QUOTE(napasteve @ Apr 20 2018, 02:21 PM)
Jim, the gap on my back trunk is too wide on the passenger side also (albeit not as wide as your before picture). How do you adjust it?
First, We measured the side gaps near the engine grill and wrote them down. Then subtract the smaller gap and get the difference. This will be used after any changes.
Next, we both loosened the bolts on the trunk hinge. I pulled the hinge on my side to get the bolts closer to the edge of the hinge slot; Eddie did the opposite. Tighten up the bolts, close the lid, and remeasure.
Went through this a second time and the gaps got real close to being equal.
Then, we looked at the gaps at the rear. They were off a little; we loosed the bolts that hold the trunk latch ( the one on the lid). Moved it over a little, and ended up with the rear gaps pretty close.
Two people make this very doable. A small change on the hinges or latch make a good change....
If that wasn’t going to work, I was prepared to remove the lid and the latch. Then widen the spots on the hinge and latch where the bolts needed to be with a metal cutter _ Drexel bit. Fortunately, we did’ have to go there
