bkrantz
Jan 16 2023, 08:39 PM
But the problem turns out to be one of the bushings.
bkrantz
Jan 16 2023, 08:43 PM
At some point the nylon(?) bushing stopped turned, and wore through on one side. This eliminates the pressure the bushings impose on the aluminum arm. Time for the rebuild kit with new bushings.
bkrantz
Jan 16 2023, 08:45 PM
But feeling optimistic, I tried to install the bushing rotated 180°. That worked for exactly 1 door closing and opening before the bushing spun around to the worn position.
bkrantz
Jan 16 2023, 08:46 PM
Then I dug into the trunk lock. When I set this up last year, the key worked fine with the lock on the bench. Now the key does not turn.
bkrantz
Jan 16 2023, 08:47 PM
Lock back on the bench. Still does not work.
bkrantz
Jan 16 2023, 08:48 PM
All apart.
bkrantz
Jan 16 2023, 08:51 PM
Time to fine-tune the lock sliding pins. When I got this lock last year, I moved the pins around to get the best fit possible, but then had to shorten a few. The red pins stick out just a bit.
nivekdodge
Jan 16 2023, 08:56 PM
QUOTE(bkrantz @ Jan 16 2023, 09:45 PM)
Thank god , it's not just me that this happens to.
Kevin
930cabman
Jan 17 2023, 05:54 AM
QUOTE(bkrantz @ Jan 16 2023, 09:35 PM)
Some (or lots) of grease on the mechanism and linkage seems to get the lock working.
I have found removing the latch/locking mechanism works well to clean the 1/2 century of crud and then lube. Adding lube seems to compound the issue
930cabman
Jan 17 2023, 05:55 AM
QUOTE(bkrantz @ Jan 16 2023, 09:24 PM)
QUOTE(930cabman @ Jan 16 2023, 05:01 AM)
With a very thin paper gasket?
Good question. I would like to hear from others. I did not use a gasket originally.
The Schadek pump I installed on my last build had a very thin paper gasket.
bkrantz
Jan 17 2023, 08:49 PM
QUOTE(nivekdodge @ Jan 16 2023, 07:56 PM)
Kevin
Yup, the foolish optimist club. That might include all 914 owners.
bkrantz
Jan 17 2023, 08:51 PM
QUOTE(930cabman @ Jan 17 2023, 04:54 AM)
I had the inner mechanisms out, solvent-soaked, and then replated during my build. I gave them a light dose of grease before installing. Now I have progressed to the max grease stage.
bkrantz
Jan 17 2023, 08:52 PM
QUOTE(930cabman @ Jan 17 2023, 04:55 AM)
Thanks. Any other viewpoints out there?
930cabman
Jan 18 2023, 05:56 AM
QUOTE(bkrantz @ Jan 17 2023, 09:49 PM)
Kevin
Includes me for sure
nivekdodge
Jan 19 2023, 09:16 PM
930cabman
Jan 21 2023, 02:40 PM
Returning to the oil pump "leak", I have a new Schadek on the shelf waiting for the time to get the next build going. Today I measured the thickness of the paper cover gasket - in the .003 range. Hope this helps
I am having the same issue with small oil leaks, watching this thread, thanks in advance Bob
bkrantz
Jan 21 2023, 07:57 PM
Back to 914 work today. I have been distracted all week by snow, with shoveling adventures on Sunday, Monday, Monday, Tuesday, Wednesday, and Friday. I have about 2500 sq ft of driveway, and feel stubborn enough to usually do it by hand. But this week I got the machine out.
bkrantz
Jan 21 2023, 07:58 PM
Anyway, I finished evening out the slide pins on the trunk lock.
bkrantz
Jan 21 2023, 07:59 PM
Here's the lock assembled.
bkrantz
And installed in the trunk wall.
bkrantz
Jan 21 2023, 08:00 PM
It works! Now I can lock (and unlock) the trunk.
bkrantz
Jan 21 2023, 08:02 PM
Back to working on the door locks. I removed the right door interior hardware and door card.
bkrantz
Jan 21 2023, 08:03 PM
With the plastic sheet removed (and destroyed) I greased the lock mechanism. Really greased it.
bkrantz
Jan 21 2023, 08:04 PM
Just like the left side, the key in the exterior handle now locks the door (and the interior lock tab closes flush).
bkrantz
Jan 21 2023, 08:05 PM
And then the key easily unlocks the door.
bkrantz
Jan 21 2023, 08:06 PM
To see if the door card interferes with the locking rod, I temporarily reinstalled it.
bkrantz
Jan 21 2023, 08:08 PM
Still works!
