bkrantz
May 8 2021, 08:12 PM
I got out my junk soldering iron, and applied a bit of local heat.
bkrantz
All the tabs now stick out.
bkrantz
May 8 2021, 08:13 PM
And the vents snap tightly into the dash.
bkrantz
May 8 2021, 08:15 PM
Then I decided to complete the engine case assembly.
Here is the Web Cam lube--in the tube.
bkrantz
May 8 2021, 08:16 PM
And on the cam. This establishes a red theme for the assembly!
bkrantz
May 8 2021, 08:17 PM
I replaced the oil pickup tube O-ring, and gave it a bit of assembly lube (red).
bkrantz
May 8 2021, 08:18 PM
And installed the pickup.
bkrantz
May 8 2021, 08:19 PM
Then new rubber edge seals on the baffles.
bkrantz
And installed that.
bkrantz
May 8 2021, 08:21 PM
Then came lots of cleaning of the mating surfaces on both case halves.
bkrantz
May 8 2021, 08:22 PM
I remembered the new cam plug.
bkrantz
May 8 2021, 08:23 PM
And I got out the case hardware.
bkrantz
May 8 2021, 08:24 PM
Here's the right case half with the through bolts installed.
bkrantz
May 8 2021, 08:27 PM
As recommended by Dan at Competition Engineering, I got this Permatex sealant.
bkrantz
May 8 2021, 08:28 PM
Which completes the red assembly theme.
bkrantz
May 8 2021, 08:29 PM
Cam plug installed. And I remembered to add more sealant on the other case half in the plug seat.
bkrantz
May 8 2021, 08:32 PM
With all the hardware installed and torqued, the case is done! And the crank spins!
djway
May 8 2021, 09:51 PM
Puebloswatcop
May 9 2021, 09:23 AM
Awesome progress...Also glad you remembered the new cam plug, forgetting that tends to cause rather large oil leaks...
bkrantz
May 9 2021, 02:36 PM
I almost forgot it, since I was maneuvering the left case half to lower it down, and had a helpful burst of memory--and then stopped to put the plug in.
And I overdid the sealant. I had some fun today cleaning off the excess.
bkrantz
May 9 2021, 02:38 PM
Today was oil pump day. I have played with it so much it seemed like an old friend.
bkrantz
May 9 2021, 02:39 PM
As expected, the case interferes with one corner of the stamped steel cover.
bkrantz
A quick trim with a cut-off wheel and then some grinding to smooth, and ready to go on.
bkrantz
May 9 2021, 02:40 PM
But first I installed the pump body and gears. The body was a tight fit to press into the case.
bkrantz
May 9 2021, 02:41 PM
I used the sealing pump nuts--not sure if really necessary.
bkrantz
May 9 2021, 02:42 PM
And then buttoned-up with the cover.
pilothyer
May 10 2021, 03:31 PM
wrong post
iankarr
May 10 2021, 10:11 PM
Awesome work, as usual. I also spent tons of time with my 26mm oil pump...but I wouldn't call it a friend. Definitely the most challenging part aside from the bearing tolerances.
Question...did you check your oil pump cover for flatness? I had heard that they can be somewhat warpy from the stamping, and indeed mine was a good 1/16 convex out before I lapped it flat on a piece of glass.
bkrantz
May 11 2021, 09:00 PM
QUOTE(iankarr @ May 10 2021, 10:11 PM)
Thanks, Ian. I did check it visually against a flat reference, but not with extreme accuracy. I guess I will find out if it does not seal.
bkrantz
May 15 2021, 07:44 PM
Time to check the crankshaft end play.
I started with a new flywheel. The original was badly scored and grooved.
bkrantz
May 15 2021, 07:45 PM
I have the 3 shims from the tear down.
bkrantz
May 15 2021, 07:47 PM
I installed 2 shims on the end of the crank.
bkrantz
And then the new flywheel with the old bolts.
bkrantz
May 15 2021, 07:49 PM
When I went to tighten the flywheel bolts I remembered a tool I made 30 years ago, and dug around in the tool chest for this.
bkrantz
May 15 2021, 07:50 PM
It still works.
bkrantz
May 15 2021, 07:52 PM
With the bolts tight, I made sure the crank had some axial play. Then I mounted my dial gauge and zeroed it.
bkrantz
May 15 2021, 07:54 PM
And then shifted the crank. I repeated this about a dozen times, and got a consistent axial play of 0.015".
bkrantz
May 15 2021, 07:57 PM
For the desired play of .004", I need a third shim .011".
But the shim I have measures .0135". Time to order a new shim.
bkrantz
May 15 2021, 08:00 PM
Meanwhile, back to working on the body trim. I got out the targa inside pads and hardware.
bkrantz
May 15 2021, 08:02 PM
And got these installed so I can mount the aluminum channels for the rubber trim.
bkrantz
May 16 2021, 07:35 PM
Here's the thin butyl strip material I found, 1/8 x 1/2", and one of the aluminum trim strips that goes on the leading edge of the targa sail.
bkrantz
May 16 2021, 07:36 PM
New stainless screws.
bkrantz
May 16 2021, 07:37 PM
Trim strip installed with the later of butyl underneath.
bkrantz
May 16 2021, 07:39 PM
While in the trim mood, I got out the strips that go on the A-pillars.
bkrantz
More new stainless screws.
bkrantz
May 16 2021, 07:40 PM
Trim installed with butyl.
bkrantz
May 16 2021, 07:41 PM
One last detail today: new ski rack tab receivers.
bkrantz
May 16 2021, 07:42 PM
Installed in the windshield frame top.
bkrantz
May 23 2021, 07:15 PM
I got a long day in the garage today, starting with a few more bits on the engine case.
Thanks to pilothyer, I have a replacement for the missing small oil pressure relief valve.
bkrantz
May 23 2021, 07:17 PM
A light smear of assembly lube, and I put the piston and spring into the cylinder in the left case half.
