bkrantz
Apr 25 2022, 08:11 PM
And then--slowly--seated the inner lip. Did I say these are thick?
bkrantz
Apr 25 2022, 08:12 PM
Right side done.
bkrantz
Apr 25 2022, 08:13 PM
And then the left. I trimmed off the excess (first rough cut) after this photo.
bkrantz
Apr 25 2022, 08:14 PM
Test fit of the roof. The right side looks pretty good.
bkrantz
Apr 25 2022, 08:15 PM
The left side not so good. Ugh.
bkrantz
Apr 25 2022, 08:18 PM
I figured the roof needs hardware to fit correctly, starting with the front latches.
bkrantz
And new rubber latch blocks for the rear.
bkrantz
Apr 25 2022, 08:19 PM
Roof with hardware.
bkrantz
Apr 25 2022, 08:21 PM
It latches on pretty easily, snug in front but with a bit of vertical freeplay in the rear. Of course, I have not yet mounted the rear weather-strip.
bkrantz
Apr 25 2022, 08:23 PM
Rear alignment needs work. The right side edge sits just inboard of the targa hoop corner.
bkrantz
Apr 25 2022, 08:24 PM
While the left side edge sits outboard.
bkrantz
Apr 25 2022, 08:26 PM
Just to get depressed, I rolled up the left window to see how bad things look. Ugh again. Did I mention that I don't like weatherstrips and seals?
bkrantz
Apr 28 2022, 07:26 PM
A little diversion: checking the fit of the targa top in the trunk.
bkrantz
Apr 28 2022, 07:27 PM
And then checking the clearance of my new EFI stuff under the forward edge of the top. Looks OK (and room for a cover over the EFI).
bkrantz
Apr 28 2022, 07:30 PM
Back to working on rubber piece alignment. I pulled off the front seals and worked on fitting the A-pillar trim.
bkrantz
Apr 28 2022, 07:32 PM
And I got the rubber seal remounted a bit higher.
bkrantz
Apr 28 2022, 07:34 PM
Then I remembered something (duh). When I mounted the side seal trim strips, I forgot to put butyl tape between the trim and the top. So I got out my roll of 1/2 x 1/8 butyl tape.
bkrantz
Apr 28 2022, 07:35 PM
Trim mounted with butyl. And then I went through the fun of installing the side seals (again).
bkrantz
Apr 28 2022, 07:36 PM
Yay! Left side alignment now looks good.
bkrantz
Apr 28 2022, 07:37 PM
And the right side is good, too.
bkrantz
Left window also looks good.
bkrantz
Apr 28 2022, 07:39 PM
But the right window needs some work, since it closes a bit uneven along the top.
raynekat
Apr 28 2022, 08:41 PM
To me, getting the windows and the targa top seals to fit was the biggest PITA job on the entire car.
Took many, many hours.
Puebloswatcop
Apr 28 2022, 09:27 PM
Looks great Bob. That job has to suck....
bkrantz
Apr 29 2022, 07:15 PM
QUOTE(raynekat @ Apr 28 2022, 08:41 PM)
Maybe I should never take it outside where it might get wet, or dirty and need washing. Then I will not need seals, right?
bkrantz
Apr 29 2022, 07:16 PM
QUOTE(Puebloswatcop @ Apr 28 2022, 09:27 PM)
Yeah. See the thread I started about least favorite 914 jobs.
bkrantz
Apr 29 2022, 07:18 PM
I needed a break from playing window adjuster, so I tackled the targa top rear seal. Here is the replacement I got from 914 Rubber. I know it can be installed as-is, but I want to duplicate the original.
bkrantz
Apr 29 2022, 07:19 PM
First, I test fitted the metal strips, including the side pieces that were molded into the original rubber seal.
bkrantz
Apr 29 2022, 07:21 PM
Starting to modify the rubber. I removed the flat flaps from the side sections, and trimmed about 3 mm from the flap along the transverse section.
bkrantz
Apr 29 2022, 07:22 PM
The side sections are a bit too long, so I trimmed them to fit.
bkrantz
That's better.
bkrantz
Apr 29 2022, 07:24 PM
I used 3M weatherstrip adhesive to first glue the entire rubber piece to the top, and then some glue on the side metal sections.
bkrantz
Apr 29 2022, 07:26 PM
The side metal sections went into slits made in the rubber "cylinder", and then I screwed everything down with new SS hardware.
bkrantz
Apr 29 2022, 07:27 PM
Then to mimic the original molded-on rubber, I glued the slit rubber to the top (bottom) of the side metal pieces.
bkrantz
Apr 29 2022, 07:28 PM
Some ever popular blue tape to hold things in place.
bkrantz
Tomorrow, I will find out if this worked.
bkrantz
May 1 2022, 07:20 PM
Next step: replacing the original headliner, which the PO painted, what for it, black.
bkrantz
May 1 2022, 07:22 PM
The small tag on the glue side makes me think this was a factory piece, and probably original to the top.
bkrantz
May 1 2022, 07:23 PM
I traced the original onto replacement bulk perlon, dark charcoal.
bkrantz
May 1 2022, 07:26 PM
Time once again for Weldwood adhesive spray. I spent almost an hour masking off the top, and then sprayed both the top (light coat) and perlon (heavy coat).
bkrantz
New perlon headliner in place.
bkrantz
May 1 2022, 07:28 PM
Last piece: the front pad strip.
First, a good cleaning.
bkrantz
May 1 2022, 07:30 PM
Then, a treatment with Car Guys Plastic Restorer, and sitting for 20 minutes.
bkrantz
May 1 2022, 07:31 PM
Finally, a treatment with Nextzett Cockpit Cleaner to take off the shine.
bkrantz
May 1 2022, 07:32 PM
Pad strip installed with original screws.
bkrantz
May 1 2022, 07:34 PM
Completed top on the car, and checking the fit of the rear weatherstripping. Looks good.
bkrantz
May 1 2022, 07:35 PM
A few more items checked off the list!
Puebloswatcop
May 1 2022, 07:40 PM
Very Nice.....
Olympic 914
May 1 2022, 07:44 PM
Beautiful work.
Like the fit of the roof and windows.
Need to work on mine.
bkrantz
May 2 2022, 07:41 PM
Thanks, guys. I am still messing with the right window. I got it a little better, but still not 100%.
