Took my 75 914 1.8 for a 30 mile drive today south of Minneapolis. It is the first time in 2 months I have had it out since May while I did the following;
Removed the engine, degreased, located and installed new uncut engine tin on the passenger side where the dealer installed tin was hacked up for the AC (and previously removed).
New engine bay seals-should be much cleaner in the engine bay now, with cool air coming from the top as designed versus the bottom of the engine!
New FI gaskets, intake gaskets, muffler gaskets installed.
New transmission ground strap, new plugs, air filter.
More degreasing and painting of engine tin ***tip Krylon sells a semi-gloss black grill paint that looks like factory paint and looks awesome from Ace Hardware.
Repainted the muffler in factory grey
Repainted the intake headers factory grey
Replaced 1st gear and synchros
Oil change to 40W oil, transmission oil change to 75-90W
Degreased and painted all of the heater elbows factory grey.
Degreased cleaned and painted the flapper boxes.
Reupholstered the seats in factory bone white material (PO painted the interior black, originally white!).
Removed black vinyl paint in the interior.
Sent clock to be repaired at Palo Alto speedo-awesome job.
New clutch cable and adjustment.
It was almost 90 degrees today, and the temp gauge only got to "M" in "Temp" which means the cooling tin is doing its work now!
*** It is now for sale-PM if you're interested in purchasing-I am selling to spend more time with my kids, 2 1/2 year old daughter, and 2 month old baby boy.***
Ran awesome, it was a great time. Now just need to replace the O ring on the side shift transmission that is leaking.
Click to view attachmentClick to view attachmentClick to view attachment
