #3 bearing. This is from my previous build attempt, correct for a standard size case saddle. Of course to change this bearing, I had to pull the timing gear and other stuff on the crank nose.
bkrantz
Aug 4 2021, 09:17 PM
Since I did not want to remove the con rods, and deal with the crank plus rods on my press, I rigged up a gear puller. It took little force to pull the distributor gear, and just a bit more to pull the timing gear.
