Cairo94507
Jun 27 2020, 06:22 AM
That car was definitely nicely secured on the trailer. I'm thinking you could have driven it across the country with no issues at all. Good job. I can't wait to see it being body worked and then color!
9146C
Jun 27 2020, 08:14 AM
I've really enjoyed following your build. Looking forward to the completion. Well done!
bkrantz
Jun 27 2020, 10:23 PM
QUOTE(Cairo94507 @ Jun 27 2020, 06:22 AM)
I might have been a little paranoid, but I worked out. I also wanted to set it up so when it comes home with fresh paint, nothing has to touch that paint.
bkrantz
Jun 28 2020, 08:20 PM
I spent most of yesterday and today cleaning and reorganizing the garage (and fabricating a new post for our deck shade structure). With things moved around, I could get to the 914 motor. Don't be jealous of the awesome red paint on the head covers and pushrod tubes.
bkrantz
Jun 28 2020, 08:23 PM
We ended the day by getting the motor up on the stand. More jealousy: red on the blower housing and intakes (and also on the exhaust and trans).
bkrantz
Jun 29 2020, 08:28 PM
I stopped by the body shop to drop off the brackets to mount the car on their rotisserie. Here are a few other cars in progress there.
bkrantz
Jun 29 2020, 08:30 PM
More outside.
bkrantz
And inside.
bkrantz
Jun 30 2020, 08:13 PM
Before starting on tear down, I made some space to lay things out. I repurposed the plywood from the trailer cradle into a work table.
bkrantz
Jun 30 2020, 08:16 PM
After some inspection, and labeling, and photos, I stripped off everything from the topside.
bkrantz
Jun 30 2020, 08:17 PM
The first round of parts to clean and inspect.
bkrantz
And the new list.
bkrantz
Jul 1 2020, 08:40 PM
Today, I stripped the outside of the engine. Everything came off easily, except one cheesehead screw. Given that this screws into the top of the case, I took some care. That turned into about 30 minutes of penetrating oil, finesse with a beefy screwdriver, heating with a torch, and finally lots of "gentle" taps with a hand impact tool. Eventually, it gave up.
bkrantz
Jul 1 2020, 08:41 PM
With the sheet metal off, I could see the tops of the cylinders. I was a little disappointed not to find an official 914 mouse nest, but a fair amount of crud made up for it.
bkrantz
Jul 1 2020, 08:42 PM
Right side
bkrantz
Jul 1 2020, 08:43 PM
Left side
bkrantz
Jul 1 2020, 08:44 PM
Next, we get to look inside, and see what is hiding there.
djway
Jul 1 2020, 09:58 PM
that is a lot cleaner than most I have opened up
Rock On
bkrantz
Jul 2 2020, 08:03 PM
I opened up the engine today. Good thing I still have an official 914 pry tool, from previous ownerships.
bkrantz
Valve train all present and looking OK.
bkrantz
Jul 2 2020, 08:05 PM
A couple of the adjusting screws have pits.
bkrantz
Jul 2 2020, 08:06 PM
Everything came off easily: push rod tubes, heads, cylinders.
bkrantz
Jul 2 2020, 08:09 PM
I need to clean off the carbon and crud, but the heads look OK so far. Left side.
bkrantz
Jul 2 2020, 08:10 PM
Right side.
bkrantz
Jul 2 2020, 08:11 PM
The cylinders even show cross hatching and no signs of wear.
bkrantz
Jul 2 2020, 08:13 PM
Next up: removing the pistons and miscellaneous, and then splitting the case.
bkrantz
Jul 2 2020, 08:14 PM
Progress on the latest list.
bkrantz
Jul 3 2020, 08:42 PM
Pistons out. Looking OK, but with a lot of oily carbon crud on top.
bkrantz
Jul 3 2020, 08:43 PM
Oil pump, exterior view.
bkrantz
Jul 3 2020, 08:47 PM
Oil pump, interior. Anyone recognize this pump?
bkrantz
Jul 3 2020, 08:49 PM
So, after removing the 6 main case bolts, and undoing 20 fasteners around the perimeter and elsewhere, I am ready to split the case. But the seam is resisting.
raynekat
Jul 3 2020, 09:13 PM
Click to view attachment I'd bet something like this could split the case halves.....
ClayPerrine
Jul 3 2020, 10:12 PM
Did you get the bolt that goes through the windage tray? It is between the two cylinder spigots in a recess.
Kansas 914
Jul 4 2020, 09:58 AM
QUOTE(ClayPerrine @ Jul 3 2020, 10:12 PM)
It was the same one I didn't see when I first split a case.
bkrantz
Jul 4 2020, 08:33 PM
All the bolts were out (I counted them at least a dozen times).
I tried the method of prying between the front shaft impeller flange and the front seal. After a gentle pry, the seam opened up along the front, but the back was still stuck. I resorted to some plastic wedges (door frame shims), and that did the trick.
bkrantz
Jul 4 2020, 08:36 PM
Inside the case looks very good. Left side.
bkrantz
Right side.
bkrantz
Jul 4 2020, 08:37 PM
Number 2 bearing looks good.
bkrantz
Jul 4 2020, 08:38 PM
Cam bearings also look good.
bkrantz
Jul 4 2020, 08:39 PM
The cam lobes look very good.
bkrantz
But the bolt-on cam is not stock, right?
bkrantz
Jul 4 2020, 08:40 PM
The crankshaft, fully assembled.
bkrantz
Jul 4 2020, 08:41 PM
The number 1 bearing and journal.
bkrantz
Jul 4 2020, 08:43 PM
Rigged up to pull the camshaft drive gear.
bkrantz
The gear itself looks very good.
bkrantz
Jul 4 2020, 08:44 PM
Time to remove the connecting rods.
bkrantz
Jul 4 2020, 08:45 PM
The number 1 con rod bearing looks good.
bkrantz
Jul 4 2020, 08:46 PM
But the number 2 bearing shows a bit more wear. This is the worst one.
bkrantz
Jul 4 2020, 08:49 PM
All the crank journals look great.
After a quick measuring session, the mains are about 2.3520 inches, suggesting these were ground one step undersize.
And the con rod journals are about 1.959 inches, two steps undersize.
bkrantz
Jul 5 2020, 08:30 PM
A bit more tinkering today, starting with removing the oil pressure relief valve. Step one was to make a tool to fit the slot profile in the cap.