And as others suggested, I checked for interference from the screw that holds the plastic surround for the interior lever. With the screw in place, the lock still works fine.
bkrantz
Jan 21 2023, 08:09 PM
OK, that's one more task done.
bkrantz
Jan 22 2023, 08:25 PM
I got these door stay rebuild kits delivered yesterday.
bkrantz
Jan 22 2023, 08:26 PM
Pretty easy to strip the stays apart, and remove the old arms, springs, and rollers.
bkrantz
Jan 22 2023, 08:28 PM
One side rebuilt.
bkrantz
Jan 22 2023, 08:29 PM
And installed. Now this door has two firm opened positions. And I can remove the blue tape X to remind me not to open the door too far without the stay.
bkrantz
Jan 22 2023, 08:33 PM
I actually did both sides.
bkrantz
Jan 23 2023, 08:04 PM
Back to working on oil leaks, and the pump. I set up my digital caliper with a plunge adapter.
bkrantz
Jan 23 2023, 08:05 PM
Measuring from the face of the pump to the tops of the gears.
bkrantz
Jan 23 2023, 08:07 PM
I got measurements from .000" to .002", with most in the range of .0005" to .001"
bkrantz
Jan 23 2023, 08:08 PM
The gasket I have in my supply measures .0045" thick.
As I understand, optimum gear clearance is .003", so I need a thinner gasket.
bkrantz
Jan 23 2023, 08:09 PM
Before quitting, I took out the clock. I am still bummed that it worked for months, and then quit.
bkrantz
Jan 23 2023, 08:11 PM
And I pulled the speedometer, too. This read about 10 mph off, and the odo never worked. I still have not decided if I want to try this myself or send it off (or source another one).
bkrantz
Jan 25 2023, 08:53 PM
OK, time to start another project.
I want to add an oil pressure gauge. And I want to keep the idiot light.
From what I understand, the VDO dual sender triggers the idiot light at 7 psi, which is too high. Better to keep the stock pressure sensor, which triggers at 3 psi.
I also know that one popular solution is to mount a T-fitting on a flex hose. But the flax hose makes me nervous, so I want to try a solid approach. That can have other problems, but I have some ideas--have to see how things work out.
Anyway, here is a VDO brass adapter.
bkrantz
Jan 25 2023, 08:55 PM
A trial fitting. Yes, the stock sensor will live inside the air ducting, and will need an extension for the wire.
bkrantz
Jan 25 2023, 08:57 PM
A view from above the sheet metal. The stock hole will probably need enlarging for the VDO sender. That was supposed to get delivered yesterday, but my local USPS is full of excuses.
bkrantz
Jan 25 2023, 08:59 PM
The pressure gauge will also need a new wire from the engine to the center console. Here I started the new yellow wire through the snorkel. Why yellow? Duh.
bkrantz
Jan 25 2023, 09:00 PM
Into the center tunnel.
bkrantz
Up to the shift console.
bkrantz
Jan 25 2023, 09:01 PM
Ready for the gauge.
bkrantz
And ready at the engine end.
bkrantz
Jan 28 2023, 07:48 PM
A bit more progress (or planning) for the oil pressure system. Here is the VDO sender. I got the dual sender, even if I don't use the low pressure trigger.
bkrantz
Jan 28 2023, 07:49 PM
The hole in the sheet metal is tool small, but not by much. I will worry about this later.
bkrantz
Jan 28 2023, 07:51 PM
Here's the configuration I have in mind. I know this has a bit of weight unsupported, and could lead to fatigue.
